Old 04-12-2013, 07:22 PM   #18286
iconman
Good vibrations
iconman's Avatar
Oddometer: 1,057
Originally Posted by TIGERRIDER007 View Post
Between trying to buy a used S or SM, my big hang-up is being afraid that the SM with dirt wheels wont handle aggressive off road....
Help!!!
I bought an E then got a set of motard wheels made up from my local Suzuki dealer. The E is great off-road but I will need to get the suspension sorted a bit more for this type of riding. I use the bike in motard mode in summer as a commuter - its a great road bike, very light etc... I have a mate who has an S model and I couldn't spot the differences at first glance and I haven't ridden it yet.
Cheers, Richard.
13 KTM EXC 300 Ring-a-ding-ding!
09 DRZ 400 E Gone to a new home
05 KTM 640 Adventure Gone but not forgotten
03 Honda CT110 'Postie' Abducted by an alien
98 Suzuki DS 80 Gone to a new home
iconman is offline   Reply With Quote
Old 04-12-2013, 08:10 PM   #18287
mineolaman
Adventurer Wannabe
mineolaman's Avatar
Oddometer: 61
tires
Originally Posted by LittleRedToyota View Post
agreed 100% for the rear.
the rear TM II is the best DOT knobby there is in the dirt, imho.
but it rounds off in about 50 miles on pavement...and the knobs completely disappear not too long thereafter.
i found the front TM II to be an even worse dirt tire than the 606 front, though, myself. washes out like crazy.
the front uses the same tread pattern as the rear...it's an awesome tread pattern for a rear tire (for getting good front-to-back traction), but makes no sense at all for a front tire (where you need more side-to-side traction).
imho, the best dirt DOT pairing is a TMII in the back and an XCMH in the front. only problem is that if you ride on the road much, the TMII will not last long at all.
Kenda K270. They are great in rock, loose rock, and wear great on the road. You won't be disappointed.
mineolaman is offline   Reply With Quote
Old 04-12-2013, 08:13 PM   #18288
Rwelch360
Oddometer: 336
Thanks for the reply. Sorry I didn't see this sooner. Been really busy with work/school. Do you have any experience with this product? Thanks again for the reply
Rwelch360 is offline   Reply With Quote
Old 04-12-2013, 08:18 PM   #18289
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 1,006
Thanks, I'm leaning toward the bike that will perform off road best. But the SM is really tempting me...
Cheers, Richard.
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 04-12-2013, 08:19 PM   #18290
Rwelch360
Oddometer: 336
Originally Posted by ADVGD View Post
Very common, the taller you are the more uncomfortable stock DRZ400 bar positioning is for adventure riding/standing up. Installing a new bar with the right bend to suit riders height/riding style is my preference, this avoids having to use bolt on raisers which can look scrappy. Scotts Performance do a very nice triple clamp assembly for the DRZ400, you can then run fat bars and even more options open up for bar bends (Renthal, Pro Taper, etc), plus they look fricken sweet
This is my setup with Scotts SUB Stablizer, Scotts Triple Clamps and Renthal fat bars (Details and links here )
If your clutch plates and fibers are in good nick and your clutch is adjusted correctly then you should be able to disengage a DRZ400 clutch with 2 fingers and not crush your other fingers. You'll most likely find correctly setting your free play will cure this issue
Thank you for that reply. I like your set up. I should look into that. Do you need to replace the whole triple, or do you just buy a top clamp? I want to avoid using any kind of riser. I was thinking of some CR high bend bars. I tightened up my clutch free play a little bit because my shifting was really notchy at times and would stop in neutral a lot instead of going to 2nd, since then it seems to be a bit better.
Old 04-12-2013, 08:21 PM   #18291
mminob
mminob's Avatar
Oddometer: 127
Sportsman Class Motard...
Help!!!
I have raced at supermoto tracks with DRZ400 SM'S and DRZ400S models and this crazy fast dude on a 400 S...with a sportsman set up...21"x18" Avon Gripster tires and a big front rotor was faster than anybody that day I just spooned on a set of Shinko 705's on my 09 S and they stick to pavement pretty good.... only takes about 1 hour to swap to my Dunlop knobbys if out at Ocotillo Wells...Fun little bikes...
