Old 02-11-2013, 06:27 AM   #17371
WayneJ
LFC City Slicker
WayneJ's Avatar
Oddometer: 6,120
Originally Posted by oclv454 View Post
Can someone recommend a good place to buy OEM replacement plastic body panels for my 2009 DRZ400S? I've found a few that sell after market, but wanted to compare the price to original. Thanks.
www.ronayers.com
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 02-11-2013, 06:31 AM   #17372
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,100
Wheeling Cycle Supply has a decent AM selection at decent prices, but Bike Bandit is the only place I know of that sells OEM parts. Though I'm sure there are others....
Starchamp is offline   Reply With Quote
Old 02-11-2013, 06:57 AM   #17373
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
The OEM stuff is ghastly expensive compared to aftermarket. Let's get that out of the way right now. It is also made better in the case of the front fender. The rears are cheesy and flimsy though. Aftermarket is just as good on side panels and shrouds. Like others have said, Wheeling Cycle Supply. Cheaper and lots of colors to choose from.
buls4evr is offline   Reply With Quote
Old 02-11-2013, 08:07 AM   #17374
rattis
rattis's Avatar
Oddometer: 1,240
Talking High rpms
Hi back again, the maybe PO says that his DRZ revs 1000 rpm / 10 mph, a buzz that eventually will drive me mad or what?
Lazy revs are nice but then again some buzziness is Ok as long as it does emulate a vibrator for my hands and fingers and I get a pesky performance
Can I give it a cog or two to loose some revs or will this turn it into a sloth?.
Or should I just buy a KLR
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, thrice up now, two 990 Adv and a 950 SER
rattis is offline   Reply With Quote
Old 02-11-2013, 08:56 AM   #17375
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,323
The major drawback to the DRZ is its short ratio gear box.
With the "S" stock gearing it is just a tad too tall in first gear, so to me there is not a lot of room to go any higher with the gearing.
With stock gearing I can ride mine all day long around 60 mph true (65-68 mph on the speedo)
Around 65 true (72-74 mph on the speedo) I can still do but it becomes notably more tiresome.
Anything above that is maddening to me.
IMO as long as you mostly can stay around or under 60 mph true the bike is fine with stock gearing.
Ogre_fl is online now   Reply With Quote
Old 02-11-2013, 09:07 AM   #17376
farkleface
ridin dirty
Oddometer: 125
Originally Posted by Dirtmongrel View Post
Was the battery dead prior to charging it?
Don't forget about all the safety switches/interlocks... kickstand switch, clutch switch, neutral switch, start/stop switch. And the one of relays may stuck... the blinker relay behind the headlight is multifunction, your start button goes thru it.
lights should still go on before startup, the R/R shouldn't effect it at that point
The battery was low before I put it on the charger, but it had power to everything at that time also?? The charger did something to kill all the electrical ??
farkleface is offline   Reply With Quote
Old 02-11-2013, 09:12 AM   #17377
bobfab
bobfab's Avatar
Oddometer: 1,499
Hey guys,
I am going to be rebuilding the waterpump on the 400 in a couple weeks. Does anyone have a parts list of required gaskets and stuff i will need? Any advice appreciated thanks!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 02-11-2013, 09:37 AM   #17378
luni
Non-artic explorer
luni's Avatar
Oddometer: 1,091
This has nothing to do with water pump rebuilds and everything to do with cattle dog profile pictures.
Originally Posted by true grip View Post
I got a feeling the KTM would be like a hot girlfriend so fun to be with just not trust worthy.
luni is offline   Reply With Quote
Old 02-11-2013, 10:14 AM   #17379
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,030
Originally Posted by bobfab View Post
Hey guys,
http://www.ebay.com/itm/2005-2006-20...c77f5f&vxp=mtr
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 02-11-2013, 10:21 AM   #17380
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,030
Originally Posted by farkleface View Post
So.........I put a charger on my drz and forgot about it for over 24hours. When I took it off the charger and turned the key, the bike is dead. No lights, no anything. Also, I noticed the charger was set for a 12v 12a charge rate, which I know is way too much especially for that long. So I checked battery voltage and it is reading 13.4 . I checked fuse and it looks good. I checked voltage at plug between rectifier/regulator and battery and it is reading 13.4. I checked voltage at plug coming out of R/R and there is nothing. I am guessing the R/R is maybe bad? Any help would be appreciated before I order the RR.
Oh, and yes I already know I don't know what I'm doing and that I am an idiot
I had this happen to me once during a ride and i replaced the fuse located by the batterie. It was due to a short in the wires (under the headlight). U must a have a short somewhere.
Old 02-11-2013, 10:30 AM   #17381
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,030
Originally Posted by rattis View Post
The PO has tuned the engine and it has, according to him, 50 hp on the wheel.
Andy
The only way to get to the vacinity of 50hp is to insatll the 469cc kit big bore cylinder work. They're around $800 give and take (just for parts).
Old 02-11-2013, 11:10 AM   #17382
bobfab
bobfab's Avatar
Oddometer: 1,499
Originally Posted by DR650SEDDY View Post
the pump is leaking around the seals to the side case. Do you think it is recomended that i replace the whole water pump
I was hoping someone was familiar with what gaskets i needed (suzuki part numbers). thanks!
@luni; hahahah thanks man. Love ACD's
CRF250L | KTM200SX
Old 02-11-2013, 11:16 AM   #17383
Plane Dr
Plane Dr's Avatar
Oddometer: 878
Um no. If you go much bigger than 434cc on the cylinder you will have gasket issues among other things. 50 hp can be done fairly easy but it.s not just bore.
Mine is 55+ depending on the dyno (the base version ran 47-48 on C12). But that is also stroked to get the 469....and cammed, and ported with o/s valves, and carbed and piped.......
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 02-11-2013, 11:25 AM   #17384
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,030
There's an o-ring/gasket sitting between the casing (of w/p) and engine if there's where the leak u might only need a gasket part # :
17435-29F00 $8.32
Old 02-11-2013, 11:27 AM   #17385
bobfab
bobfab's Avatar
Oddometer: 1,499
Thanks, thats what i was looking for!
CRF250L | KTM200SX
Times are GMT -7.   It's 07:19 AM.
