Old 05-25-2010, 06:26 AM   #2596
ridingleaky
Just startin' out
Oddometer: 14
I've been to Moab on my pedal bike and can't wait for the chance to do it on my little DR, it sounds like a pile of fun
ridingleaky is offline   Reply With Quote
Old 05-25-2010, 09:49 PM   #2597
web037
Oddometer: 164
Originally Posted by bross
....then *before* loosening the bottom clamps, break loose the top fork cap bolt. It's easier when the fork is still clamped in the triple tree, but loosen the top clamp first as it can pinch the bolt.
Once the forks are out just unscrew the top cap bolt. It'll probably pop out because of the pre-load on the spring and you might find it easier to turn if you keep pushing it down as you unscrew. Be careful starting the top cap bolt, it's got very fine threads and easy to cross thread, again keep pressure on the bolt as you screw in, you should be able to screw in almost all the way by using downward pressure....
The DR200 forks do not have a top cap bolt they have a sort of plug that is held in with an inside retaining ring. To open them up you need to push down on the top plug real hard with a small metal bar or Phillips screw driver and then grab hold of the retaining ring and pull it out. Not an easy task and best done with three hands and while the fork tubes are tightly clamped in the triple clamp. After that they are a pretty standard dampening rod forks.
While you got it apart you might want to consider throwing in some stiffer springs. They made a big difference on my wifes.
web037 is offline   Reply With Quote
Old 05-25-2010, 09:53 PM   #2598
web037
Oddometer: 164
Originally Posted by GarryC
My wife and I just returned from 4 days in Moab with our bone stock DR 200's...what a blast. The little bikes performed perfectly. I was afraid they might be a bit challenged in the performance department but they were more than up to the task. I took my DR 650 as a backup and only put 30 miles on it ...the DR 200's were too much fun to mess with the bigger bike!
What a beautiful place to ride. I gotta make a trip out there some day. Just gotta get my wife comfortable on her DR200.
Old 05-25-2010, 10:06 PM   #2599
Dagofast
Full giggety ahead.
Dagofast's Avatar
Oddometer: 1,356
Originally Posted by Klay
...snip... The petcock will fail at some point...just replace it.
Originally Posted by kelly007
thats my normally philosophy. We dont have the same petcocks as you guys i think. The standard is on/off/res type no vacuum pipe or anything....snip...
You lucky Africaner's get a better petcock? Cool!
Just FYI for any stateside owners, when the petcock on dagowife's DR200 failed, I found the manual petcock from one of our Yamaha TTR-125LE's fit perfectly. You just need to remove the vacuum line from the carb and put a cap on it. Suzuki wanted north of $70 for a replacement, the Yamaha unit was $10 bucks.
Dagofast is offline   Reply With Quote
Old 05-26-2010, 04:09 PM   #2600
K44rll
K44rll's Avatar
Oddometer: 249
Petcocks
Is there any reason (Cost/Availability) why you can't fit the Suzuki non vacuum petcock as used on the UK and Japanese DR200's
part# 44300-44AA0
Karl
www.vstromadventure.co.uk www.suzukivanvan.co.uk
www.flickr.com/photos/k44rll/sets/www.klassiktrans.co.uk
Suzuki DL650A V-Strom Touring K7..Suzuki Vanvan RV200K8..Suzuki Djebel 250XC..Suzuki StreetMagic TR50S..Suzuki Choi Nori..Suzuki AP50 1976..Honda Monkey R..
K44rll is offline   Reply With Quote
Old 05-26-2010, 04:36 PM   #2601
mrchristian
Oddometer: 114
Which ones did you put in?
mrchristian is offline   Reply With Quote
Old 05-26-2010, 04:40 PM   #2602
Klay
plainsman
Oddometer: 89,809
part# 44300-44AA0
Karl
I imagine you could, but availability is a problem here. There's no reason to pursue it if a Yamaha petcock fits well.
I replaced my petcock with the original vacuum operated model just for the convenience of not having to turn the petcock off all the time. The DR200 experiences constant use with many short trips.
_______
Old 05-26-2010, 05:17 PM   #2603
bburnette21
Adventure Ready
bburnette21's Avatar
Oddometer: 145
Adjusting the Valves
Has anyone adjusted the valves on their DR....
2011 BMW 38th Annual International Rally, Youngest Rider Winner.
2012 BMW Motorcycle Owners of Georgia, 28th Annual Mountain Rally, Youngest Rider Award.
- 2006 BMW F650GS Dakar
- 1988 Honda NX650
bburnette21 is offline   Reply With Quote
Old 05-26-2010, 05:29 PM   #2604
Klay
plainsman
Oddometer: 89,809
Yes, a very easy and convenient process.
_______
Old 05-26-2010, 06:13 PM   #2605
bburnette21
Adventure Ready
Oddometer: 145
Do you know a forum i can look at to guide me through the process?
Thanks,
Brandon
- 1988 Honda NX650
Old 05-26-2010, 07:36 PM   #2606
Klay
plainsman
Oddometer: 89,809
Thanks,
Brandon
There may be one in this thread...I can't remember. Have you ever done valves before? It's a matter of taking the valve covers off, turning the engine to get the piston in the right place, (intake valve opens then closes and mark on flywheel lines up with the inspection port) and then measuring the clearance between the rocker arm and tappet. It's really easy to do with the 200.
_______
Old 05-26-2010, 08:48 PM   #2607
web037
Oddometer: 164
CRF150F springs from BBR. Go back to page 163 and see post #2440.
Old 05-26-2010, 10:20 PM   #2608
Dagofast
Full giggety ahead.
Dagofast's Avatar
Oddometer: 1,356
According to the dealer, it wasn't available in the US from Suzuki. The Yamaha petcock fits perfectly and works just fine. For 10 bucks!
The same dealer sells Suz, Yam and Honda bikes and parts. He didn't give a hoot what I used the petcock on.
Old 05-27-2010, 09:46 AM   #2609
bburnette21
Adventure Ready
Oddometer: 145
Valves
No, This will be my first valve adjustment on any bike.
- 1988 Honda NX650
Old 05-27-2010, 11:01 AM   #2610
Klay
plainsman
Oddometer: 89,809
You might need a little help, but the 200 is perfect to learn to adjust valves.
_______
Times are GMT -7.   It's 10:06 PM.
