Old 06-01-2011, 07:07 PM   #3736
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
Originally Posted by jcetters View Post
Roger on the regular fuel. I'll give that a try. Due to ethanol and carbs not getting along, I thought higher octane would be better. Air filter is new and clean. Mileage is 3800, and has never had a valve adjustment. She doesn't knock or ping when running, so I take that as a good sign. The carb is original with stock settings. As for "choking out" that is the general term I used to describe the issue. Fuel starvation is what the mechanic said...draining the bowl faster than fuel flowing into it. Right now, I have just over one gallon of gas in the tank and I added 2 onces of Seafoam yesterday. When I ride home, I'll go for 70 mph again to see if the additive helped or made no change. I plan to check the plug as well, for gap and/or deposits. -jason
I would open float bowl drain at the carb, set the petcock to "prime" and verify that plenty of fuel flows out. If not, first remove the fuel line from the carb and see if it flows then. If not, you need to pull the petcock and clean the filter screen in the tank. If so, you have an issue in the carb, likely with the float/needle valve.
When you pull the plug, if you can get a new one, just replace it. I have seen many plugs that appear to be fine, but will cause all sorts of trouble that will drive you nuts chasing down other problems, when it just needed a new spark plug. Cheap, and you can always keep one for a spare, if that is not the trouble.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 06-01-2011, 07:29 PM   #3737
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,445
Originally Posted by tbolt View Post
Spent Memorial Weekend riding trails for the first time.
Nice.
The future is bright, fruitful, and positive.
Old 06-01-2011, 10:36 PM   #3738
tlong2
Oddometer: 107
What have you got behind that front tire? Toolkit? and which skidplate is that?
gravel roads and rides to nowhere await me
tlong2 is offline   Reply With Quote
Old 06-02-2011, 06:51 AM   #3739
kafkamars
Oddometer: 40
how fast have you gone? i just took suzi to 80 mph on the highway, i think i could have gone faster too. id love to take her to the Bonneville salt flats with some different sprockets and see how fast she can go.
kafkamars is offline   Reply With Quote
Old 06-02-2011, 08:07 AM   #3740
jcetters
Oddometer: 29
Throttle response
Thanks for all the advice. As of today, I have filled with 87 octane and added some Seafoam. I added some Marvel Mystery Oil to the crankcase as well. So far, the problem is still there. I will change out the plug soon and see what happens. I plan to drain the carb bowl and check the petcock as per "Andyinhilo". That was also recommended by some of the my local friends as well. I'll post an update after all that is complete.
-Jason
jcetters is offline   Reply With Quote
Old 06-02-2011, 09:17 AM   #3741
tbolt
Bypass? What bypass?
tbolt's Avatar
Oddometer: 436
The black tube is a tool tube made from 3" ABS and capped with test plugs. That particular tube didn't survive the trip as it saved my leg from being mangled when a fucking idiot hit me nearly head-on around a blind corner.
The skidplate is by Ricochet: http://www.utahsportcycle.com/store/page309.html
bolty.net - a blog about riding motorcycles [SV650] [DR200]
The ADV Ride Report De-crufter -- [Firefox] [IE]
The ADV Picture Once-inator -- [Firefox]
tbolt is offline   Reply With Quote
Old 06-02-2011, 09:47 AM   #3742
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,445
Mine tops out at about 72 mph. I buried the needle once going downhill with a tailwind. (85 mph+)
Old 06-02-2011, 09:55 AM   #3743
lobsta
Oddometer: 160
rear rack
Originally Posted by jungleplant View Post
Well i have it , we shipped it off to the tester up in washington today for final fit,
bungee hold down points? steel,, all hardware included?oh and about $79.00? and yes free shipping
I have a question though , it fits the year models that have the rear grab bar , anybody know what years that is , mike
I'm riding an 2005 w/ grab handles,don't know about other years.
lobsta is offline   Reply With Quote
Old 06-03-2011, 07:43 AM   #3744
Underider
Oddometer: 5
rear rack
My 2004 version has grab handles also.
Underider is offline   Reply With Quote
Old 06-03-2011, 08:04 AM   #3745
bross
Where we riding to?
bross's Avatar
Oddometer: 4,547
Wife's 2007 has grab handles as well.
Old 06-03-2011, 08:08 AM   #3746
bross
Where we riding to?
bross's Avatar
Oddometer: 4,547
Hey guys iam trying to develop the DR200 rack, I already make a Dr250/350 and DR650 racks but need info here, are they close , anybody have a rack
send pics ok, mike
Sorry no rack on my wife's currently but can send you pics, measurements etc. If you can get me a mock up in the next 2 weeks we'd be willing to test it for you on a 4 day dual sport ride we're going on, Jun 17th.
Old 06-03-2011, 02:45 PM   #3747
PerroLoco
PerroLoco's Avatar
Oddometer: 17
nice idea with the test plugs. I recently made a pvc toolkit for my bike and ended up putting on a thread and screw cap, but the test plug would have been nicer...
PerroLoco is offline   Reply With Quote
Old 06-05-2011, 06:56 PM   #3748
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,846
DR200 Rack is finaly here
Been working of this one for a while now, we found a nice gentelman up in washington state that wanted one so we prototyped it together , many thanks to Mr. Zwar should be in production in a few , mike
jungleplant screwed with this post 06-06-2011 at 04:18 PM
jungleplant is offline   Reply With Quote
Old 06-05-2011, 07:34 PM   #3749
tbolt
tbolt's Avatar
Oddometer: 436
Originally Posted by Ladybug0048 View Post
Good job TBolt. Please do post a ride report in Day Trippin.
Just posted part 1: http://advrider.com/forums/showthread.php?t=694827
Yep, it's nice being able to access the tools packed in the tube from either end.
Old 06-05-2011, 10:31 PM   #3750
Sateev
Oddometer: 118
Exactly what I'm looking for. I'm in for one, whenever they're available.
Sateev is offline   Reply With Quote
Times are GMT -7.   It's 12:44 PM.
