Old 02-07-2013, 10:36 AM   #17311
SSG B
Rounds complete
SSG B's Avatar
Oddometer: 623
Originally Posted by Jon B.
Unless, that is, you have an 'E' with the FCR, big cams, high compression and the snorkel removed. Then rejet said FCR carb. The low-end torque is *very* noticeable. The throttle response, too. Inmate SSgB has an '01 E with stock carb & pipe but open airbox. I have an '05 E with full Yosh exhaust and fat jets. Mine will leave his in the dust every time! Same gearing on the two - 14 & 47.
Mine will 'tractor' along on the single track without slipping the clutch quite nicely. He's riding the clutch and keeping the RPMs up to pull his along.
The E already has a better pipe than the S (I think; could be mistaken), so the improvement will be more significant, provided you can get air and fuel into the cylinder to complement the outflow.
Jon
Something is wrong with his jetting, brakes, or technique. S, SM, E will all walk along nice and slow with 14/47 (assuming 18/21" wheels on them) gearing just fine. Fix his jetting, no need in making miraculous claims about E's.
^Originally posted by "ohgood" ^
__________________________________________________ __________________________________________________ _-
There might be some jetting that is needed as it does not start all that easily and likes the choke until it is good and warm. However, the brakes work just fine, and my technique is decent.
Jon's claims are true, his 05 with a full yosh system will walk away from mine on a drag race. It will also tractor along much better than mine will. My 01 is not slow or underpowered by any means, but his, with a pipe, does in fact have a lot more "go" in it and that "go" wants to get out faster.
Granted this is all gauged by the calibrated seat of my pants, so take it for what it is worth. He would win a drag race hands down every time. Wheel size and gearing is the same on the both of them.
My $.02
You, this is me, over.
Bike-less in Minnesota
SSG B screwed with this post 02-07-2013 at 10:38 AM Reason: added a fancy line and some text
SSG B is offline   Reply With Quote
Old 02-07-2013, 10:37 AM   #17312
150ron
150ron's Avatar
Oddometer: 1,313
Originally Posted by luni View Post
55mpg wide open everywhere to 45mpg on a good day.
Originally Posted by ifixfords View Post
+1
DRZ400E Tagged
KTM200XC-W ""
Sounds pretty damn good to me, seems like the FCR is the mod to do to these bikes.....
If i only had a extra $500 bucks laying aorund, lol
Long story short, went off roading, something broke, i go to fix it, and the tool bag zipper broke off, the bag is garbage,
Replaced it with a Tusk rear fender bag ($20 dollars shipped, also had this exact bag on my previous bike, good shit) same exact size as the stocker, but stronger all around, mounted it without using the stock white plastic tool holder thingie, and now can fit almost double the stuff in there, without the white plastic taking up needed space.
Just some dude...
150ron is offline   Reply With Quote
Old 02-07-2013, 11:00 AM   #17313
DualSportDad
DualSportDad's Avatar
Oddometer: 2,430
Since it seems relevant once upon a time I heard from a guy (yup) that the slide in a vacuum carb could jostle a bit in washboard or rough track and make inconsistent fuel delivery even with steady throttle application just from the mechanics of the carb. A pumper carb, by design, doesn't have this problem making for quicker and more consistent throttle.
True? Outlandish hootenanny? Often unspoken benefit of pumper vs vacuum carb?
When I was rebuilding my S I got a great deal on a pumper carb and it made a complete difference from the jetted 3x3 I had before.
I ride my bike weekly down a wash board dirty road with pot holes. It does the same with the bsr as it did with the fcr.
Think of it like this: the fcr has a direct link from your hand to the slide, the bsr does not. ..just to a butterfly. If your hitting bumps I could understand how the vacuum slide might get jostled around a bit but if you're hitting bumps I'm sure your hand isn't staying still either so that direct link to the slide on the fcr would be moving around as well.
Sent from my Galaxy Note 2 using tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 02-07-2013, 11:41 AM   #17314
Jon B.
