Old 06-07-2013, 03:47 PM   #19066
The Toad
Let There Be Light
The Toad's Avatar
Oddometer: 1,183
Originally Posted by Falcon86 View Post
Info please and thank you!
The headlight is a standard 7" bucket (Honda CB900). I wanted to be able to use the stock mounting brackets and plug (high beam/low beam). Also with a standard headlight in the bucket its cheap and easy to replace if it should break.
I fabricated the windscreen and its brackets to attach to the side mount headlight. Its not 100% yet, but we may offer it as a conversion "kit" in the future. The fairing and its hardware need a little more tweaking but overall I like it MUCH better. I am taking the bike to ride the CDT (north to south) in July and that should be a good test of its use-ability/durability.
thanks,
-Brian
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 06-07-2013, 04:13 PM   #19067
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,444
Swimgarm install
Everything kinda fell apart when I pulled the swimgarm out so I didn't notice how much slack, if any, existed between the pivot spacers and the swimgarm. Now that everything is ready to go back together, I noticed there is some "slop" between the spacers and SA. It looks like there is 56 mm of space on each side of the engine case (between the frame and the case), but the pivot spacers, when you lay them end to end, measure 57.5 mm.
What am I missing? Will the frame spread out a bit to slip the SA in? And does the SA normally slip back and forth laterally (a CH) until you get the rest of the suspension hooked back up?
PineyMountainRacing is offline   Reply With Quote
Old 06-07-2013, 07:15 PM   #19068
Vzuke
Vzuke's Avatar
Oddometer: 150
To THRASHED
I just hooked up the Zeta hand guard LEDs as running lights.
I didn't think they would be bright enough in daylight for turn signals.
signed, Conspicuous
Vzuke is offline   Reply With Quote
Old 06-07-2013, 07:20 PM   #19069
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Originally Posted by twizzler View Post
Thanks, they are the RAD MFG wheels and the front hub is compatible with the stock speedo drive unit so I did keep the stock instrument cluster/speedometer. I prefer the look of the stock speedo over the Vapor one in particular even though the speedometer is off by 5-15 mph with the 17" wheels it's not a fast bike but extremely grin inducing.
Really?? I like the Vapor myself, and with a fully built 434cc engine its fast too.
bobbed06 is offline   Reply With Quote
Old 06-07-2013, 07:28 PM   #19070
bobbed06
Oddometer: 1,236
VZuke your bike looks great....
Old 06-08-2013, 04:46 AM   #19071
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,574
Are any of you running high pressure radiator caps?
I was riding in a wash and the coolant started to boil in my DRZ-E. I stopped and let the bike cool down, and the bike ran fine, and showed no adverse symptoms other then that. I know high pressure radiator caps will increase the boiling point of the coolant (I think they're 1.6bar, vs 1.1bar stock), but I have heard that they will also put undue stress on your hoses and water pump. And can cause the water pump seal to leak and eventually damage the water pump. Has anyone had that issue? I am going to flush and refill my radiators, hopefully it's just old coolant, but I had also considered upgrading the cap to a higher pressure one at the same time. It's an E model, so no fan, and swapping a cap is easier then trying to install a fan, but if I hear that a lot of people are having hose/pump blowouts with the caps then I'll go the fan route.
Maybe I'll keep both caps and run the high pressure one during the summer and switch back to stock during the winter.
I tried to search this thread and the website in general, and found some info on people running (higher pressure) EXC caps on 950/990 Adventures, but nothing really DRZ specific.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 06-08-2013, 08:56 AM   #19072
Plane Dr
Plane Dr's Avatar
Oddometer: 888
You see posts here and there about HP caps. I don't recall seeing posts on component failures. The water pump leak is just part of the DRZ.
The most common route is to add a fan. The sealed high flow computer fans help big time. Mine tends to run hot so I'm thinking of adding a second to hel the stocker.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 06-08-2013, 08:56 AM   #19073
150ron
150ron's Avatar
Oddometer: 1,459
Install a fan with a SSW on/off switch, your bike is getting too hot, the fsn will cool it down i would not do a gigher pressure cap imo.
Just some dude...
150ron is offline   Reply With Quote
Old 06-08-2013, 04:00 PM   #19074
tt100
tt100's Avatar
Oddometer: 261
Joined
I switched up from a Bonneville to a DRZ. The guy that had it before me took real good care of it and put lots af great parts on it already. I'm excited to learn what you guys already know!
Out with the old....
In with the new (to me...)
