Old 02-13-2013, 10:44 AM   #17971
blaster11
Are you a Sheeple?
blaster11's Avatar
Oddometer: 4,689
Send a message via Skype™ to blaster11
Originally Posted by Gadget678 View Post
Sorry for the delay.... it took me a while to find the pics:
Thanks Gadget...that's exactly what I needed! No worries on the delay since I got a head cold and don't feel much like working on the bike anyways.
Bruce
IBA # 46755
Adventures of Blaster and Dorito
blaster11 is online now   Reply With Quote
Old 02-13-2013, 11:43 AM   #17972
Gadget678
Gadget678's Avatar
Oddometer: 777
Originally Posted by DR650SEDDY View Post
Thanks Gadget, does the magnet goes on one of the allen bolt that hold the rotor ?? (like vid i posted earlier).
Yep. I used the bolt in magnet (replaces a disc rotor bolt)... I didn't trust glue to hold a magnet in place.
You might notice that I've rounded off the lower - outer edges of the sensor to get it all to fit better and pick up the magnet in my preferred location.
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 02-13-2013, 02:53 PM   #17973
Plane Dr
Plane Dr's Avatar
Oddometer: 712
Originally Posted by 955616846 View Post
Why? Big disk and caliper set up are a pair. Small disk and caliper are a pair. Stick sensor in its intended spot on the caliper and the magnet where it needs to be on each of the disks...
Didn't have a good spot on the other disk. Or couldn't find a "sweet spot" on both. I'm not running conventional SM rims so it was a little more complicated. One less thing as well when I change wheel sets. Just a brake line and spacer. Since I also run KTM guards no fiddling required.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 02-13-2013, 04:53 PM   #17974
Dirtnadvil
Dirtnadvil's Avatar
Oddometer: 718
Anyone here using an RM front rim
If you are, did you use a custom spacer or did you leave the speedo spacer/ pick up on. Thanks
Dirtnadvil is offline   Reply With Quote
Old 02-13-2013, 07:55 PM   #17975
SKINZ
Geo Steve
SKINZ's Avatar
Oddometer: 11
Never thought I would want winter to last longer, but people change.
SKINZ is offline   Reply With Quote
Old 02-13-2013, 08:55 PM   #17976
Bobby Ginger
Unicorn Wrangler
Bobby Ginger's Avatar
Oddometer: 216
Bike maintenance and luggage question
Attempted my first tire change on a motorcycle tonight. Things went well, lots of goggling and a few beers. Almost had my tire reinstalled when I realized the PO removed the bead lock? I am assuming he used on the road only so did not worry about it. A quick trip to the dealer tomorrow will take of it, so no worries.
I am preparing for a rally ride next month and I need advice on a bag. I will be traveling light so nothing too big. I just want it to fit on the factory rack, and be able to carry a change of clothes, a few tools, and toiletries. Anybody have similar need and knows what I should get? Input appreciated
Forget it, drive on.
2009 GSA 2008 Husky TE450
2007 Ducati GT1000 Sold 2005 DRZ 400 Sold
IBA 50407
Bobby Ginger is offline   Reply With Quote
Old 02-13-2013, 09:35 PM   #17977
955616846
Oddometer: 1,692
The bead lock was never standard on the DR-Z.
A Kriega or Wolfman tail pack... or something like a 18-20L Lowe Alpine day pack for a quick overnighter.
http://www.lowealpine.com/eng/produc...id=13&type=man
I've got a Kriega tail pack which is normally full of tools and spares. I have used the 28L Air Zone close to home.
http://www.kriega.com.au/tail-packs/us-10-tailpack
http://www.kriega.com.au/tail-packs/us-20-tailpack
http://www.lowealpine.com/eng/produc...id=11&type=man
I use these brands because they're convenient... there are probably a hundred other choices, but these should give you an idea
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800
Founding member Longtails SC
955616846 is offline   Reply With Quote
Old 02-13-2013, 09:51 PM   #17978
Bobby Ginger
Unicorn Wrangler
Oddometer: 216
Nice! Thanks for the info. I was curious when a dry rotted piece of rubber came out that I would assume would wrap around the bead lock. Serious tire noob so, I am guessing.
IBA 50407
Old 02-14-2013, 05:01 AM   #17979
Plane Dr
Plane Dr's Avatar
Oddometer: 712
Which Lake? it ain't Chestemere. Only time I ever tried that was the num bum and it was awesome. Ice racing isn't big here so now I could manage it I can't.
86 RG500WW (gone)
Old 02-14-2013, 04:23 PM   #17980
SKINZ
Geo Steve
SKINZ's Avatar
Oddometer: 11
This is Ghost Lake just west of Calgary. Some friends made a quick video of their ice time out there.
http://youtu.be/BiKzEFGY7wk
It's a blast
Old 02-14-2013, 05:23 PM   #17981
DRDeano
Oddometer: 20
Does anyone know for certain whether a rear sub frame off an 'S' will fit on an 'E'? I have an 'E' and would like to get some pillion pegs so the wife can hop on the back and keep her happy.
Failing that does anyone have any other work arounds?
If it does work, does anyone have a rear frame with pegs they would like to part with?
Sent from my GT-I9100T using Tapatalk 2
DRDeano is online now   Reply With Quote
Old 02-14-2013, 05:31 PM   #17982
Bobby Ginger
Unicorn Wrangler
Oddometer: 216
tire change rear wheel assembly
Guys, another noob question here. Putting the rear tire back on and I am lost on the chain adjustment. I think i have to do something with the tear drop/half moon/numbered pieces but I really am lost. Searched youtube tt and here. May not be looking for the right thing, but I really want to get this project finished up. A point in the right direction would be much appreciated.
IBA 50407
Old 02-14-2013, 05:45 PM   #17983
Wlfman
Wlfman's Avatar
Oddometer: 869
Owners Manual pages 68-70
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 02-14-2013, 05:48 PM   #17984
Bobby Ginger
Unicorn Wrangler
Oddometer: 216
If i only had one of those
Bought a Clymers, no worries :)
IBA 50407
Bobby Ginger screwed with this post 02-14-2013 at 05:55 PM
Old 02-14-2013, 05:52 PM   #17985
Wlfman
Wlfman's Avatar
Oddometer: 869
here ya go:
1 is place motorcycle on side stand
Times are GMT -7.   It's 03:04 AM.