Oddometer: 581
I made no such "miraculous" claims; just a statement of fact.
A decent aftermarket exhaust system - not just a muffler or just the header, etc - *will* make a noticeable difference. Measurable, even. I suspect the difference is noticeable on the S but you claimed all it does is make noise (indirectly). Swap the exhaust system, open the airbox, increase the jetting; voila! A measurable, noticeable, significant gain in performance. With the bigger cams, higher compression and pumper carb on the E, the open pipe has more effect than on the S, which can't breathe as well or deliver fuel as well.
SSgB's E used to be mine. It runs well, though is a bit lean after opening the airbox (de-snorkled). Bumping the jet a size or three would cure that. His still won't stay with mine, either poking along on the single track or drag-racing. Mine simply has better performance, fast or slow. It's not a miraculous claim; it's a fact.
Jon
Hey - if it ain't an adventure, it's just a ride!
'05 DRZ 400E Titled/Plated
Jon B. is offline   Reply With Quote
Old 02-07-2013, 09:29 PM   #17315
RMOTO
Doing secret stuff
RMOTO's Avatar
Oddometer: 332
2 week adventure ride through New Zealand on a DRZ400
Full Ride Report Here
www.RemoteMoto.com
RMOTO is offline   Reply With Quote
Old 02-07-2013, 10:23 PM   #17316
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 928
Damn you, your enticing terrain, your lack of government restrictions, and apparent over-abundance of sunshine.
10-14" of snow on the way here in over the next 36 hours.
Starchamp is offline   Reply With Quote
Old 02-07-2013, 10:47 PM   #17317
Nashvegas
Nashvegas's Avatar
Oddometer: 7
Thanks for the report ADVGD! Looks incredible!!
Nashvegas is offline   Reply With Quote
Old 02-08-2013, 03:14 AM   #17318
ifixfords
ifixfords's Avatar
Oddometer: 277
Great pics advgod! Looked like an awesome vacation.
Sent from my GT-N8013 using Tapatalk HD
Real motorcycles have 21" front wheels!
2014 BMW F800GSA
2008 KTM200XC-W
2009 Beta EVO 250
ifixfords is offline   Reply With Quote
Old 02-08-2013, 06:32 AM   #17319
Plane Dr
Plane Dr's Avatar
Oddometer: 857
Without seeming rude. Have you removed the kickstand safety? Washboards, small whoops it will bounce around killing the engine with small rapid bumps maybe that is the issue especially if the kickstand return spring is weak.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 02-08-2013, 06:41 AM   #17320
Wlfman
Wlfman's Avatar
Oddometer: 1,288
You sir SUCK
I hope to one day explore your beautiful country
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 02-08-2013, 09:42 AM   #17321
DualSportDad
Oddometer: 2,430
It does not.
Oh and for the record mine doesn't miss a beat on dirt roads etc, bsr or fcr unless I get knocked around pretty bad and then it is just my hand making it do that.
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
Old 02-08-2013, 09:50 AM   #17322
streetndirt
streetndirt's Avatar
Oddometer: 122
DRZ ready to ride!
Sent from Samsung Galaxy S2
streetndirt is offline   Reply With Quote
Old 02-08-2013, 10:27 AM   #17323
motolab
motolab's Avatar
Oddometer: 2,579
Indeed. See http://www.moto-lab.com/gallery/view?itemid=351.
Regards,
Derek
motolab is offline   Reply With Quote
Old 02-08-2013, 10:51 AM   #17324
150ron
150ron's Avatar
Oddometer: 1,313
Originally Posted by streetndirt View Post
DRZ ready to ride!
Looks great!
Just some dude...
Old 02-08-2013, 01:59 PM   #17325
Wlfman
Wlfman's Avatar
Oddometer: 1,288
Got my 1.75 Gallon Rotopax today, mounted up to my rear rack.
Wlfman screwed with this post 02-08-2013 at 02:50 PM
Times are GMT -7.   It's 01:42 AM.
