Old 07-04-2012, 04:35 AM   #14941
generatordave
generatordave's Avatar
Oddometer: 88
Originally Posted by ptgarcia View Post
Do you mean MT 43s? I haven't heard of MT 24s before.
I run 18-20 psi in my tires around town and typically 12-14 psi off road (mostly rocky terrain around here and pinch flats are common). When dual sporting I don't stop to adjust pressures. I set them to 14 psi before I head out and raise them back to 18-20 psi if I remember when I get home.
On the trail I carry a spare tube with a handful of CO2 cylinders; no pump or compressor. Knock on wood but I haven't needed them yet.
MT43's
My Bad Pauly
Thanks for pointing that out!
Dave
2012 DRZ400
1973 Honda Elsinore 250 ( nice barn find to be restored)
RANCHER 350 atv, BRUIN 350 atv
and a kick ass 21' chris craft
generatordave is offline   Reply With Quote
Old 07-04-2012, 04:39 AM   #14942
generatordave
Oddometer: 88
Originally Posted by LittleRedToyota View Post
i air my rear down to 8 to 12psi and front down to 12 to 15psi for dirt riding depending on the nature of the trail (basically, if there are a lot of rocks, i go with the higher end of the range. if there aren't, and it's really slippery, i'll go with the lower end of the range. if i don't know what to expect, i'll go in the middle.)
(sometimes i forget to air down...but i realize it about 1 minute into the trails. it really does make a huge difference.)
i'll leave the pressures like that for riding roads to link trails. i will sometimes leave the pressures like that to ride home at the end of the day if i'm withing 10 miles or so of home.
if i have farther to go, i will air back up (to around 25psi both front and back) first. a bunch of the guys i ride with do not have plates and trailer to rides. i can generally borrow an air compressor from one of them. if everyone is dual sporting it, though, we will stop at a gas station to air back up if there is one within a few miles of getting back on the road. if not, i carry a planet bike mini versair MTB pump and use that (which i also use to fix trailside flats).
i have ridden pretty far on twisty roads at pretty good speeds with 10 psi in the back and 12 in the front. it does not equal death. the bike does feel squirmy, though, and i would rather air back up. but i don't bother if we are linking trails.
(also, i have rim locks...i like two per wheel as they balance each other. i would not run such low pressures without rim locks.)
i prefer to carry a bicycle pump (particularly the mini versair...as it is a dual stage, high volume pump that fills the tire rather quickly and is easy to use and it's cheap--and i've used it many times and it has never let me down) as opposed to an air compressor (too big and weighs too much) or CO2 cartridges (if you run out of cartridges--it can take a couple to fill a single tire, and you might have more than one flat--you are screwed)...though having both CO2 cartridges and a pump would be a good backup.
here is a link to the mini versair:
http://www.rei.com/product/800084/pl...al-action-pump
Thanks LRT and all others that replied to my air pressure question.
I have 2 rim locks coming and will have installed with my new tires.
This forum is full of great information for a noob, Thanks again to all.
Looking forward to Cromag and meeting those that attend,
Dave
2012 DRZ400
Old 07-04-2012, 07:06 AM   #14943
yosso
yosso's Avatar
Oddometer: 971
Originally Posted by sanjoh View Post
The new fairing looks great.
Honda ST1300/2000 Suzuki DRZ400E/Ducati 750 Monster re-work Blog
yosso is offline   Reply With Quote
Old 07-04-2012, 07:30 AM   #14944
See-Three
C3
See-Three's Avatar
Oddometer: 143
I need a rear sprocket.
Any chance someone on here lives around norther Oklahoma that has a rear sprocket that will work on my DRZ400? A used one would be great as a spare until I can find a new set of sprockets and chain.
Anything from a 44-46 tooth should work with my current chain
I'm from nh and am currently doing the TAT. Ride report here http://advrider.com/forums/showthread.php?t=803820
See-Three is online now   Reply With Quote
Old 07-04-2012, 05:45 PM   #14945
Ryel
Ryel's Avatar
Oddometer: 236
I have found no discussion on setting the DRZ rear race sag. What is the easy way to measure sag and set the pre-load?
"Good judgment comes from experience and experience comes from bad judgment."
