Old 02-12-2013, 12:48 PM   #17401
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,362
Originally Posted by DualSportDad View Post
If it's leaking it is probably just the o ring around the seat.
Yep, my thoughts exactly.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 02-12-2013, 02:52 PM   #17402
singletrak
singletrak's Avatar
Oddometer: 73
What would you pay for a low mileage (less than 1000 miles), non running 2004 DRZ400s? Probably needs a carb cleaning and a battery. Bike is all stock and has not been run since 2006? $1000 to $1500?
Singletrak
singletrak is offline   Reply With Quote
Old 02-12-2013, 03:37 PM   #17403
streetndirt
streetndirt's Avatar
Oddometer: 122
I gave $3000 for a 2006 DRZ400s with 400 miles in January 2013. Battery was good but I had to clean the carb. I felt that was a good enough price.
Sent from Samsung Galaxy S2
streetndirt is offline   Reply With Quote
Old 02-12-2013, 05:18 PM   #17404
Wlfman
Wlfman's Avatar
Oddometer: 1,295
Singletrak
I paid $2000 for my 04 back in June. Stock except bars. 8600 miles. And it runs fine.
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 02-12-2013, 05:49 PM   #17405
DualSportDad
DualSportDad's Avatar
Oddometer: 2,455
I got the pack of o rings from discount auto. The brand was doorman... it was a assorted pack of viton o rings for like $10. Sucks to pay $10 for 1 o ring but I guess I different sizes of I ever need them. If I remember correctly the size needed was 8mmx1.5mm.
When you try to remove the seat from the carb body be sure to only grab the out side of the seat area. If you even slightly Nick the inside of the seat area the needle assembly will get hung up on it. I found that out the hard way.
Sent from my Galaxy Note 2 using tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 02-12-2013, 08:13 PM   #17406
markjenn
Oddometer: 10,473
I'd jumper it and make sure it turns over strongly with good compression and no bad noises. Assuming nothing else is wrong, it's easily worth $1500, and probably considerably more.
- Mark
Old 02-12-2013, 11:16 PM   #17407
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,054
Originally Posted by blaster11 View Post
I am starting my Trailtech Vapor install and was wondering how you guys installed the magnetic pickup on your bike,
I haven't start with it yet but i have an idea of how to install it now, i got this youtube vid it shows u how to install the magnet bolt on wheel the mount wheel sensor to brake caliper.
http://www.youtube.com/watch?v=K-lpI2-jDxw
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is online now   Reply With Quote
Old 02-13-2013, 03:02 AM   #17408
Gadget678
Gadget678's Avatar
Oddometer: 1,206
I am starting my Trailtech Vapor install and was wondering how you guys installed the magnetic pickup on your bike, no sense in reinventing the wheel so to speak. Looking for pictures of the sensor down on the wheel.
Sorry for the delay.... it took me a while to find the pics:
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 02-13-2013, 06:12 AM   #17409
Plane Dr
Plane Dr's Avatar
Oddometer: 888
Originally Posted by DR650SEDDY View Post
i was trying to figure this out myself last nite but i got too tired , if anything i'll wait till my neighbour cross the street get back in town he's got the same bike and device. He told me to wait he'll help me out on that. If i only can peak into his bike quickly . i'll post up a pix soon as i get it done.
I took a small piece of Aluminium. Notched it for a hose clamp. Then made a countersink for the fastener. The hose clamp (band clamp? Runs between the block and the sensor and wraps around the fork.
This way both sets of wheels have the magnet mounted the same distance from the axle rather than having the location based on the caliper. Which changes with the wheels.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 02-13-2013, 07:19 AM   #17410
Achtung
Wicked Pisssah Adventurer
Achtung's Avatar
Oddometer: 999
Singletrak
That'd be a very fair price and typically your only looking at a carb clean and a battery but I worked on one once that needed a top end after sitting too long. There was corrosion on the piston and the rings were stuck. Not trying to scare you but realize you are taking a risk, albeit at that price not a very big one. Good luck.
Achtung is offline   Reply With Quote
Old 02-13-2013, 07:35 AM   #17411
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
[QUOTE=DualSportDad;20711892]I got the pack of o rings from discount auto. The brand was doorman... it was a assorted pack of viton o rings for like $10. Sucks to pay $10 for 1 o ring but I guess I different sizes of I ever need them. If I remember correctly the size needed was 8mmx1.5mm.
Sent from my Galaxy Note 2 using tapatalk 2[/QUOT
Keintech sells the proper seat O-rings for .50 ea .
buls4evr is offline   Reply With Quote
Old 02-13-2013, 07:58 AM   #17412
Wlfman
Wlfman's Avatar
Oddometer: 1,295
Anyone have a right passenger peg bracket they don't want? I'm looking for one to cut up for the section the exhaust mounts to.
Old 02-13-2013, 09:18 AM   #17413
DualSportDad
Oddometer: 2,455
[QUOTE=buls4evr;20715594]
Viton?
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
Old 02-13-2013, 09:55 AM   #17414
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,054
Thanks Gadget, does the magnet goes on one of the allen bolt that hold the rotor ?? (like vid i posted earlier).
Old 02-13-2013, 10:44 AM   #17415
blaster11
Where to go......
blaster11's Avatar
Oddometer: 7,143
Thanks Gadget...that's exactly what I needed! No worries on the delay since I got a head cold and don't feel much like working on the bike anyways.
blaster11 is offline   Reply With Quote
Times are GMT -7.   It's 07:27 PM.
