Old 01-21-2013, 02:11 PM   #17116
bonekrusher
big jerk
bonekrusher's Avatar
Oddometer: 56
Originally Posted by focallength View Post
Ok, ill pull it off when I get home, any idea which direction they go, im guessing round nose side in, towards the engine.
The smaller part goes toward the engine - the round top is the contact for the cap that goes on top.
bonekrusher is offline   Reply With Quote
Old 01-21-2013, 02:40 PM   #17117
focallength
You're Welcome
focallength's Avatar
Oddometer: 4,982
I dont see a place for them...
Theres only 2 holes for the bolts...
focallength is offline   Reply With Quote
Old 01-21-2013, 02:53 PM   #17118
bonekrusher
big jerk
Oddometer: 56
http://i65.photobucket.com/albums/h2...psc818d0dd.jpg
I just noticed the link in your sig - your rebuild thread in October is part of what helped me decide to get a DRZ and rebuild it (as oppose to just getting a brand new bike).
If you hadn't started your thread I probably wouldn't know jack about those pins. Funny how that works.
bonekrusher screwed with this post 01-21-2013 at 03:01 PM
Old 01-21-2013, 03:01 PM   #17119
focallength
You're Welcome
Oddometer: 4,982
Originally Posted by bonekrusher View Post
Really? Alright, I thought those were oil holes...
So, I put them in the holes, they just sit in there? No springs or anything? Theres no magnetic pull from the engine or the other piece...
focallength screwed with this post 01-21-2013 at 03:07 PM
Old 01-21-2013, 03:03 PM   #17120
bonekrusher
big jerk
Oddometer: 56
I can't believe yours just fell out - I was holding my engine sideways and shaking it to get them out before I was told
by someone to use a magnet, then they came right out.
Anyways - hope all goes well with the rest of your build.
Edit: I think there are springs - when you put them in and depress them they should pop up a little less than a quarter inch to keep tension against the cap.
bonekrusher screwed with this post 01-21-2013 at 03:10 PM
Old 01-21-2013, 03:09 PM   #17121
focallength
You're Welcome
Oddometer: 4,982
Well, I distinctly remember them falling out...so what does that black hockey puck thing do? Im thinking something may be broken if they just fell out...
Thanks, just ordering parts now, almost have everything, just need intake cam, head, left radiator, right radiator sensor, primary gear for the clutch, clutch plates and im going to throw on a fmf power bomb header...thats it.
Old 01-21-2013, 03:12 PM   #17122
bonekrusher
big jerk
Oddometer: 56
The cap? It just holds the contacts to run the switch.
I'll be home in like an hour and a half and then I can take pics of all parts and the order they go in.
I just checked every microfiche I can find on the DRZ and nothing shows those contacts/springs/cover or mentions neutral indicator at all. Damn.
As mentioned I'll put up what I can when I get home.
bonekrusher screwed with this post 01-21-2013 at 03:26 PM
Old 01-21-2013, 04:25 PM   #17123
bonekrusher
big jerk
Oddometer: 56
Ok, so I was wrong about them having any magnetic anything holding them in place - guess mine were just stuck
However they are spring loaded.
http://i65.photobucket.com/albums/h2...psd0d07dc9.jpg
Will post spring dimensions shortly - have a question about which microfiche shows these on TT, hopefully someone responds.
Ok - they are about a half inch long (uncompressed) 11.5mm and just under 3/8ths in. (4.5mm) wide. Wish I could be more help...
bonekrusher screwed with this post 01-21-2013 at 04:34 PM
Old 01-21-2013, 04:37 PM   #17124
focallength
You're Welcome
Oddometer: 4,982
Thanks, I knew there had to be springs..., that pic will help me find them.
Old 01-21-2013, 04:38 PM   #17125
ohgood
ohgood's Avatar
Oddometer: 2,882
Originally Posted by DualSportDad View Post
You most likely have a valve that is tight. Check the valves. If one is tight rebuild the head.
Sent from my Galaxy Note 2 using tapatalk 2
mmm
Sounds like a timing chain stretched to me... I wouldn't worry about the head until the valves are needing reshimmed every oil change.
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 01-21-2013, 06:38 PM   #17126
bkwags
bkwags's Avatar
Oddometer: 92
Coolant Reservoir
Anyone know where I can find a coolant overflow tank for my 2001 DRZ? I hear turkey basters work, any tips on that will get me by till I find the real thing would also be helpful.
Cheers!!
BKWags
bkwags is offline   Reply With Quote
Old 01-21-2013, 06:44 PM   #17127
DualSportDad
DualSportDad's Avatar
Oddometer: 2,441
Cheers!!
BKWags
Use a turkey baster and don't look back. Mine has worked great for years.
Sent from my Nexus 7 using Tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 01-21-2013, 06:50 PM   #17128
DualSportDad
Oddometer: 2,441
Originally Posted by ohgood View Post
mmm
Nope, sounds like a tight valve. A timing chain that is stretched makes a rattle noise as idle comes down... Like when you adjust a mcct. A tight valve will tick constantly.
I've had my can chain loosen up a couple times over the years.... Once with a acct and a couple times since the mcct and new chain. It has never sounded like that. When my valves got tight tight many years ago it sounded exactly like that. I also had the starting problems that he mentions. Bike would run fine when warm but cold I would kill my battery at times trying to get it started.
Edit: oh and... The two main weak parts of a DRZ in my eyes are the valves and the oiling system. I don't take chances with either. I use the best oil possible and of a valve gets tight I rebuild the head. I'll only shim it once on the initial rebuild, check them at 3,000 miles and never look back. I also make sure to run very clean air filters at all times to help make sure I don't have to rebuild a head again. Its worked so far.
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
Old 01-21-2013, 07:32 PM   #17129
focallength
You're Welcome
Oddometer: 4,982
Really? Why not just use the OE bottle?
Got pics?
Old 01-21-2013, 07:35 PM   #17130
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,005
I took the DRZ on a ride on Sunday. It was mostly washes & various terrains. Here's one of my vids.
http://youtu.be/eSQRXwD_AVY
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY screwed with this post 01-21-2013 at 08:57 PM
DR650SEDDY is offline   Reply With Quote
Times are GMT -7.   It's 01:52 AM.
