06-15-2009, 05:00 PM
#1591 |
plainsman
Oddometer: 89,061
It's probably okay if your needle and seat are in good condition. What you ought to do is look at the sight glass and see if the oil level has risen from where it was. Then open the oil cap and sniff and see if the oil smells like gasoline. Next, take the seat off and cover to the airbox and see if fuel ran into the airbox. (a little liquid in there may be normal...never come into contact with that stuff...it can cause cancer)
If you don't detect fuel in any of those places, you're okay.
_______ |
06-15-2009, 06:20 PM
#1592 | |
Oddometer: 1,274
Turin 11' Husky TE449, 06-Husky SM610(100/0)- 02' Ducati ST4S- - 04'Honda xr80r "Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves." - Albert Einstein |
06-16-2009, 08:22 AM
#1593 |
WNC trail addict
Oddometer: 404
anyone ever installed handguards on the stock bars? holy crap i spent 4 hours installing them on my girlfriends 200 last night, had to grind the weld off the bar end weights, then the inside diameter of these bars is not a standard size either, what gives? these mustve been the absolute cheapest bars suzuki could get their hands on
'99 DR 200SE '05 KTM 450 EXC '05 SV 650n '02 YAM YZ 250 |
06-16-2009, 08:47 AM
#1594 | |
I can ride on dirt, too?
No dice. The levers don't clear the inside of the guards, no matter how I arrange them.
06-16-2009, 09:01 AM
#1595 |
WNC trail addict
Oddometer: 404
i got mine fitted, just a lot more work than it shouldve been, as far as problems with your levers, they'll just have to hang out the bottom of the guards, thats how i have mine on all of my bikes
06-16-2009, 09:09 AM
#1596 | |
06-16-2009, 09:46 AM
#1597 | |
ADVenture Capitalist
I've dropped plenty of bikes and never had a lever break with good handguards. It's easier to swap bars. the stock bend is really high. CR HI actually sits lower. I'd reccomend a KX hi or Pastrana FMX bend. Unless you're running adapters for a fat bar that will raise them, then a CR HI will be a good bet.
Not an ACTUAL motorcyclist |
06-16-2009, 11:27 AM
#1598 | |
WNC trail addict
Oddometer: 404
06-16-2009, 02:15 PM
#1599 |
Where we riding to?
Oddometer: 3,520
Make sure you leave the lever clamp bolts a little loose as well, that allows the lever to twist in a fall instead of breaking. You should be able to twist the lever on the bar without much resistance, just enough to hold it in place.
06-16-2009, 04:39 PM
#1600 | |
Drill a 3/16 hole in the lever about 1/3 of the way in from the end and chamfer it so there are no barbs and rough edges. If they do take a hit you still have enough lever there to work the brake or clutch. If you want the "rotation" effect; there are some nice clamps from ASV. I've gotten them as "blemished" from ASV's ebay page. Dig around, it's there. ![]() Pick up a couple of their Y-handles while you're at it. They're really handy.
06-16-2009, 07:33 PM
#1601 | |
Oddometer: 259
06-16-2009, 07:44 PM
#1602 | |
plainsman
Oddometer: 89,061
Yours lets the fuel flow into the carb all the time when it's "on" regardless of whether the engine is running or not. You ought to get into the habit of shutting it off whenever the engine isn't running. Eventually it may cause problems with too much fuel getting into the carb because of a worn needle and seat or something like jiggling the bike constantly when being trailered, for example.
_______ |
06-16-2009, 11:47 PM
#1603 | |
Uncle Sally
Oddometer: 306
Thank you
2007 Kawasaki Ninja 500 (Pirelli Sport Demon tires front and rear, full set of Tourmaster Cortech Sport Saddlebags) 1997 Suzuki DR 200 (Ricochet skid plate, www.cycleracks.com rear luggage rack, Bridgestone ED03 front tire, Pirelli MT21 Rallycross rear tire) |
06-17-2009, 06:21 AM
#1604 | |
Oddometer: 1,274
I must admit this DR200 was my latest acquisition and it is now my favorite around town bike. Small, agile, makes all the noises with out the tickets! Good fun!
06-17-2009, 06:32 PM
#1605 |
Oddometer: 61
I just got a new battery ($55). Batteries for that bike last about a year for me. Leaving the light on now and then doesn't help, but that's rare. How long do your batteries last in the dr200, and what maintenance do you do to them, if any? I took my battery out for the winter. No battery tender.
![]() I just got my dr200 back from a great local mechanic. He installed a chain, 2 new sprockets and a new tube and tire totaling $230 including tax, parts, and labor. ![]() My front sprocket is stock, but I took 6 teeth off the rear one, so it has 39. It's quite a drastic change from stock, but I like it as I ride mostly around town and on back roads in the country. Crusing at 55mph has never been so good on the dr200. Definitely need 4th gear more often on hills ;)
-2000 Suzuki DR200SE -1999 Suzuki GS500e |
