Old 06-12-2013, 09:13 AM   #19141
iyaoyas98
Bored Silly
iyaoyas98's Avatar
Oddometer: 6,772
Originally Posted by threadkiller View Post
So if Eddie isn't the go to guy, who is?
I got a dremel and a bottle of Bulleit......
iyaoyas98 is offline   Reply With Quote
Old 06-12-2013, 10:02 AM   #19142
bobfab
bobfab's Avatar
Oddometer: 1,499
Originally Posted by bobbed06 View Post
That was where the bike was built....I had a garage, but it was not air conditioned So the kitchen worked better. Here you can see the upper motor mounts I widdled down on the mill. I also used cardboard under the stand to prevent scratching the floor.
Any pics of the bike completed? Looks great with the white frame!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 06-12-2013, 10:12 AM   #19143
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,716
GRAVEL WORLDS
'14 KTM ADV R - '06 DRZ 400 - lot's of bicycles
fifthcircle is offline   Reply With Quote
Old 06-12-2013, 10:47 AM   #19144
HiJincs
Dreamer
HiJincs's Avatar
Oddometer: 624
Couple of Newbie DRZ Questions
Just picked up a 2005 SM and need to know what would make the front inside brake pad wear 2 to 3 times faster than the outside pad.
Also, anyone care to cut and paste the proper procedure for removing and installing the front wheel on an SM? I just want to make sure I'm doing it in the right order and torque settings.
TIA
"I am ill equipped in the philosophies of failure"
When I die, show no pity, send my soul to Juggalo City.
Dig my grave six feet deep and put two Sidi's on my feet.
Put some leather over my chest and tell my family I did my best!
HiJincs is offline   Reply With Quote
Old 06-12-2013, 11:07 AM   #19145
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Originally Posted by fifthcircle View Post
No action shots? Or is there a trip report somewhere for those?
I'd like to know more about what trails you rode, and where the DRZ felt good, vs felt too big. Trying to plan a trip for this fall or next spring.
I did Metal Masher, White Rim and many more last spring. The DRZ is fine for all of this but be VERY cautious on Rose Garden Hill its an experts only trail ! best to leave that one to the Young and the Restless
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 06-12-2013, 11:33 AM   #19146
bobfab
bobfab's Avatar
Oddometer: 1,499
We only really did Fin's and Things in the sand flats rec area. The rest of the riding was limited to dirt roads / 2 track. We didnt run as many hard trails as i would have liked but the company was novices, rental jeeps and buggies.
It did fins and things at race pace without breaking a sweat... unlike me
CRF250L | KTM200SX
Old 06-12-2013, 01:33 PM   #19147
makazica
makazica's Avatar
Oddometer: 752
Klx 400
Sorry for a probably silly question, but can anyone confirm that 2001 Kawasaki KLX 400 engine parts fully fit onto an 2001 DRZ 400 engine.
Specifically I'm interested in gearbox parts, second and third sprocket on the output shaft and the second sprocket on the clutch shaft, looking from the left, also I'll be needing the left "fork" on the output shaft.
Thanks a lot!
M.
makazica is offline   Reply With Quote
Old 06-12-2013, 05:43 PM   #19148
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,467
Originally Posted by hasenwerk View Post
My 400S needs some new tires. Currently there are D606s on there from the previous owner 90/90-21 on the front and 120/90-18 on the rear. As I am using this bike for mostly highway use the D606s are dieing a rapid death - especially the front tire.
I have Mitas E-07s on my BMW 650 GS and they work quite well for me and are priced decently and was thinking of installing these on my DRZ. Question is will a 140/80-18 fit or rather work shall I say work well for the the stuff that I do, which is to and from work (15km each way on pavement) and weekend back dirt road warrior with no "serious" off road stuff? 140 seems quite a jump up from the original 110 - the issue with the 130 is that is only available in 130/80-18 which is shorter than the original tire by just a bit. I would rather get my RPMs down and not up. Perhaps I am splitting hairs too much and should just to the 130/80s?
Just do the 130. I have a 140 on my pig and it rubs on the inner plastic guard. Great tire btw, hooks up pretty good.
06 950S, YZ250WR, 300 TXT Pro
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV,Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 06-12-2013, 05:50 PM   #19149
bobbed06
Cavalera Conspirator
Oddometer: 1,236
My DRZ is using oil. I think it needs rings, so I'm gonna put a 434 in. I want headwork (ie. bigger valves/ported) so I can maximize the performance. Also, planning on FCR and Hotcams.
The porting or valve size in the DRZ head is not a limiting factor even on a 434cc build.....bigger valves and porting are only beneficial on 462cc or 470cc stroker builds.
Here ya go..... Thank You for the compliment.
bobbed06 is offline   Reply With Quote
Old 06-12-2013, 05:56 PM   #19150
Xylx
Oddometer: 99
Moab DRZ
Did White Rim in April. Much improved from a decade ago. There's outhouses ! Easy for DRZ. Behind the Rocks is good too. Although at the ledge after the sand on the way up to the Pritchett overlook I dumped the DRZ on myself. Drain the carb, start over. I wanted to do Kane Creek, but my buddy said no. He has done it and said it was really difficult and he's the guy who usually gets us in trouble. Ran into a gang of KTM 450 guys from Montana fixing flats out by Bartlett wash. There's some very nice rides out there. Don't miss the Tusher tunnel. DRZ can take most anything. There are some good posts on here about tire choice and pressure. If you're riding the White Rim have a DOT tire. They give out tickets. D606 works fine. Heavy duty tube at about 17 psi seems to be a good compromise.
Xylx is offline   Reply With Quote
Old 06-12-2013, 06:21 PM   #19151
Oddometer: 532
Did a whole bunch of trails including White Rim twice, had Maxis IT desert tires on and never saw any one giving out tickets
Did make it up to Tower Arch the long way round up the VERY deep sand climb, tires did great on that but several others tried the same route and did not make it had to turn back down hill.
Maybe I was lucky or highly skilled I may never know
KLR 650-sold
1977 BMW R100-sold
Old 06-12-2013, 09:31 PM   #19152
focallength
You're Welcome
focallength's Avatar
Oddometer: 5,049
Yeah, it seems lately he isn't shipping stuff out when he says and customers are getting pissed. I'm sure his work is great. It's just his logistics are sub par. Nevertheless, I want my stuff back in a timely manner.
Its not him its the dip shit owner of epic motorsports...
what was the greatest thing, before sliced bread?
focallength is offline   Reply With Quote
Old 06-12-2013, 09:35 PM   #19153
focallength
You're Welcome
Oddometer: 5,049
Originally Posted by DualSportDad View Post
Not sure how many cans it would take to fill each radiator or at least get enough in there to slosh around. I'll but a few and give it a try tho.
I forgot to mention as well... I came across a web site a while back that had high capacity racing radiators for like $300 a set but I can't find it again. Anyone know where I can get radiators for around $300?
Sent from my SPH-L900 using Tapatalk 2
Mylers, sells oversized radiators for $300 a pair..100% garuntee and can rebuild them for something like $15 ea. If you munch them.
Old 06-13-2013, 01:45 AM   #19154
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,467
Soooo...whos got a FCR for meeeee
Old 06-13-2013, 04:30 AM   #19155
DualSportDad
DualSportDad's Avatar
Oddometer: 2,447
Thanks, that's the best deal yet.
Sent from my Nexus 7 using Tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Times are GMT -7.   It's 11:38 AM.
