Old 01-10-2013, 12:55 PM   #17521
ohgood
ohgood's Avatar
Oddometer: 800
Originally Posted by TIGERRIDER007 View Post
DRZ owners, a quick question: when did they upgrade the DRZ? Is there a big difference between a 2001 and a 2006?
I was checking into a 2001, but don't want to get an older model if it's not worth it...
thanks for the information!
Very little changed from first to 2013.
Crazy_Dave just made it into my sigline, and I agree: I fall down alot.
ohgood is offline   Reply With Quote
Old 01-10-2013, 01:25 PM   #17522
BygDaddee
Ex: RideWithMe
BygDaddee's Avatar
Oddometer: 547
Just search around the Cam Chain Tensioner, it's really the only major improvement to fix an early issue but I can't remember the year.
George Carlin “Never argue with an idiot, they'll only bring you down to their level, then beat you with experience.”
I'm the slow guy on the 2013 KTM 690 Enduro R, please toot as you go past
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 01-10-2013, 02:02 PM   #17523
ptgarcia
Huh?
ptgarcia's Avatar
Oddometer: 508
The suspension on the S model was upgraded in 2002.
Pauly
'06 DR-Z400S
ptgarcia is offline   Reply With Quote
Old 01-10-2013, 04:15 PM   #17524
Piet93
Oddometer: 3
Thumb
Hello, Im piet and im new to this awesome website
Afther a couple dirtbike's RM125, CR250 and a RMZ 250 i bouth my first road legal bike.
2001 DR-Z 400S, original, but has brand new dirt tires one it.
Has no speedometer, and 2 blinkers are broken. technical in good shape, and still has original plastic on it.
Want to make it a real offroad bike, but stil use it one the road to.
i just got the bike, and have to make it ready for safety inspection.
Bike got now 15/41 sprokets, and i dont like it at all. its not powerfull, and i feel sorry for the clutch...
I got another set with the bike, 14/44 and i probely try that.
I dont like the stock tail light and blinkers at all, and probely go for the edge 2 tail light and some led blinkers.
any one use the edge tail light offroad?? no mud flying up your back?
and for speedo i probely go for the vapor trail tech, but i heard that the are not realy waterproof. any one using it all year arround??
oh im from ontario canada, any one know's a good online store?
Piet
Piet93 is offline   Reply With Quote
Old 01-10-2013, 04:58 PM   #17525
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,209
Piet
Welcome, i'll try 15/47 first it's great for both. Vapor tech are cheap on ebay,
TRAIL TECH VAPOR TACH TACHOMETER SUZUKI DRZ400 2000-10
DR-Z400E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is online now   Reply With Quote
Old 01-10-2013, 05:13 PM   #17526
Piet93
Oddometer: 3
47 / 15 = 3.13333
44 / 14 = 3.14285
Thats pritty much the same, so home that works for me!
yea i like the vapor tech, but i heard that the are not good in rain/ water.
Probely get the speed pickup thing out the wheel?? i dont know if you can get something for that tho..
Old 01-10-2013, 05:14 PM   #17527
150ron
150ron's Avatar
Oddometer: 873
Bullet key
New front fender
before
after
difference between em
Just some dude...
150ron is offline   Reply With Quote
Old 01-10-2013, 06:34 PM   #17528
955616846
Oddometer: 1,726
There's that filthy bike back in the shed again.
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800, 13 FXST
Founding member Longtails SC
My Bike Pages
955616846 is online now   Reply With Quote
Old 01-10-2013, 09:09 PM   #17529
Adrian V
Oddometer: 438
Springs.....
Muddler and Numbers, thanks for the replies on suggested spring rates. Muddler, I'll have a look at the procycle calculator, but I'm thinking 050/5.7 might be the best compromise for me.
I'll check out the Bremer rider, I think I still have the details for soex somewhere. You going on the Israelite Easter run?
