Old 02-02-2013, 03:15 PM   #17236
Danielmoben
Danielmoben's Avatar
Oddometer: 27
Originally Posted by fifthcircle View Post
Subscribed
Danielmoben is offline   Reply With Quote
Old 02-02-2013, 04:22 PM   #17237
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,016
Originally Posted by Greg MacD View Post
Okay, I searched and can't find what I am looking for so I am going to ask.....I know the answer is out here some place, but anyway.....I just bought a stock set of SM wheels for my DRz, they have the stock 310mm rotor installed, what I am looking for is an adapter to move my stock caliber (S model bike) to work with the lager rotor.....I have found an adapter for a 320mm rotor, but I'm not necessarily looking to buy another rotor too.
Where can I find a bracket that will work for a 310mm rotor???
thanks for the help!
I don't think there's an adapter to relocate the S caliper to fit the SM rotor. Since the hub is the same, your cheapest option is to buy another S rotor and put it on the SM wheel. Otherwise, you'll need the 320mm relocator bracket and TWO 320mm rotors.
Starchamp is offline   Reply With Quote
Old 02-02-2013, 05:19 PM   #17238
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,016
Originally Posted by Danielmoben View Post
Hi, where did you buy the gallon tank? (I mean tank and support) Do you know any international suplier?
www.mobenmotorcycles.blogspot.com
It's a Kolpin Fuel Pack Jr. 1.5g tank, very similar to the RotopaX products, and mounts the same way. I'm sure if you search for either one of those, you'll probably find an international source local to you.
Old 02-03-2013, 06:56 AM   #17239
Danielmoben
Oddometer: 27
Thanks I will try, I think it's an interesting option for long routes...
Old 02-03-2013, 07:17 AM   #17240
Rockaway
Gregtiger800
Rockaway's Avatar
Oddometer: 86
Question??
I'm running a set of Warp 9 rims(love em) with ktm size 450 hubs on my DRZ. I'd like to get my gearing back to stock (DRZ S model). I've ordered a 40 size rear sprocket. What are your thoughts??
Any help is appreciated...
Love the rims.. They are a great compromise for adventure/ dual sport riding. I own a 2006 drz400 sm. But would like the bike to travel smoother, less buzzy, on the freeways while I commute on it with the larger tires. I'll stick with my stock setup while I have the sm tires on it...
Greg
Sent from my iPad using Tapatalk HD
Rockaway screwed with this post 02-03-2013 at 07:31 AM
Rockaway is offline   Reply With Quote
Old 02-03-2013, 07:40 AM   #17241
Greg MacD
Greg MacD's Avatar
Location: Flying at 1500 foot AGL over the Gulf of Mexico
Oddometer: 470
Thanks, looks like I am going to fork out another $200 or so on the SM wheels.....Guess the 320 conversion will be bad ass, might be worth the extra money!
2003 Aprilia RST1000 Futura
2006 Harley Davidson FLHTPI
2004 Suzuki DR-Z400s (Motard)
"Drinking Rum before 10 am does not make you an Alcoholic, it makes you a Pirate"
Greg MacD is offline   Reply With Quote
Old 02-03-2013, 07:42 AM   #17242
Greg MacD
Greg MacD's Avatar
Oddometer: 470
Why two rotors? One for each set of rims?
Old 02-03-2013, 09:54 AM   #17243
gots_a_sol
gots_a_sol's Avatar
Oddometer: 475
Or just run the S disk on the dirt wheels like normal.
06 Husky TE610
09 Husky WR165 - VCHSS #79L
gots_a_sol is offline   Reply With Quote
Old 02-03-2013, 02:18 PM   #17244
EmmEff
Oddometer: 1,735
Can anybody offer advice for jetting my stock DRZ for riding in -10C? (I think) I know I need to add more fuel to richen up the mixture, but that's where my knowledge ends :)
2001 F650GS Dakar
2008 DR-Z 400S
EmmEff is online now   Reply With Quote
Old 02-03-2013, 03:39 PM   #17245
markjenn
Oddometer: 10,456
It is running poorly now? I've ridden mine down to 10 deg F or so and it ran fine. It's probably not optimal, but for most of us, adjusting jetting with weather changes is a bridge too far. You jet for the average conditions and live with the extremes.
- Mark
markjenn screwed with this post 02-03-2013 at 08:22 PM
Old 02-03-2013, 06:34 PM   #17246
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,043
contact Eddie. http://www.sisnerosspeedworks.com/ http://www.epicmotosports.com/catalo...atalogId=-2183
he is the master.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 02-03-2013, 06:44 PM   #17247
jackpiner57
Moto-Racks.com
jackpiner57's Avatar
Oddometer: 1,674
I'm a believer in the James Dean Jetting kits. They are designed to work with the 3x3 mod, which is to remove the snorkle in your airbox and enlarge the hole to 3"x3". This gives more air to go along with the increase in fuel that the jetting kit provides. The kit comes with very good instructions, but they forget to mention to buy the Kientech extended fuel screw and use the stock pilot jet when re-jetting. The Kientech richens up the pilot circuit, which eliminates the need for the larger pilot jet. I did this mod to three DRZ-S's and they all turned out great. I ride in 14f degree temps (-10c) and the bike runs very well.
Tom - '07 DR-Z400S, '05 DL650
Dual Sport Luggage Racks: DRZ400, DR650, KLR650, WR250R:
http://www.moto-racks.com
"I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott
jackpiner57 is offline   Reply With Quote
Old 02-03-2013, 07:17 PM   #17248
motolab
motolab's Avatar
Oddometer: 2,714
Originally Posted by eakins View Post
Hardly. In my experience, his jetting recommendations for the FCR for the DRZ400 are way off. In fact, once the jetting is corrected, all of the gymnastics with the accelerator pump become superfluous.
Regards,
Derek
motolab screwed with this post 02-03-2013 at 07:58 PM
motolab is offline   Reply With Quote
Old 02-03-2013, 08:40 PM   #17249
EmmEff
Oddometer: 1,735
To be honest, I haven't actually had it out in this temp. I am just afraid of doing any damage.
Probably sound advice, but I don't have time to spare. The way this winter has been going, I probably have a couple of weeks at the absolute most and I only decided at the last minute that this was worth pursuing. I'm hoping to figure out something and get parts locall.
I don't doubt your results, but I would've thought the jetting wouldn't be able to span such a temperature range. When I use to ride a snowmobile, I know they were jetted from the factory for around 0F which meant when the temps got close to freezing, the jetting was off. I imagine the same thing would be true in reverse (jetted for above freezing meant it'd be off at below freezing). I'll see how it runs as is, but I'm worried about doing damage.
Thanks for all the replies!
2001 F650GS Dakar
2008 DR-Z 400S
Old 02-04-2013, 02:06 AM   #17250
markjenn
Oddometer: 10,456
You're not going to do any damage. Again, the jetting may be somewhat leaner than optimal for very cold temps, but you can't hurt the engine. I bet it will run fine.
- Mark
Times are GMT -7.   It's 06:34 AM.