2014 NC700X...Purrs like a kitty cat...2001 DRZ400E...Cheap Thrills.
mminob is offline   Reply With Quote
Old 04-12-2013, 09:04 PM   #18292
focallength
You're Welcome
focallength's Avatar
Oddometer: 5,011
ASVs are top shelf, yes theyre expensive, but theyll never break. After you snap 6 or 7 cheap levers, you would have already paid for a set. Plus you dont have to carry spare levers, pay now or pay later.
focallength is online now   Reply With Quote
Old 04-12-2013, 10:24 PM   #18293
iconman
Good vibrations
iconman's Avatar
Oddometer: 1,057
Just bought a set. Cheers.
Old 04-12-2013, 10:33 PM   #18294
RMOTO
Doing secret stuff
RMOTO's Avatar
Oddometer: 347
My DRZ400 tank was suffering from some war wounds, a little intervention required…
Full article here: Fuel Tank Protectors
www.RemoteMoto.com
RMOTO is online now   Reply With Quote
Old 04-13-2013, 05:51 AM   #18295
TIGERRIDER007
Oddometer: 1,006
So, I guess an S will do...eh?
How fun is an SM off road though, with off road wheels?
Scott
Old 04-13-2013, 06:56 AM   #18296
150ron
150ron's Avatar
Oddometer: 1,415
Theres a few long threads on TT that cover the SM off roading, jumping, dirt wheels and all that stuff, lots of good info there.
If you are vertically challanged, id get the SM, here is my S with a SM
Im only 5'9, so on the SM i can flat foot, which i really liked, bike seemed way lighter too, because all the weight is lower, i do some pretty hard trails over here, so i enjoy the bigger wheels, but the SM model with shinko 244's front and rear, is also very capable on the dirt,
how tall are you?
The SM with 50/50 tires such as the kendas or shinkos, can pretty much handle anything off road, as long as the rider can ride, ive seen some great off roading vids.
Just some dude...
150ron is offline   Reply With Quote
Old 04-13-2013, 07:04 AM   #18297
TIGERRIDER007
Oddometer: 1,006
I ride a Tiger and enjoy the height of it, can see over cars etc...
I'm 6 1 and really want a bike that is fairly high, especially with good suspension for the occasional catching air opportunities...
From your pictures the S looks a tad taller...I'm really wanting an SM and then get a set of wheels with knobbies...BUT I'm finding the prices are just a tad higher for the SMs.
Maybe I should check out some SMs off road via youtube...
Scott
Old 04-13-2013, 09:37 AM   #18298
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 367
Air/fuel mixture help Immediately
Hey all,
So, I hauled my 2012 DRZ400 up to Big Bear Lake (altitude 6,300 ft) and tried to fire it up this morning. After engaging the choke, it fired right up, ran for about a minute, then stalled. I had a really hard time getting it going again. Every time I got it fired, same thing, run for a little bit, then stall out. Fuel if full and fresh. Ran it all weekend at Death Vally and no issues. Not sure if this altitude required a mixture adjustment.
Unfortunately, I don't have a manual and left the dealer book at home. I don't even know which is the mixture screw.
I really want to ride today so any help would be greatly appreciated.
UPDATE
So, Lior, a super great guy, called me back on his day off. He talked me through possible problems. After I hung up with him, I checked some wiring at his suggestion. Still no good. Then, I noticed something. If I gave the throttle three twists, the bike would fire up for a few seconds. Hmmm, thought I, obviously a fuel issue. I looked at the petcock and noticed an open nipple. The vacuumhose had come off of here. Plugged it back in, problem fixed. This might help someone else in the future.
Thanks,
THRASHED
THRASHED screwed with this post 04-13-2013 at 10:17 AM
THRASHED is offline   Reply With Quote
Old 04-13-2013, 09:45 AM   #18299
150ron
150ron's Avatar
Oddometer: 1,415
Originally Posted by THRASHED View Post
Hey all,
Thanks,
THRASHED
The fuel screw is at the very buttom of the carb, by the engine side, (not the air boot), kind of hard to reach, i put a extneded fuel screw in mine.
try having it out 3 turns and see how it does, you will need a short small flat head screwdriver to get in there, you can try loosening, both clamp on the boots and try rotating the carb a bit, will be easier to get to.
Just some dude...
Old 04-13-2013, 11:13 AM   #18300
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,005
UPDATE
I am glad u got it solved. Here's where it is for future references.
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Times are GMT -7.   It's 09:49 PM.
