Old 10-09-2012, 06:43 PM   #16471
DRZ Charlie
Old & beat up
DRZ Charlie's Avatar
Oddometer: 11,086
Originally Posted by DualSportDad View Post
I have had the black box removed on mine for years and my bike doesn't. Consume oil. I just teed the two hoses together and made sure the t is high... zip tied to the frame through the box mounting hole.
Sent from my Galaxy Nexus using Tapatalk 2
On the E model the box vents to atmosphere.
On the S the box vents to the Air box boot which effectively feeds your engine a VERY small amount of warm synthetic or petroleum based mist. Not much advantageadmittedly but it will leak oil onto the swing arm, shock and maybe to the brake disc.
They both (E & S) have the same box just a different hose routing for the box vent
Shedding the box for weight reduction is a non event. It weighs next to nothing.
Ride, Crash, Visit the ER, Get a splint, Recuperate, Assess your mistakes, Repair Motorcycle, Gather courage to ride again, Ride, Rinse & Repeat
My SPOT - No tracks = not riding | Mapsource Tutorial | Rides
DRZ Charlie screwed with this post 10-09-2012 at 08:34 PM
DRZ Charlie is online now   Reply With Quote
Old 10-09-2012, 07:04 PM   #16472
marine_mike
marine_mike's Avatar
Oddometer: 208
Swapped out my white brothers exhaust for a stock one...all is quiet now. Damn carb keeps flooding and overflowing with fuel though, so I just ordered a rebuild kit. I can't say that I'm looking forward to pulling the carb. It's alot more of a detailed job than I am used to doing. I'm not going to rejet just yet because I just got my endorsement and I figured I'd get a feel for it first before I go modding the carb.
marine_mike is offline   Reply With Quote
Old 10-09-2012, 08:10 PM   #16473
payback
payback's Avatar
Oddometer: 46
horn sounds muffled
I just put on some new rad guards (Flatland racing) and my horn seems to be really muffled , barely audible....... Why ?
Also are there any good upgraded horns
for the drz?
thanks.
2006 DRZ400-s
payback is offline   Reply With Quote
Old 10-09-2012, 08:30 PM   #16474
DRZ Charlie
Old & beat up
Oddometer: 11,086
The easiest procedure (for me) for removing the carburetor is below. While your carb is out for the rebuild why not re-jet?
The following procedure looks complicated but it's really not.
1. Remove the seat and side plastics
2. Remove any pannier racks from the frame and sub-frame
3. Loosen the lower sub-frame bolts but don't remove
4. Loosen and remove the upper subframe bolts (you will remove them in step 10.)
5. Remove the fuel and vent lines from the carb
6. Loosen the upper nuts on the throttle cables. Leave the bottom ones alone to help index where the throttle cables were previously adjusted.
7. Remove the throttle cables from the carburetor taking note of which is the front cable and which is the back.
8. Loosen the carb boot clamp between the motor and carb
9. Loosen the carb boot clamp between the carb and airbox
10. Remove the upper sub-frame bolts then spread the sub-frame from the main frame
11. Wiggle the carb out and do whatever you need to.
12. Reverse the process to re-install. Use a light coating of grease on the boots (leading edges) to help with the re-installation of the carb.
DRZ Charlie screwed with this post 10-09-2012 at 08:36 PM
Old 10-10-2012, 09:07 AM   #16475
955616846
Oddometer: 1,692
for the drz?
Have a fiddle with the way it is mounted. The body of the horn should not touch anything and sometimes horns can be sensitive to the tab that they're mounted on.
The Hella Super tone kit (HL85115) is a good one. If only one horn is to be fitted then I'd suggest the lower frequency (300Hz HL85113) as it penetrates a bit better.
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800
Founding member Longtails SC
955616846 is offline   Reply With Quote
Old 10-10-2012, 10:40 AM   #16476
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,180
Swapped out my white brothers exhaust for a stock one...all is quiet now..
U can always use Db Dawg silencer+spark arrestor without compromising the performance of ur muffler.
http://www.hyderacing.com/db_dawg.htm
DR-Z400E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 10-10-2012, 11:13 AM   #16477
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 6,720
for the drz?
thanks.
You probably have something touching the horn. Check for clearances.
If I'm doing much street on a given bike, I'll get a car horn from the auto parts store. That requires the addition of a relay.