Cheers,
Adrian
Adrian V is offline   Reply With Quote
Old 01-10-2013, 09:54 PM   #17530
Gadget678
Gadget678's Avatar
Oddometer: 793
and for speedo i probely go for the vapor trail tech, but i heard that the are not realy waterproof. any one using it all year arround?? Piet
I've used the Trailtech Vector for years now........ never any problems with water.
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 01-11-2013, 01:12 AM   #17531
Tropic-Of-Canada
pining 4 the fjords?
Tropic-Of-Canada's Avatar
Oddometer: 556
Well, My newest farkle aint pretty, but so far, it seems to be working!
I've been having real problems with my 04 S (36000Kms) dying in the cold after start up, and upon stopping on a highway light up to 15 minutes after starting.....The rain makes it worse as well.....
It's becoming a bit of a pain when trying to leave work at midnight in January in -2C, so I did what I've seen done to many cars and trucks around northern BC, and I put cardboard in front of my radiators!!! I attatched it to the stock "guards".
Didn't die stopping at the light tonight, so if I notice it helps enough, I might make something a little better out of plastic or aluminum.. I'll keep an eye on the fan to see if it comes on, but I have my doubts it will, since It still gets airflow at the ends, and one side is still exposed.
Tropic-Of-Canada screwed with this post 01-11-2013 at 02:18 AM
Tropic-Of-Canada is offline   Reply With Quote
Old 01-11-2013, 02:18 AM   #17532
Gadget678
Gadget678's Avatar
Oddometer: 793
Didn't die stopping at the light tonight, so if I notice it helps well enough, I might make something a little better out of plastic. I'll keep an eye on the fan to see if it comes on, but I have my doubts it will.
If you do cover the radiators, one of these might keep your mind at ease: (Copied from the Trailtech website)
  • Engine, water, or air temperature
  • Sensor options for all standard radiator hoses, oil lines and spark plugs
  • User selectable display: 30-500°F or 0-260°C
  • Measures current and maximum temperature, resettable
  • Spinning-arrow activity icon
  • Flashing dot indicates 6 second sample rate
  • Peel-n-Stick or Bolt-on
Old 01-11-2013, 02:51 AM   #17533
ThumperDRZ
Bouncing off Rocks!
ThumperDRZ's Avatar
Oddometer: 2,394
Cam chain tensioner was upgraded in 2003
Buy a manual CCT or one from a 2003 and up.
Suspension was upgraded in 2002 as mentioned.
There are also torque value changes but other than that it's been the "Bold New Graphics"
Make sure you go on Thumpertalk to learn all of the tricks on a DRZ. Main thing is to check that front sprocket nut. These must be installed with red loctite or they come loose. Then the oil seal behind them will weep.
"If you're going through hell.......Keep going!"
On Hiatus
ThumperDRZ is offline   Reply With Quote
Old 01-11-2013, 05:20 AM   #17534
Muddler
Muddler's Avatar
Oddometer: 539
Cheers,
Adrian
I did Israelite last summer with Dennis. Great trip, but I have to save my Annual Leave for the Anne Beadell Hwy in June. PM me if you need the Bremer info.
Good luck with the springs
Cheers
Rob
Muddler is offline   Reply With Quote
Old 01-11-2013, 09:52 AM   #17535
Plane Dr
Plane Dr's Avatar
Oddometer: 720
Your problem is carb icing. You are running a BSR.
You need item 63and 64
https://www.thumpertalk.com/shop/oem...004&model=5310
Well known problem with the S in those conditions. Some countries the parts are stock (delivered installed). When I lived in Abbotsford it was a real problem. I never did do the fix though as I moved after the second winter.
I don't recommend covering the rads. It helps but it doesn't actually fix the problem. The vapour is nice but again you aren't really fixing the problem. If you go to TT thee are several threads on it from 5-6 years ago. Last I checked the parts were <$100
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Times are GMT -7.   It's 12:48 AM.
