Old 08-30-2011, 09:57 AM   #10336
huntinguy
Oddometer: 16
Originally Posted by ZukiNoomin View Post
Model year doesn't matter, but the BLUE ones are faster.
I kind of like the yellow ones myself. Thanks guys.
huntinguy is offline   Reply With Quote
Old 08-30-2011, 01:02 PM   #10337
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,218
Originally Posted by huntinguy View Post
So guys what year is the best DRZ? Has to be factory road legal.
What's the lowest milage / newest one that you can find and/or afford?
(Btw, I'm thinking about selling my 06..., but Nebraska is a looong way from NC.)
http://www.firedancersglass.com/ PM me for "ADV discount"
GlennR is offline   Reply With Quote
Old 08-30-2011, 01:24 PM   #10338
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,435
Originally Posted by threadkiller View Post
Use a petcock off a Raptor 660.
Installed the raptor petcock, looks good, works good - only problem I had was the fuel line had to be routed out of the petcock, over the top of the air intake and around under the bottom of the intake and into the carb, not a big deal. But the angle was too tight to go straight from the petcock barb to the carb. I've kept the fuel line away from the engine, so it should stay cool. Capped the vacuum port on the carb and I should be good.
PineyMountainRacing is offline   Reply With Quote
Old 08-30-2011, 01:59 PM   #10339
Joey Jo Jo Jr. Shabadu
1 Less Car
Joey Jo Jo Jr. Shabadu's Avatar
Oddometer: 245
Originally Posted by bobbed06 View Post
I never knew what that extra 10mm bolt was for so I hacked that off
It holds down one side of the passenger "grab-strap" that goes over the seat.
2009 Suzuki DR-Z400S
2007 Aprilia SR50R Factory
2005 Yamaha FZ-6
Joey Jo Jo Jr. Shabadu is offline   Reply With Quote
Old 08-30-2011, 02:26 PM   #10340
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Thanks, Its much cleaner now. I went dremel happy for 2 days and cutoff the sidestand switch mount/ helmet lock/ that mount pictured/ chain guard mounts. That stuff has to add up to a bit of weight and the bike looks and builds much cleaner without that stuff.
I still want to ditch the fork lock, and shave the frame but am gonna wait until the winter to do that.I use a Krypto Lock on trips.
Since NC doesnt require turn signals I removed all of that stuff and the stock headlight. I think I may have removed
over 17 lbs of weight when considering the Shorai Battery as well. I am hoping to be around 290lbs prepped to ride, but really just wanted to clean the bike up a bit. Weight Savings is definitely noticeable so far. I will weigh it once completed.
I kept the passenger peg mounts and upper mount holes so the subframe will accept the Happy Trails Side Racks for soft bags or Panniers depending on what I decide. If I end up with Giant Loop bags I will cut those extras off as well.
bobbed06 is offline   Reply With Quote
Old 08-30-2011, 04:42 PM   #10341
Entrepre-neer
Ultimate Tight A$$
Entrepre-neer's Avatar
Oddometer: 424
E model For Sale in the "greater" Denver area
http://advrider.com/forums/showthread.php?t=719918 - In the flea market
Shameless plug.
2001 Suzuki DRZ400E (electric start, better carb) - $2400 ($2300 if you don't want the bigger tank)
Wyoming Street Title PLATED
FMF Power Core 4 exhaust (has spark arrestor)
Keihin FCR 39mm carb
IMS 4.1gal Larger Tank (Original tank included but this one is just as narrow.)
Suzuki factory High bend bars with 1.5 risers (Super comfortable standing up for me @ 61)
Rear Rack (ties into sub-frame)
LED tail light with dual switches
Skid Plate
Thumper Case Savers (gotta stick the left side on)
Wide Foot Pegs
MSR Bark Busters
Folding mirror
Radiator Guards
14-Tooth sprocket (Trail)
15-Tooth sprocket (Street/Trail)
Tires have 3 days of riding on them (Both DOT legal - Kenda Trackmaster II in back)
2011 Colorado and Wyoming OHV stickers
Entrepre-neer is offline   Reply With Quote
Old 08-30-2011, 05:01 PM   #10342
Just GO!