Ryel is offline   Reply With Quote
Old 07-04-2012, 06:05 PM   #14946
kpt4321
kpt4321's Avatar
Oddometer: 1,671
Measure from the axle to some easy-to-see point on the tail (edge of the plastic, tape/marker line, whatever). Lift the rear of the bike and measure it (fully drooped out), sit on it in the riding position and measure it (or rather, have someone measure it). Set it by adjusting the preload on the rear shock.
Rule of thumb is 25-35% of total travel. For most dirt bike, this means about 4 inches.
TAT 2008 / Colorado 2010
"Both the man of science and the man of action live always at the edge of mystery, surrounded by it." -Oppenheimer
2007 Monster S2R / 2006 TE610 / 1999 KDX 200 / 2000 DRZ-E
kpt4321 is offline   Reply With Quote
Old 07-04-2012, 06:38 PM   #14947
tominboise
Oddometer: 722
Originally Posted by 59DEN View Post
+1 - mine does not have the digital readout
I have had a good 2 years so far out of my Topeak hand pump, lots of coastal sand riding, it gets a good workout and works very well.
How do you guys carry your pumps on the bike?
tominboise
1995 DR350SE - mini adventure bike,,,,
1982 R65/80 G/S - bigger adventure bike,,,,
tominboise is offline   Reply With Quote
Old 07-04-2012, 07:34 PM   #14948
59DEN
59DEN's Avatar
Oddometer: 838
Hi, I had a small canvas cover made up for mine, which is then attached across ways to the handlebars with some double sided velcro tape, works well.
59DEN is offline   Reply With Quote
Old 07-05-2012, 04:57 AM   #14949
mrprez
KJ4WMZ
Oddometer: 1,265
Can you set the bead when changing out a tube with one of these hand pumps?
mrprez is offline   Reply With Quote
Old 07-05-2012, 05:59 AM   #14950
mrprez
KJ4WMZ
Oddometer: 1,265
Originally Posted by 955616846 View Post
Yes.
I use these pumps to set the bead on the GSes tubeless tyres...
Really? I had trouble seating a rear tire on a GS with an electric pump. I'll have to look into one of these. Thanks...
Old 07-05-2012, 06:56 AM   #14951
wingam00
Formely AKA Wingam00
wingam00's Avatar
Oddometer: 530
Yes.
With this being small bike pump, how was the volume when using on a motorcycle tire? How long did it take to pump up the GS tire?
Mark
“There is only one reason for pavement and that is to get to dirt.” - “King” Richard Burleson
-- If you argue with a Fool you are a FOOL! --
wingam00 is offline   Reply With Quote
Old 07-05-2012, 09:31 AM   #14952
mrprez
KJ4WMZ
Oddometer: 1,265
If it is taking excessive amounts of pressure to seat tubeless tyres then something is not right and it most often comes back to technique.
It was definitely technique. It was the first time I had put a new tire on the back. Seems like it was just the last few inches that wouldn't pop on. Had to deflate and relube.
I'd like to see how you have your tool tube rigged up as an air chamber. Got any pics?
Old 07-05-2012, 09:39 AM   #14953
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,078
955616846,
How about showing us a photo or 2 of your tool tube air resevoir setup? That sounds interesting.
GlennR is offline   Reply With Quote
Old 07-05-2012, 09:47 AM   #14954
ptgarcia
Huh?
ptgarcia's Avatar
Oddometer: 509
The DR-Z seems to like a little less sag than most. 90mm is recommended by Eddie Sisneros and works great for me.
Pauly
'06 DR-Z400S
ptgarcia is offline   Reply With Quote
Old 07-05-2012, 10:48 AM   #14955
jackpiner57
Moto-Racks.com
jackpiner57's Avatar
Oddometer: 1,671
Saw this and couldn't help posting it. Maybe just carry one of the small 3 oz cans of WD40 and a lighter?
http://www.youtube.com/watch?v=UhR5Z...layer_embedded
Tom - '07 DR-Z400S, '05 DL650
Dual Sport Luggage Racks: DRZ400, DR650, KLR650, WR250R:
http://www.moto-racks.com
"I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott
jackpiner57 is offline   Reply With Quote
Times are GMT -7.   It's 04:37 PM.
