Old 03-30-2013, 12:02 PM   #18031
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,686
Originally Posted by AKoffroader View Post
I have an '08 WR250R and a '08 DR650SE.
I like both bikes for what they are but the DRZ has me curious. What I'd like to have in the WRR is more low end pull. What I'd like to have in the DR650 is less weight.
How does the DRZ compare as an "in between solution" compared to the WRR and DR650?
I'd like to get down to one DS bike plus my S Tenere for two up.
Thank you,
AK Greg
I think you'd be extremely happy with the DRZ as a nice blend of the two. Try to find someone on your local regional thread with a Drz and ask if you can take take theirs for a spin. I think you'll love it.
Falcon86 is offline   Reply With Quote
Old 03-30-2013, 03:42 PM   #18032
mineolaman
Adventurer Wannabe
mineolaman's Avatar
Oddometer: 61
Punished?
Originally Posted by savedzrex View Post
Great looking bike......... Congrats
Are you mad at her already? She's got her nose in corner like she's being punished. lol
mineolaman is offline   Reply With Quote
Old 03-30-2013, 07:23 PM   #18033
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Originally Posted by Muddler View Post
. Ok, I'm stupid. What's with the smoke joke??
Check out post #18615
Its kid of a British bike thing
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 03-31-2013, 06:22 AM   #18034
Lat
Lat's Avatar
Oddometer: 114
You are on the right path!
Thank you,
AK Greg
If you only had one bike, the 650 size would be the way to go, imo. The fact you have a "land yacht" for your two up riding and fire roads, it should be easier to narrow your choice down to the WRR and a DRZ. If your budget is not limited, you might want to consider some of the six speed choices too.
My GS1200 is getting lots of rest these days. Had everythang to do with picking up the DRZ recently. Let us know how your shopping goes, Greg. ~Jeff
______________
'05 R1200GS
'04 DR Z400S
Ride For Kids
Lat screwed with this post 03-31-2013 at 12:38 PM
Lat is offline   Reply With Quote
Old 03-31-2013, 07:02 AM   #18035
TypeSH
Oddometer: 167
If you aren't happy with the power delivery on the WR you probably won't like the DRZ much more as they both make their power with revs. Removing some weight on your DR and working on its suspension is what I would do.
TypeSH is offline   Reply With Quote
Old 03-31-2013, 07:14 AM   #18036
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,716
I was under the assumption that the WRR was quite a bit more "peaky" than the DRZ... I don't need to wring the DRZ's neck at all to go fast. In fact, I regularly short shift on gravel to keep traction on my way to 60mph.
When I was looking for a true Dual Sport, I considered the 250's, the DR and the DRZ. Really glad I got the DRZ. I have ridden a DR, and it seemed big and lazy to me. I think I'm too big for a 250
GRAVEL WORLDS
'14 KTM ADV R - '06 DRZ 400 - lot's of bicycles
fifthcircle is offline   Reply With Quote
Old 03-31-2013, 07:59 AM   #18037
gkgeiger
Every ride is an ADV
gkgeiger's Avatar
Oddometer: 661
Just in case you guys haven't seen this.
http://www.advrider.com/forums/showthread.php?t=871633
Getting old is not for Sissy's!
Gene
'14 R1200GSW
'12 NC700X/D
gkgeiger is offline   Reply With Quote
Old 03-31-2013, 11:30 AM   #18038
rube
Oddometer: 95
drz400e header on a drz400s
Hi,
I have a drz400s. I wanted to mount a drz400e header to the bike. I had read that the -e model header was a larger diameter and gave a little more power.
After searching here and thumperalk I started looking for a header. I bought an -e header, -e clamp, and -e exhaust gasket from someone on the forum.
What I read indicated that the way to do this was to expand the inlet on the -s model muffler to accept the larger diameter -e model header. Folks posted that you could not use the -e model muffler because of the -s model passenger foot peg mount being in a different spot on the -e model without a passenger foot peg.
Most posts said that the best way to get the -e header to fit into the -s muffler was to take the -s muffler to an exhaust shop and have them expand the muffler inlet. I tried to do it myself with a tool from Autozone. Using my impact wrench I broke the expanding tool without expanding the inlet at all!
Then I tried fitting all the exhaust pipe and adaptors they had at Autozone to see if I could find a piece of pipe there which would work. I found that the inside diameter of 2"OD exhaust pipe fit very nicely over the -e model header exhaust gasket. The same tubing fit nicely over the factory weld bead on the -s model muffler.
I ended up cutting a section from a 1 7/8"IDx2"OD exhaust adapter to get a short section of tubing of 2"OD. I used a saw to make 4 cuts in this pipe for the exhaust clamp to be able to tighten on. Then I cut the "clamping fingers" off of the -s model pipe to get the length right. I welded the adaptor piece of 2"OD pipe to the -s model exhaust.
It fits up nicely and the stock heat shield mounts right up.
So, this may be an option to consider to the usual expanding the -s model muffler inlet when mounting an -e model header to a drz400s.
rube
rube screwed with this post 03-31-2013 at 11:31 AM Reason: spelling
rube is offline   Reply With Quote
Old 03-31-2013, 01:14 PM   #18039
tdrrally
tdrrally's Avatar
Oddometer: 3,420
i think the drz400 has better lowend than the wr
the 400 is good middle ground .
but the 650 with the 400 suspension would be a good direction too
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is online now   Reply With Quote
Old 03-31-2013, 01:53 PM   #18040
blaster11
Heading North!
blaster11's Avatar
Oddometer: 7,045
Tank bag?
So are any of you guys with a Clarke tank running a tank bag, if so what bag? Pictures appreciated.
blaster11 is offline   Reply With Quote
Old 03-31-2013, 02:42 PM   #18041
gkgeiger
gkgeiger's Avatar
Oddometer: 661
Gene
'14 R1200GSW
'12 NC700X/D
Old 03-31-2013, 02:49 PM   #18042
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,030
I have the 4.5 IMS (if u switch to ims tank) these atv bags provides a lot of carry space. U can get them on ebay, cheap.
They wrap around the tank providing extra protection to your knees.
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY screwed with this post 03-31-2013 at 02:55 PM
DR650SEDDY is offline   Reply With Quote
Old 03-31-2013, 02:53 PM   #18043
blaster11
Heading North!
blaster11's Avatar
Oddometer: 7,045
Originally Posted by gkgeiger View Post
Is that the small Enduro bag?
Old 03-31-2013, 02:55 PM   #18044
blaster11
Heading North!
blaster11's Avatar
Oddometer: 7,045
Which bag is that over the headlight?
Old 03-31-2013, 03:17 PM   #18045
gkgeiger
gkgeiger's Avatar
Oddometer: 661
Yes
Gene
'14 R1200GSW
'12 NC700X/D
Times are GMT -7.   It's 07:40 AM.
