04-30-2012, 07:31 AM
#14341 |
Oddometer: 720
He used honda wheels. He has a thread going on TT. Search Hooligan you'll find a couple.
01/09 DRZ470SSW more bits than necesary 2005 R1200 GS AKA The Mothership 2003 Z1000 Nuclear Pumpkin (gone) 86 RG500WW (gone) Bikes are like women. What you think you want, and what you want, change after the first ride. |
04-30-2012, 08:13 AM
#14342 | |
Newb Extraordinaire
Oddometer: 180
Thanks for the info! The TATrack system looks great, will there be an E version available as well? I'm from VT originally and will be up there quite a bit this summer- maybe I can even save on shipping as well!
-Sevenpointsixtwo 1998 Tiger 900 2000 DRZ400E |
04-30-2012, 08:21 AM
#14343 |
Let There Be Light
Oddometer: 874
Oil Filter - O - ring.... O ! Ring ? or ????
So its only my second oil change on the DRZ and after doing so, I remembered that I forgot to research the fact that my 04 "S" model has no "O-ring" behind the filter.... the one that the service manual says should be changed whenever you change the filter.. Im not sure if the original owner pulled it and never replaced it ?? or maybe it was attached to the original filter and came out with it ???
In either case, it appears that it isnt needed ? Is it typical to run without it ? or am I in dire need of getting one yesterday and installing it ??? Does anyone know where to get the proper size ?? thanks, -Brian
LED LIGHTS - LED Lights For Sale - MondoMotos - Motorcycle Accessories BLOG - BackRoadBiker RIDE REPORTS - Four Corners - Amish Country - Costa Rica - RoadRUNNER - Expedition Michigan (or not) - Tellico Plains The Toad screwed with this post 04-30-2012 at 08:26 AM |
04-30-2012, 08:51 AM
#14344 | |
Ranger
Oddometer: 1,007
2000 Suzuki DR-Z400S “And what is good, Phaedrus, and what is not good- Need we ask anyone to tell us these things?” Pirsig |
04-30-2012, 09:07 AM
#14345 | |
The Dude abides
Oddometer: 228
an assortment of o-rings in a small plastic box. I keep one in the garage, it has saved me many trips to the hardware store.
Winter Springs, FL Yeah, well, you know, that's just like your opinion man - The Dude |
04-30-2012, 09:10 AM
#14346 |
Endeavor to Perseve
Oddometer: 3,435
Yes, there is an E rack. Tom (Jackpiner57) finished the fabrication on the prototype and it's in for paint this week. The production models will be powder-coated as his other racks are. I hope to road test it soon. The system consists of both a top rack and side racks which are designed to work together. I have some pictures of the rack in progress, but I will not post them without Tom's permission. If you PM him, he will likely share them with you.
The Bull Cook Racks Made in the US! Dual Sport Luggage Racks for: DRZ-S, SM and E, DR 650 and KLR650: http://www.moto-racks.com |
04-30-2012, 09:20 AM
#14347 |
Montana Adventurer
Oddometer: 290
Key relocation after install of Rox Risers on the "S"
Anyone have any shots of what they did when they installed the Rox 2in risers with their ignition location? If you roll back the Rox Riser you can slip in the end hole of the ignition bracket into the lower clamp bolt but if you want to toll the rox mount forward you cover up this access.
Thought someone might have a plate they made of the equivalent. Thanks.
JB |
04-30-2012, 09:51 AM
#14348 | |
Oddometer: 822
Project Labor of Love: 1972 CT90 Rebuild Current Stable: DRZ400 | VFR800 | DRZ250 | CT90 | KTM200sx Need an airfilter for your DRZ250!? I have too many, PM ME
04-30-2012, 10:18 AM
#14349 | |
Kitsune
Oddometer: 192
That side up. ![]() '02 FZ1, '02 DRZ400S, '09 TE250 |
04-30-2012, 11:29 AM
#14350 |
kefakruiser
Oddometer: 69
12 Tooth Front spocket
I googled DRZ sprockets and found a supplier. Went to their sight and searched DRZ400E sprockets and bought a 12 tooth and a 15 tooth. Currently have a 14T on the bike. Has anyone ever ran a 12T? Sounds like a trials sprocket and I don't want to damage chain, sprocket, etc. Will it fit the stock chain?
I guess it only takes 10-15 minutes to put it on and take it for a spin. I have read 700 pages of this D@*N thread and haven't seen anyone who had tried a 12T...
Rick 1996 Triumph Trophy 900 for commuting 2000 Suzuki DRZ400E- New to Me 2007 Yamaha XT225 for everything else- Sold |
04-30-2012, 11:54 AM
#14351 | |
pining 4 the fjords?
Oddometer: 555
Oil filter O-ring Size
What Rumble Strip??? http://www.advrider.com/forums/showthread.php?t=734616 http://www.advrider.com/forums/showthread.php?t=723302 |
04-30-2012, 12:58 PM
#14352 | |
Rubber duck
Oddometer: 453
![]() At a guess it will probably chew out the swing arm before it buggers the chain.
If you answered yes to all, some or some of none of the above questions please consult your healthcare professional. DR-Z434E Gas Gas EC 300 |
04-30-2012, 01:14 PM
#14353 |
Oddometer: 2,912
is that a jdm drz400s tail light?
![]() if not what do they look like?
2002 DRZ250 what it lacks in horse power it makes up for with traction FOR SALE!!! ![]() 2000 DRZ400e tagged ![]() 1980 TS125 project in the corner 200? zuma 50/70 the wifes bike
04-30-2012, 03:09 PM
#14354 | |
toadl
Oddometer: 608
http://www.thumpertalk.com/topic/954...on-an-drz400s/ |
04-30-2012, 09:45 PM
#14355 |
Oddometer: 945
I've got a stupid type question for you guys. Been cruising my drz for about 1k miles now, that puts her at just over the 11k mark, 2006 S model.
Thing runs awesome, and looks brand new. I got it off my little bro. I checked the oil the other day, seems a hair less than 1/2 qt. low at the stick, so I added 1/2 quart of 5w-30. I noticed there's oil on my garage floor now, bottom of the frame, and around the shifter and sprocket. It also has slung oil onto my tire and I had a nice fishtail making a turn on slab. I figure it's leaking from the CS seal, but I'm also figuring that I just need to drain the oil and fill it all back up with rotella 15w-40. I know that's what my xrl uses, but it's air cooled, I was too stupid to read up and see what the recommended oil for the bike it, and figure the thin oil might just be slipping past the seal. Either that or the seal itself just magically started leaking about the time i added oil to the bike. I do know there's a problem with the mild steel spacer on the countershaft/seal that can be changed out for a stainless unit, but I kind of doubt it would happen the moment I put some 5w30 oil in the frame. thoughts? |