Scored all these too...
tt100 is offline   Reply With Quote
Old 06-08-2013, 04:10 PM   #19075
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,601
Sisneros - Beware
When I needed a new cam chain and tensioner I noted remarks here about Eddie Sisneros and his products. I always try to support small businesses so I phoned him a week ago yesterday, ordered a cam chain kit, and my credit card was charged for over 140.00. I spoke to him personally and he said the stuff would get into the mail that day. I told him the the bike is in pieces in a parking lot in Santa Fe and I appreciate his quick delivery.
Six days go by and no package. I send him an email asking about this. I get this reply on the morning of June 6:
im checking into as soon as the parts dept is open.
About 6 or 7 hours go by and I don't hear anything so I send another email and get this reply:
they sent it to the wrong adress. its been corrected and on its way. should see it tommorow if not sat.
Of course, the chain has not appeared as of Saturday evening. And, I don't see any apology for the wasted time or inconvenience. I don't see any understanding of customer service at all.
On Monday morning I plan to contact my credit card company and open a fraud complaint.
Just saying, there are a number of vendors out there selling us parts who do understand customer service and can be relied upon. For instance, I ordered an oil change kit from ThumperTalk and it was on my doorstep three days later. Those are the types of businesses that deserve our support.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob screwed with this post 06-09-2013 at 07:45 AM
MrBob is offline   Reply With Quote
Old 06-08-2013, 06:24 PM   #19076
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,720
Every time I order from TT, I get an email a bit later saying "X part is in a different where house, and it will be an additional 3-6 buisiness days". In other words, they have to get it from their parts supplier.
I kinda hate motorcycle parts ordering. Doesn't matter where its from, it sucks 90% of the time.
Sent from my fat thumbs on a small touch screen.
GRAVEL WORLDS
'14 KTM ADV R - '06 DRZ 400 - lot's of bicycles
fifthcircle is offline   Reply With Quote
Old 06-08-2013, 08:41 PM   #19077
focallength
You're Welcome
focallength's Avatar
Oddometer: 5,217
Originally Posted by MrBob View Post
When I needed I new cam chain and tensioner I noted remarks here about Eddie Sisneros and his products. I always try to support small businesses so I phoned him a week ago yesterday, ordered a cam chain kit, and my credit card was charged for over 140.00. I spoke to him personally and he said the stuff would get into the mail that day. I told him the the bike is in pieces in a parking lot in Santa Fe and I appreciate his quick delivery.
I had a similar experience, ordered a cam, they said it was in stock, charged me and never shipped it, everytime I called I got the run around and "were too busy to look into it right now, theres a line out the door" To wit I replied you already have my money, youve told me it shipped out yesterday, 4 times now. Eventually the little pissant owner got upset and said he was tired of dealing with it. So after 2 weeks, after being told 6-7 times it would ship tomorrow, he got "tired of dealing with me calling" and refunded the money. I talked to eddy a couple of times and that guy has a rock for a brain, he claims hes the owner but dosent know whats going on, the other guy says hes the owner too.
same thing, the guy was indignant and acted like I was wasting his time, never apologized for lying, never tried to fix the problem. It was always "yeah...itll ship tomorrow" I asked for the shipping/tracking number and the reply was "we dont give that to customers". I told him that I would let everyone I came in contact with about my experience. He just laughed and said "go ahead, I dont care"
biggest bunch of retards ever, they may know about the drz, but their customer service is piss poor
Why do meteors, always land in craters?
focallength screwed with this post 06-08-2013 at 08:48 PM
focallength is offline   Reply With Quote
Old 06-08-2013, 08:59 PM   #19078
150ron
150ron's Avatar
Oddometer: 1,459
There has been like 5-7 threads in the last week alone on TT about SSW and his horrible customer service, its simply a case of guy does great engine work, but does not know shit about customer servie, period.
Just some dude...
Old 06-09-2013, 04:12 AM   #19079
greer
Oddometer: 3,858
Ordering parts
I don't mean to butt in, I've been following the thread last couple of weeks just learning about the DR-Z....
Any way, I have the best luck with Rocky Mtn and OEM Cycle. Their sites let you know if the part is in stock, and you get shipping/tracking updates by email. No affiliation with either, just a happy customer.
Sarah
http://www.rockymountainatvmc.com/
http://www.oemcycle.com/
'08 DR650, '13 TU250X
greer is offline   Reply With Quote
Old 06-09-2013, 07:12 AM   #19080
SteveROntario
Oddometer: 52
You got 3 sets of wheels!? You have an opportunity to make some good money on the SM wheels if you decide you won't want them.
Steve
2009 Suzuki DR-Z400SM (Zed version) with offroad wheels
SteveROntario is offline   Reply With Quote
Times are GMT -7.   It's 02:55 PM.
