Old 04-08-2013, 06:45 PM   #18196
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Originally Posted by SloDon View Post
Yes mine did that also.......had a little over 10 thousand miles on them. The seals looked good so I bought aftermarket spacers from Rocky Mtn ATV.
Next tire change the barings were dry, grease look good, so, I figure they are a wear item and check them now more often. As long as your seals look OK and are keeping water out, you should be fine.
BTW then front wears like that also.....
OK thanks
Am putting new seals and bearings in, will get new spacers ASAP and put them in when they get here
OH and only 5500 Kilometres on the clock, but I ride hard
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 04-08-2013, 06:53 PM   #18197
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 846
Originally Posted by The Recycled Teenager View Post
OK thanks
Yep, fairly common, that's why a lot of the bearing kits come with replacement spacers. Nothing to be concerned with.
Starchamp is offline   Reply With Quote
Old 04-08-2013, 06:57 PM   #18198
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 868
sorry to interrupt tire discussion
If you had a choice to buy, either a street legal E or a stock S which one would it be and why?
What would make me choose the E, I guess is my question....
I'm looking for a smile giving off road machine by the way
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 04-08-2013, 06:59 PM   #18199
ohgood
ohgood's Avatar
Oddometer: 2,641
Originally Posted by marine_mike View Post
What is this "Magic" button you you speak of?
u made me lol when I read it over again.
ok, not the button so much, but wideopenthrottle + the starter= no more flood.
usually, it only takes 1-2 seconds, c lose throttle again and its vroooom time. :)
scrolling through the words to get to the pictures is cool, but i'm really just here for the tracks and waypoints... post some ok ?
ohgood is offline   Reply With Quote
Old 04-08-2013, 07:33 PM   #18200
ohgood
ohgood's Avatar
Oddometer: 2,641
the s has more subframe, so camping loads can be heavier.
the e has more power, and possibly not as adjustable suspension if its old enoguh
the e gets you instant nods of approval from people in the know.
the s is 50 state legal, the e questionable
otherwise, it all swaps, so who cares
Old 04-08-2013, 07:56 PM   #18201
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,912
Front & rear suspension are adjustable (Rebound/compress) I have a 2000 E
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 04-08-2013, 08:03 PM   #18202
LittleRedToyota
Yinzer
LittleRedToyota's Avatar
Oddometer: 2,232
unless you are going to be carrying really heavy loads, a real E without a doubt.
primarily because it weighs less.
secondarily, because it has an FCR instead of the mikuni carb.
LittleRedToyota is offline   Reply With Quote
Old 04-08-2013, 09:17 PM   #18203
Psycho18th
Oddometer: 383
I've ridden both off road, owning an E and riding a buddy's S. The throttle response, and off road manners were much better on the E. The weights can be evened out when you add a dual sport kit to the E, and take all the crap off the S. You can set up the suspension on either, though bone stock my E was much better/balanced/ dirt bike feeling than the S. The E FCR carb seemed to put out better/more instant throttle over all terrain, especially on slow on/off throttle scenarios and quick acceleration over obstacles. However, the S carb is supposed to get better mileage. The S has a subframe to accept a rack and passenger. If I was riding more dirt(which I am) I'd go with an E. If I were riding more street, and wanted to ride 2-up with some luggage, I'd go with an S. Just my less than informed opinion.
02 DRZ400E Dualsported in AZ
14 KTM 250 XCW (Plated in AZ)
85 HON XL80S (Wife's ride)
00 and '07 YAM TTR 90s (kids' bikes)
89 Lockheed F-16C (Work vehicle )
Psycho18th is offline   Reply With Quote
Old 04-08-2013, 10:05 PM   #18204
Jon B.
Oddometer: 581
Originally Posted by fifthcircle View Post
Thanks for posting that.... ( it's Tonn's Fabrication though )
I have been thinking about some of that stuff for my DRZ lately, and couldn't decide....until I saw their stuff. VERY NICE. Ordered it all! I'm a sucker for a free T-shirt
http://www.tonnsfabrication.com/drz.html
Free tee-shirt??? I've purchased two of their skid plates - no shirt for me!! Do they hate me?
Jon
Hey - if it ain't an adventure, it's just a ride!
'05 DRZ 400E Titled/Plated
Jon B. is offline   Reply With Quote
Old 04-09-2013, 01:28 AM   #18205
dante_alighieri
dante_alighieri's Avatar
Oddometer: 177
the exact size depends on what sizes are available in the tire I want. usually, though, i end up with a 120/100 on the back and either 100/80 or 90/90 on the front.
you can vary the size of the tires without a problem (as long as you don't get a rear tire so wide that it rubs on the chain).
(your tires/wheels are either out of balance or the mechanic screwed up putting your wheels back on the bike.)
Originally Posted by Gadget678 View Post
I also have the E-09's. Balanced with no dramas at any speed.
A few simple things to consider:
There's a difference between bounce & 'swinging'.... check that your rear axle is square & that they didn't stuff the allignment up when they tensioned the axle nut. What pressures did they put in them (some places will put them up to rediculous PSI to get the bead to pop, but not check it again.)
The swinging appears with the new front tyre, the rear Mitas was mounted a month ago and did his job ok with a front Trailwing.
The pressures are checked: 2 - 2.2...
The problem must be, ad you say, in the front tyre balance. I'll check itghead:
Thanks from Spain inmates!
F650GS on trail
DRZ400S so!
dante_alighieri is offline   Reply With Quote
Old 04-09-2013, 01:53 AM   #18206
Gadget678
Gadget678's Avatar
Oddometer: 1,175
They didn't put it on backwards did they? (Serious question- They're directional, but don't look it.)
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 04-09-2013, 06:05 AM   #18207
TIGERRIDER007
Oddometer: 868
Thanks for the information, I've got to sell my DR to take a shot at a street legal E...I'm just hesitant about all the aftermarket electronics on a bike, don't want the mess of having to deal with electric gremlins.
Scott
Old 04-09-2013, 06:11 AM   #18208
dante_alighieri
Oddometer: 177
Icm working on my DRZ for next week travel, and I put this to prevent burning bags.
But Im worried about corrosive effects...
I have seen some HD exhaust collectors broken under this tape, due to too much heat suposse...
using tapatalk!
F650GS on trail
DRZ400S so!
dante_alighieri screwed with this post 04-09-2013 at 07:26 AM
Old 04-09-2013, 07:03 AM   #18209
McGiverman
Oddometer: 2
Looking for a part
Hey guys..just finished my set of wheels from the thread creating the super retard but stuck on one part...and cant seem to locate it or the possible source. What I need is the front caliper relocation bracket. Otherwise all done and good..
Truely not a bad task.
Any sources or help out there. Just need one to button this thing up and ride...
McGiverman is offline   Reply With Quote
Old 04-09-2013, 07:09 AM   #18210
threadkiller
Semi-feral Pappy
threadkiller's Avatar
Oddometer: 1,781
My SR relocation bracket is homemade. The previous owner fabbed it. I can take pictures, but I don't have the stuff to get good measurements.
threadkiller is offline   Reply With Quote
Times are GMT -7.   It's 09:20 AM.
