11-29-2012, 01:05 PM
#17086 | |
pining 4 the fjords?
Oddometer: 556
how do you remove and install a new cam chain? I understand the valve shimming process in theory, so is it a matter of dangling the chain down till its on the bottom gear, then looping it around the cams or do you have to tear down further? I've never been in there myself, but I think I'll attempt it one of these weekends.... It's just getting too noisy! I'll try and post a vid of the metallic sound I hear....
What Rumble Strip??? http://www.advrider.com/forums/showthread.php?t=734616 http://www.advrider.com/forums/showthread.php?t=723302 |
11-29-2012, 01:11 PM
#17087 |
Oddometer: 2,123
Its been a long time since I have replaced mine. You can check it by setting the motor at tdc and removing the bolt in the back of the acct and then remove the acct from the head. Inspect how far out the plunger is. If its all the way out the can chain is stretched.
If I recall when I replaced mi e I had to remove the clutch basket and the crank gear. You have to be very carefully when putting the clutch basket back on cause of the plastic oil pump gear. If the gears aren't lined up and you tighten everything up it'll damage the oil pump gear and starve the engine for oil. I remember the job east hard and it only took me an hour or so but I'm also a mechanic for a living. Sent from my Galaxy Nexus using Tapatalk 2
Alex Cape Coral, Fl. 2003 KLX400R tagged
11-29-2012, 01:58 PM
#17088 | |
Scone Rider
Oddometer: 6,873
We don't stop riding because we get old, we get old because we stop riding. |
11-29-2012, 03:06 PM
#17089 |
OLD DOG-NEW TRICKS
Oddometer: 1,970
Mine is an E,and I haven't taken the time yet to fool with it.I believe it is set up for the sub frame bikes.
24 hours,maybe 60 good years,it's really not that long a stay.........jimmy b. |
11-29-2012, 05:02 PM
#17090 | |
Oddometer: 795
is the water pump exposed as much as that oil line is ? id rather punch the case with the shifter (bike dropped and stopped) than take a rock to the oil line or water pump at speed.
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
11-29-2012, 05:07 PM
#17091 | |
I lost my village!
11-29-2012, 05:08 PM
#17092 |
I lost my village!
Check the link.
11-29-2012, 10:19 PM
#17093 | |
Oddometer: 35
'11 DRZ400S Acerbis Handguards,TT Case Savers,Unibiker Radiator Guards,Hyde Skid Plate,Kenda 270,HEL Braided Lines,IMMIX Cargo Rack,3X3 Mod,JD Jet Kit,Yoshi Fender Eliminator Kit,Moose Headlight Cowl Bag,Moose Cross Bar Pad,Swing Arm Decals,Gripper Seat Cover,ASV F3 Brake & Clutch Levers,Yoshi RS-2 Full Exhaust CF,Zeta Brake Clevis,Anodized Check Plugs,Mishimoto Hoses |
11-30-2012, 04:13 AM
#17094 | |
I lost my village!
11-30-2012, 05:07 AM
#17095 |
Oddometer: 1,726
Those PE plates might surprise you.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800, 13 FXST Founding member Longtails SC My Bike Pages |
11-30-2012, 05:17 AM
#17096 |
I lost my village!
They might. After seeing a guy I ride with rant about how great his carbon fiber cover was on his expansion chamber and then run it into a tree and put a huge dent in it without the cover looking like anything happened...I will just stick to tried and true. Please don't get me wrong I have looked at and contemplated the Hyde stuff before but I concluded that I would only use it for wear resistance or areas that have a strong backing.
11-30-2012, 05:25 AM
#17097 |
No Marks....
Oddometer: 1,650
11-30-2012, 12:42 PM
#17098 |
Ex: RideWithMe
Oddometer: 546
I was the same, at the end of the day it was the torque of the DRZ400E over WR250R and also I intended to do a bit more road commuting. I love being able to just sit back and pull the throttle for the power and not have to work the engine. The WR has power but you have to work the engine. I also loved the "tractor" ability of the DRZ, it's just like a low reving tractor up hills. I really wish I had the WR suspension though
George Carlin “Never argue with an idiot, they'll only bring you down to their level, then beat you with experience.” I'm the slow guy on the 2013 KTM 690 Enduro R, please toot as you go past ![]() Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY |
11-30-2012, 01:05 PM
#17099 |
Oddometer: 706
Cheers all!
I sold my KTM and get to use my friends DRZ until I buy a bike. Beeing a bit spoilt by the austrian I'm trying to set up the DRZ to my riding style so I've got a couple of questions for you and would appreciate some help.... We have put a FCR 39 and an open exhaust can, bike pulls much much better but it leaks gas on the overflow....I suppose the float height needs to be adjusted; do you know, from the top of the head what is the float height for the FCR39, I think I've read somewhere it's 9 mm. Front brake.....is there something to do with stock front brake setup to get more feel or is it just up to the quality of the pads? Wouldn't like to go aftermarket cause it get's expensive quickly so I'm looking for a cheap fix/trick/something. The lack of feel on the front brake could be up to the front suspension, I'm 97 kg with gear, stock forks, preload set at 1 groove from top, compression damping set at 4 clicks out from hardest setting.....tips/advice....would also like to stay stock..... And the last issue; how much is it possible to rise the bars without stretching the cables too much? Also, what aftermarket bar would you recommend? Thanks! M.
ENDURO DALMATIA LC4 Adventure parts for sale: http://s485.photobucket.com/albums/r...%20for%20sale/ |
12-01-2012, 12:31 AM
#17100 |
Oddometer: 1,726
Without actually seeing it, best guess is the float needle is stuffed.
There is nothing to be gained with after market pads. The Suzuki HH pads arguably offer the best all round performance (including feel) for the average rider. Perhaps the one area where they lack is outright braking performance and the only real fix for that is a larger rotor. The best improvement that can be made to the brakes after ensuring that everything is in good shape (ie clean, greased wheel pistons and sliders and fresh well bled fluid) without spending large amounts of money is a braided line - especially so if the bike is more than a couple of years old. Mine has a 320mm EBC rotor (+ larger 240mm rear with an SM caliper bracket), Suzuki pads, Venhill braided lines and the calipers are stripped and cleaned annually. They have power and feel, but it cost a little more than pocket change and I do need to be mindful of the rotor diameter on rough ground. The bars can be raised 50-60mm before cable lengths become an issue.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800, 13 FXST Founding member Longtails SC My Bike Pages 955616846 screwed with this post 12-01-2012 at 01:19 AM |