We don't stop riding because we get old, we get old because we stop riding.
HellSickle is offline   Reply With Quote
Old 10-10-2012, 09:22 PM   #16478
Mike_drz
Mike_drz's Avatar
Oddometer: 402
Originally Posted by 955616846 View Post
Hmmm, okay. That's interesting. Are you sure it is not just carrying a small LiFe pack inside the air box or elsewhere on the bike?
Right on top of the air filter inside the air box, I think there are enough space for a LiFe pack drill a few holes underneath ecu, to put zip ties to secure the pack. use dean plugs or rc car connectors, it can save big time to remove, recharge or simply disconnect
Mike_drz is offline   Reply With Quote
Old 10-11-2012, 09:41 AM   #16479
DualSportDad
DualSportDad's Avatar
Oddometer: 2,113
I hear ya... I had mine dump a bit of oil one time when the zip tie that holds the "t" up broke and t fell a little. Other than that the only oil leakage I have is one drop on the ground every time I shut the bike off. I ha e the drain hose coming down and it ends just below the shock linkage... dog bones. I didn't remove mine for weight saving I removed it to access my fcr carb easier.
Alex
Cape Coral, Fl.
2003 KLX400R tagged
DualSportDad is offline   Reply With Quote
Old 10-11-2012, 07:30 PM   #16480
Goofy Footer
Oddometer: 254
DRZ400E ride report video - Lobsters in Puerto Nuevo, Baja California
Hello fellow DRZers, I thought I'd share this here for you guys. I hope you enjoy it!
My E handled the trails superbly and I caught myself hauling the mail in certain sections. I really need to get my stabilizer rebuilt cause I smacked a few of those rocks pretty hard while moving at speed. We had a range of bikes from my E all the way to a Scrambler 900cc.
What do you guys think of the video? Hows the length, editing, footage and/or song? I appreciate your thoughts and advice because I want to make the most entertaining ride report videos that I can.
Length 2:35. Watch in 720p for best picture
My E
The Lobster
The Route
I ran this loop round trip from my house in San Diego. Pretty awesome and it was my first time riding in Mex. Rock on DRZers!
Goofy Footer screwed with this post 10-12-2012 at 11:23 AM Reason: added pictures
Goofy Footer is offline   Reply With Quote
Old 10-12-2012, 07:35 AM   #16481
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 102
What advantage does a steering stabilizer have on a bike such as a DRZ-S besides reducing funds in my bank account? Okay it stabilizes steering. What does that actually mean?
coarsegoldkid is offline   Reply With Quote
Old 10-12-2012, 08:27 AM   #16482
955616846
Oddometer: 1,692
Stabiliser? I prefer damper. It will dampen oscillations and absorb impacts in the same way a shock does.
It reduces head shakes, but mostly keeps the wheel pointed in the right direction on impacts to the wheel or bars. You'd notice the benefits in gnarly rocky or rutted ground... or if a bar end clips a tree (within reason!) or cars(!) at speed just to mention a couple of scenarios.
Some use them as a fix for poor riding technique in for example sand. Others use them as a band-aid fix for a badly behaving bike. If the suspension is not as good as it can be then empty your wallet into that before worrying about a damper.
Until you identify a need, you probably won't benefit from one.
Cheers, Numbers
Old 10-12-2012, 08:31 AM   #16483
ptgarcia
Huh?
ptgarcia's Avatar
Oddometer: 508
They slow down those quick bar movements when you hit square-edged obstacles like rocks and other similar impediments. When set properly you don't even know you have one until it kicks in, and even then you don't really feel it it just quietly does its job. I love mine.
Pauly
'06 DR-Z400S
ptgarcia is offline   Reply With Quote
Old 10-12-2012, 08:39 AM   #16484
Goofy Footer
Oddometer: 254
The first two replies describe what a stabilizer/dampner does. Watch the bike's reaction when I slam into that at 1:34 of the video. That handlebar (and bike jerk) is what a a stabilizer/dampner slows down. Its hard to see in the video but I was caught off guard and nearly got bucked off the bike. Running fast for miles through those rocks, I was bound to hit one.
Old 10-12-2012, 08:43 AM   #16485
955616846
Oddometer: 1,692
Which video?
Cheers, Numbers
Times are GMT -7.   It's 08:55 AM.
