02-12-2013, 12:48 PM
#17956 |
Purveyor of Light
Oddometer: 3,646
Yep, my thoughts exactly.
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
02-12-2013, 02:52 PM
#17957 |
Oddometer: 49
What would you pay for a low mileage (less than 1000 miles), non running 2004 DRZ400s? Probably needs a carb cleaning and a battery. Bike is all stock and has not been run since 2006? $1000 to $1500?
Singletrak |
02-12-2013, 03:37 PM
#17958 |
Oddometer: 122
I gave $3000 for a 2006 DRZ400s with 400 miles in January 2013. Battery was good but I had to clean the carb. I felt that was a good enough price.
Sent from Samsung Galaxy S2 |
02-12-2013, 05:18 PM
#17959 |
Oddometer: 869
I paid $2000 for my 04 back in June. Stock except bars. 8600 miles. And it runs fine.
Those who say it cannot be done should not interrupt the people who are doing it." "Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY." |
02-12-2013, 05:49 PM
#17960 |
Oddometer: 2,113
I got the pack of o rings from discount auto. The brand was doorman... it was a assorted pack of viton o rings for like $10. Sucks to pay $10 for 1 o ring but I guess I different sizes of I ever need them. If I remember correctly the size needed was 8mmx1.5mm.
When you try to remove the seat from the carb body be sure to only grab the out side of the seat area. If you even slightly Nick the inside of the seat area the needle assembly will get hung up on it. I found that out the hard way. Sent from my Galaxy Note 2 using tapatalk 2
Alex Cape Coral, Fl. 2003 KLX400R tagged
02-12-2013, 08:13 PM
#17961 |
Oddometer: 9,698
02-12-2013, 11:16 PM
#17962 | |
ride2discover
Oddometer: 3,169
http://www.youtube.com/watch?v=K-lpI2-jDxw
DR-Z400E 00 - DR650SE 02. Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY". |
02-13-2013, 03:02 AM
#17963 | |
Oddometer: 770
Have you ever noticed that when you're out on the bike, nothing else matters? http://www.advrider.com/forums/showthread.php?t=709292 |
02-13-2013, 06:12 AM
#17964 | |
Oddometer: 708
This way both sets of wheels have the magnet mounted the same distance from the axle rather than having the location based on the caliper. Which changes with the wheels.
01/09 DRZ470SSW more bits than necesary 2005 R1200 GS AKA The Mothership 2003 Z1000 Nuclear Pumpkin (gone) 86 RG500WW (gone) Bikes are like women. What you think you want, and what you want, change after the first ride. |
02-13-2013, 07:14 AM
#17965 |
Oddometer: 1,690
Why? Big disk and caliper set up are a pair. Small disk and caliper are a pair. Stick sensor in its intended spot on the caliper and the magnet where it needs to be on each of the disks...
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC 955616846 screwed with this post 02-13-2013 at 07:42 AM |
02-13-2013, 07:19 AM
#17966 |
Wicked Pisssah Adventurer
Oddometer: 809
That'd be a very fair price and typically your only looking at a carb clean and a battery but I worked on one once that needed a top end after sitting too long. There was corrosion on the piston and the rings were stuck. Not trying to scare you but realize you are taking a risk, albeit at that price not a very big one. Good luck.
We wanna be free... free to ride our machines without being hassled by the man... and we wanna get loaded... yeah! |
02-13-2013, 07:35 AM
#17967 |
No Marks....
Oddometer: 1,610
[QUOTE=DualSportDad;20711892]I got the pack of o rings from discount auto. The brand was doorman... it was a assorted pack of viton o rings for like $10. Sucks to pay $10 for 1 o ring but I guess I different sizes of I ever need them. If I remember correctly the size needed was 8mmx1.5mm.
When you try to remove the seat from the carb body be sure to only grab the out side of the seat area. If you even slightly Nick the inside of the seat area the needle assembly will get hung up on it. I found that out the hard way. Sent from my Galaxy Note 2 using tapatalk 2[/QUOT Keintech sells the proper seat O-rings for .50 ea . |
02-13-2013, 07:58 AM
#17968 |
Oddometer: 869
Anyone have a right passenger peg bracket they don't want? I'm looking for one to cut up for the section the exhaust mounts to.
02-13-2013, 09:18 AM
#17969 | |
Oddometer: 2,113
[QUOTE=buls4evr;20715594]
02-13-2013, 09:55 AM
#17970 |
ride2discover
Oddometer: 3,169
Thanks Gadget, does the magnet goes on one of the allen bolt that hold the rotor ?? (like vid i posted earlier).