Countersteer it.
Just GO!'s Avatar
Oddometer: 2,867
Handguard question..
Does anyone know if Suzuki markets a set of handguards for the DRZ's that look identical to their VStrom handguards?
These ones.......
Don't know why I'm lost all the time...
Everyone is always telling me where to go.
Just GO! screwed with this post 08-30-2011 at 08:08 PM
Just GO! is offline   Reply With Quote
Old 08-30-2011, 05:19 PM   #10343
huntinguy
Oddometer: 16
Not ready to buy right now anyway. No money!
Old 08-31-2011, 04:34 PM   #10344
211john
Oddometer: 225
Ballistic Battery
I recently bought a 2001 E model with very low miles. After about 4 months the battery isn't holding a charge. I have not idea how old the battery was. I just replaced it with a Ballistic Evo2 4 cell. While I was hoping for a great big weight reduction, the old battery didn't really weigh that much. Maybe it was dry? I didn't look that close.
As you can see the new one is much smaller. It's actually a little taller though and if the leads were long enough I would have put it on it's side (still might). I had to grind a little of the battery box away to make clearance for the charging port and add some closed cell foam to hold it in place. Doesn't weigh anything and the bike fired right up. Definitely cranks good.
I couldn't find much info on the Ballistic so I figure I'll just have to try it myself.
211john is offline   Reply With Quote
Old 08-31-2011, 05:02 PM   #10345
bobbed06
Oddometer: 1,236
I went with the Shorai battery, and I cant remember but I think I lost 6 lbs by switching to it. I want to say 7bs but cant remember for sure. I thought about using the Ballistic and mounting it in between the CDI and the seat. But I I am not there yet, as thats the next step on my list. I would like to completely eliminate the battery box if I can. I may have to notch the seat pan.
Regardless of the mounting method used the new generation of batteries are unbelievably lightweight. Off to the garage.
Old 08-31-2011, 05:45 PM   #10346
PineyMountainRacing
Oops....
Oddometer: 2,435
Originally Posted by p0diabl0 View Post
Those are the screws that hold the chain guard on.
Dingdingdingding.... You're right, now where did those 2 bolts come from that WERE holding the chain guard on? Duh. I gotta be more careful.
Old 09-01-2011, 01:17 AM   #10347
kmax
Kruzer
kmax's Avatar
Oddometer: 222
Vstorm handguards are good for wind and rain cover but not for protection once you drop the bike.
I had it on my other bike and handguards fly away everytime the bike fall, so eventually switched to barkbusters.
These ones.......
Roamer, Wanderer, Nomad, Vagabond, Call me what you will
kmax is offline   Reply With Quote
Old 09-01-2011, 04:48 AM   #10348
dasvis
dasvis's Avatar
Oddometer: 536
The Highway dirt bike handguards are the gold standard, no others are even close as far as quality & protection.
http://www.highwaydirtbikes.com/HDB_Shop/
Dasvis
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
2009 Suzuki DRZ400S
dasvis is offline   Reply With Quote
Old 09-01-2011, 06:48 AM   #10349
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,789
Thumb
Dasvis
Ya know I'd seen their stuff before but didn't quite look close enough....now that I'm doin the DRZ to KLR fork swap and adding a Vapor...this is looking fricken gooood! They've got a nice set up and I could get the Vapor right up in my face at the top clamp...
I like it maaan Thanx for taking me back down that road...and my Cabelas card thanx you too
Jettn Jim is offline   Reply With Quote
Old 09-01-2011, 06:58 AM   #10350
Just GO!
Countersteer it.
Just GO!'s Avatar
Oddometer: 2,867
Concerning the handguards, what I am asking is this..........
Has Suzuki ever marketed those VStrom handguards (shown in the pictures I posted) for use on the DRZ models?
Times are GMT -7.   It's 08:10 PM.
