Old 03-02-2010, 08:11 AM   #2281
K44rll
K44rll's Avatar
Oddometer: 271
Originally Posted by HeReTiK
How are you guys planning on installing this thing? Drilling into the case to run the lines???
No need it's a plug and play kit, oil feed is from the 17mm headed main oil gallery feed just below the oil filter housing and return is via the replacement oil filter housing
http://www.motosd.com/vip/UploadFile...8161330732.gif
Karl
www.vstromadventure.co.uk www.suzukivanvan.co.uk www.suzukiburgman.co.uk
www.flickr.com/photos/k44rll/sets/ www.klassiktrans.co.uk
Suzuki DL650A V-Strom Touring K7... Suzuki Burgman 400 K9...Suzuki Vanvan RV200 K8...Suzuki Djebel 250XC...Suzuki StreetMagic TR50S...Suzuki Choi Nori...
K44rll is offline   Reply With Quote
Old 03-02-2010, 09:07 AM   #2282
bross
Where we riding to?
bross's Avatar
Oddometer: 4,633
Karl
Looks pretty darn vulnerable in a tip over. I'll pass, never had a problem with the bike overheating anyway and I live in a desert.
Old 03-02-2010, 06:13 PM   #2283
HeReTiK
HeReTiK's Avatar
Oddometer: 259
Wow, that's awesome. Count me in too. Someone should grab a bunch of these and sell them on eBay.
HeReTiK is offline   Reply With Quote
Old 03-02-2010, 08:30 PM   #2284
green hell
yawning or snarling
green hell's Avatar
Oddometer: 19,967
i'm pretty sure my leg would protect that set up from damage in a go-down.
lookin' for a place to happen;
makin' stops along the way - the tragically hip
needless dickery
green hell is offline   Reply With Quote
Old 03-03-2010, 06:09 PM   #2285
ebrabaek
Oddometer: 4,810
That thing is mayhem waiting to happen......If you off road these.....You will hit bumps....you will ding your shin.....If you take a spill you will ding your leg.....and your exposing the magnesium case to carnage.....this is now your new crash bar.......Ouch.......
Erling
Old 03-03-2010, 11:51 PM   #2286
gazzerwgtn
Oddometer: 5
Trojan Oil Cooler
Has anyone checked out the factory oil cooler on the Trojan sometimes called a DF200
looks like a tidier option
gazzerwgtn is offline   Reply With Quote
Old 03-04-2010, 12:01 AM   #2287
gazzerwgtn
Oddometer: 5
Trojan Link
http://www.suzuki.co.nz/html/blob.ph...lementId=11203
The oil cooler is mounted on the left side of the downtube (check out page 2 of the .pdf)
Old 03-04-2010, 04:31 AM   #2288
mike1952
Oddometer: 1,114
why
mike1952 is offline   Reply With Quote
Old 03-04-2010, 09:38 AM   #2289
K44rll
K44rll's Avatar
Oddometer: 271
The OE oil cooler alone is $331.51
As well as the other pipes,connectors you will also be needing a new clutch cover for the oil return $$$$$$$$$$$
I know it's not Suzuki quality but a sensible priced option
Karl
Old 03-04-2010, 09:39 AM   #2290
HeReTiK
HeReTiK's Avatar
Oddometer: 259
I absolutely love that bike. Someday I will have to travel to NZ and bring one back with me. ;) ;) ;)
Old 03-04-2010, 02:29 PM   #2291
SoccerShark21
SoccerShark21
SoccerShark21's Avatar
Oddometer: 4
Bike now idles poorly
So the back story is that my DR200 has been sitting under a cover for a good month because of all of the snow that Virginia was getting. Last week, I had to drain the fuel (which had become very gunky) and clean the connecting bolt for the starter wire.
Today, I decided that I would start the bike up and let the engine run for a good 15-20 minutes before riding so that it could warm up and kinda clear its system after sitting for a month.
The problem now is that the bike idles poorly. I stood there for 15 minutes holding the throttle so that the engine wouldn't die, which happened twice when I let go of the throttle. What seems to be wrong? Could it be a carburetor or spark plug issue? What can I do to fix this?
I will also note that the bike definitely has gas. I bought a small gas can and filled it up, so I'm going to add a little fresh gas to the tank to see if that helps after I post this.
SoccerShark21 is offline   Reply With Quote
Old 03-04-2010, 03:56 PM   #2292
bburnette21
Adventure Ready
bburnette21's Avatar
Oddometer: 172
WTB--- Need two rims for my DR200
Want to buy two rims for my DR. Message me or email at suzukidr200@gmail.com
bburnette21 is offline   Reply With Quote
Old 03-04-2010, 04:11 PM   #2293
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,745
It's likely the carb is a little dirty. Maybe fresh gas will clear it.
Old 03-04-2010, 04:39 PM   #2294
mamacone
mamacone's Avatar
Oddometer: 149
Carberator Vent Hose?
On the right side of the carburetor there are two hose's the front one goes to the fuel petcock (if you have the original petcock otherwise it is caped off), where does the rear hose on the right go? It looks to me like it sits in a clip on the top of the air box, but that sure looks like an easy way for dust to get into the carburetor? If someone could go take a quick look at their it would be greatly appreciated. Thanks.
mamacone is offline   Reply With Quote
Old 03-04-2010, 04:57 PM   #2295
ebrabaek
Oddometer: 4,810
Your pilot jet is clogged.... The PJ orifice is not much bigger that a few human hairs.... It plugs up easy after fuel is gunked up..... Remove the fuel line, and vacuum line.....throttle cable as well..... Loosen the two clamps...Rotate the carb so you can take the bowl off.....remove the pilot jet....NOT the center positioned one where the needle goes......Clean it good...or better yet get a new one...it only cost a few bucks.......
Erling
Times are GMT -7.   It's 11:17 PM.
