02-06-2008, 10:15 PM
#301 | |
plainsman
Oddometer: 89,011
_______ |
02-15-2008, 12:03 AM
#302 | |
running in: please pass
Oddometer: 349
I cut a 2 inch hole in the airbox lid and put it back together without the jet kit to take it out for a spin. A bit lumpy off the line, but it sure did sound like a gentleman's motorcycle. Pulled the carb, spent spent way too long messing with seized screws, but eventually got everything apart and cleaned. I fitted the main and pilot jets, and the fuel screw, which I could not get in more than 14 turns, (by hand,) despite the instructions' claim that it'd go in 15 or 16 turns. It's backed out 1.25 turns. Put it all back together, and it smelled very rich. Hard to say whether I noticed a difference on the short ride I just had, but it beat mister boi racer three out of three. One thing I did notice was that the engine was hot, hot, hot when I parked up at home. Whether because I'd been giving it the berries or because of the mods, I don't know. Both sound plausible. A couple of weeks of my usual commute should be long enough to see whether there are any measurable changes in performance or consumption. |
02-15-2008, 12:03 PM
#303 | |
plainsman
Oddometer: 89,011
_______ |
02-16-2008, 09:13 PM
#304 | ||
Condescending Nag
Herbie even got to be a model for all of her future 07's panniers and gear. I know that she's going to enjoy Baja on her 200 because great minds know that........................Quote:
http://by128w.bay128.mail.live.com/a...A3BD118730210|
DR's are like potato chips- you can't have just one. 99' DR650 SEX "The Doctor" 99' DR200 SEX "Herbie" the Looove bike "Life's odyssey is not to arrive at the grave safely, in a well preserved body but rather to skid in sideways, totally worn out,shouting,"...holy shit...what a ride!" Blessed are the flexible, for they will never be bent out of shape The purpose of fun is to have it |
02-16-2008, 10:12 PM
#305 | |
plainsman
Oddometer: 89,011
I've been staring at my 200 out in the garage, longing for summer. The pics aren't working here. I'd like to see the set-up.
_______ |
02-16-2008, 10:23 PM
#306 | |
Condescending Nag
02-16-2008, 10:52 PM
#307 | |
plainsman
Oddometer: 89,011
No, I can't do either. Pictures, pretty please.
_______ |
02-16-2008, 11:32 PM
#308 | |
Condescending Nag
For what it's worth, we'll be seeing a lot more of Superbug (not sure if that'll be the chosen name) when the Baja ride report is done.
02-16-2008, 11:57 PM
#309 | |
Oddometer: 349
02-17-2008, 12:13 AM
#310 | |
Condescending Nag
I'm green with envy.....
02-17-2008, 12:14 AM
#311 |
plainsman
Oddometer: 89,011
Great! Thanks for the lifeline!
_______ |
02-17-2008, 01:33 PM
#312 |
REMF
Oddometer: 8,546
Has anybody upgraded the fork springs? I can't find anything from Race tech, Progressive, etc.
Can someone with a shop manual post the free length spec for the fork springs? I have some misc. ones around I might try to make work. This is for my DR125, but the 200 should be identical. Klay, you said in another thread your Kientech jetting mods got rid of the off-idle hesitation? I still need to try a bigger pilot on my 125. The way it is now it will die as soon as you open the throttle until it is fully warmed. One weird thing I found looking at the parts fiche between the 2 bikes - the 125 has a 40 pilot and the 200 has a 35, unless I am reading something wrong???
Mike S. '09 Bonneville Black AMA MSTA STOC http://autos.groups.yahoo.com/group/...orcycleriders/ |
02-17-2008, 01:47 PM
#313 | |
plainsman
Oddometer: 89,011
I wouldn't expect the jets to be the same between the two bikes, so that sounds right. Have you tried adjusting the pilot screw yet? You might have to take the plug out that covers up the screw. I don't remember which way to turn the screw for more richness. If adjusting the screw is not enough, I would just try going up one size in the pilot screw. I have no experience in changing jets, however, other than following the instructions for the Kientech mods, and also I've cleaned a few carbs.
_______ |
02-17-2008, 02:46 PM
#314 |
REMF
Oddometer: 8,546
Yep, I knew the jets would be different, but my point was the larger CC 200 specs a *smaller* pilot jet.
Already drilled the cap and adjusted the pilot screw, out to 2 1/2 turns. Also have one size bigger main (115 up from 112.5) and shimmed the needle up with 2 washers. I didn't do the 2" hole in the airbox though. Just need some damn weather to check it out and play with it some more (preaching to the choir I know
02-17-2008, 03:01 PM
#315 | |
plainsman
Oddometer: 89,011
_______ |
