Old 02-06-2013, 02:24 PM   #17296
threadkiller
Semi-feral Pappy
threadkiller's Avatar
Oddometer: 1,796
Originally Posted by Smokeydrz View Post
Hi does anyone have an fmf q2 muffler? ive lost the screw that holds the spark arrestor in place and need to know its size
I have an FMF. My screw fell out, as well as the spark arrester. I do know mine was a machine threaded, allen head cap screw. About 4 or 5 mm if I recall.
threadkiller is offline   Reply With Quote
Old 02-06-2013, 04:56 PM   #17297
bobbed06
Cavalera Conspirator
Oddometer: 1,236
DRZ Hi/Lo beam doesnt work
So I went for a ride after work and the headlight worked fine. Then after this rough dirt road I lost BOTH my high and low beam. This evening I looked into it and had no 12v at the bulb connector, so I opened the headlight switch to discover the Yellow/White wire on the top of the switch had broke loose at the solder joint. I will resolder it tomorrow evening after work.
Just thought I would share....
bobbed06 is offline   Reply With Quote
Old 02-06-2013, 04:58 PM   #17298
bobbed06
Oddometer: 1,236
Originally Posted by blaster11 View Post
Picked up a Trail Tech Vapor for the DRZ and was wondering if there are any tricks to get the tachometer to work reliabily or just wrap it around the plug wire and call it good?
Connect it directly the coil pack via a piggyback spade connector
Old 02-06-2013, 05:04 PM   #17299
DualSportDad
DualSportDad's Avatar
Oddometer: 2,456
Anybody wired directly into the coil?
Mine is. Just cut the signal wire and solder and heart shrink it all together.
Sent from my Galaxy Note 2 using tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 02-06-2013, 05:06 PM   #17300
DualSportDad
Oddometer: 2,456
Do not do this. You are asking for a corroded or broken wire. Use solder and Marine heat shrink.
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
Old 02-06-2013, 05:24 PM   #17301
blaster11
Where to go......
blaster11's Avatar
Oddometer: 7,157
blaster11 is offline   Reply With Quote
Old 02-06-2013, 07:11 PM   #17302
p0diabl0
Oddometer: 571
I just wrapped it... never had a problem in 4+ years.
p0diabl0 is online now   Reply With Quote
Old 02-07-2013, 12:59 AM   #17303
Adrian V
Oddometer: 520
Removing the helmet lock
I want to remove the helmet lock, but leave the frame tab behind to mount a tool tube, anyone know the easiest way to do this? It looks like I could drill out the bolts, is that the best way?
Cheers,
Adrian
Adrian V is offline   Reply With Quote
Old 02-07-2013, 02:28 AM   #17304
DRDeano
Oddometer: 36
Cheers,
Adrian
Unlock it with the key then undo the screw behind the retracted bar. Easy!
Sent from my GT-I9100T using Tapatalk 2
DRDeano is offline   Reply With Quote
Old 02-07-2013, 03:02 AM   #17305
Adrian V
Oddometer: 520
What size bit?
God I feel dumb now . That looks like a tamper proof torx bit, any idea what size?
Cheers,
Adrian
Old 02-07-2013, 04:07 AM   #17306
ifixfords
ifixfords's Avatar
Oddometer: 277
Originally Posted by ohgood View Post
Something is wrong with his jetting, brakes, or technique. S, SM, E will all walk along nice and slow with 14/47 (assuming 18/21" wheels on them) gearing just fine. Fix his jetting, no need in making miraculous claims about E's.
I beg to differ. I have a 2001 E and a 2004 S (with stock BSR). There is a big difference between the two (both are 14/47). The fcr carb has an accelerator pump, which is what changes the throttle response. If an E model doesn't perform better than a stock S or you have issues with starting there is something wrong. My E starts reliably hot or cold at temps from 100 F down to 25 F, it has the stock FCR jetted to match the full yosh system. Even a stock E should have better throttle response.
Don't get me wrong, there is nothing wrong with a stock S model. Just takes a little more clutch and rpm control compared to the E. Love my DRZs. :)
Real motorcycles have 21" front wheels!
2014 BMW F800GSA
2008 KTM200XC-W
2009 Beta EVO 250
ifixfords is offline   Reply With Quote
Old 02-07-2013, 07:01 AM   #17307
luni
Non-artic explorer
luni's Avatar
Oddometer: 1,093
Since it seems relevant once upon a time I heard from a guy (yup) that the slide in a vacuum carb could jostle a bit in washboard or rough track and make inconsistent fuel delivery even with steady throttle application just from the mechanics of the carb. A pumper carb, by design, doesn't have this problem making for quicker and more consistent throttle.
True? Outlandish hootenanny? Often unspoken benefit of pumper vs vacuum carb?
When I was rebuilding my S I got a great deal on a pumper carb and it made a complete difference from the jetted 3x3 I had before.
Originally Posted by true grip View Post
I got a feeling the KTM would be like a hot girlfriend so fun to be with just not trust worthy.
luni is offline   Reply With Quote
Old 02-07-2013, 07:59 AM   #17308
150ron
150ron's Avatar
Oddometer: 1,459
For all you guys that went from the stock mikuni carb to the FCR, has your mpg's decreased by much?
Just some dude...
150ron is offline   Reply With Quote
Old 02-07-2013, 08:57 AM   #17309
luni
Non-artic explorer
luni's Avatar
Oddometer: 1,093
55mpg wide open everywhere to 45mpg on a good day.
Old 02-07-2013, 09:18 AM   #17310
ifixfords
ifixfords's Avatar
Oddometer: 277
+1
DRZ400E Tagged
KTM200XC-W ""
2014 BMW F800GSA
2008 KTM200XC-W
2009 Beta EVO 250
Times are GMT -7.   It's 11:49 AM.
