Old 08-22-2011, 08:22 PM   #4111
canuck76
canuck76's Avatar
Oddometer: 160
Originally Posted by KF7GTH View Post
Stalling:
OK, the wifes DR200 likes to stall at idle- about 1200 miles on her now. I thought when it was new it was cold blooded, but this weekend it was plenty warm out and we had gone 50+ miles and it wants to die at stoplights. Pretty F-ing annoying. Carburetors are not my specialty- but I suspect someone here can tell me what I need to do to get it right. Thanks in advance oh wise ones.
Could be bad gas, or clogged up carb. Try a small dose of "heet" then a good shot of SeaFoam. The Heet will help absorb any water in the gas, then the SeaFoam will help unclog carb. The Seafoam will not be immediate, I have heard instances that it took numerous SeaFoam treatment. Good luck
Canuck76
2006 BMW R1150GSA
Eventually, socialists run out of other peoples' money
canuck76 is offline   Reply With Quote
Old 08-22-2011, 08:23 PM   #4112
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,394
A simple fix would be to turn the idle screw up a little on the outside of the carb. My bike has about 2000 miles on it. When I was riding with some experienced guys last fall, one did that and it never stalled again after warm up.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 08-22-2011, 09:42 PM   #4113
KF7GTH
KF7GTH's Avatar
Oddometer: 152
I have tried several times adjusting the idle screw on the side of the carb- May play with it some more- weird thing is that several times I have and even a miniscule adjustment will send the idle WAY too high. Where is the idle mixture screw hidden on this thing?
'09 Kawasaki KLR 685 -Black
'09 Suzuki DR 200se -Black- Mommas
KF7GTH is offline   Reply With Quote
Old 08-22-2011, 09:44 PM   #4114
KF7GTH
KF7GTH's Avatar
Oddometer: 152
Don't think it's bad gas, I have filled my KLR from the same hose each time the DR has been filled. I may throw a bit of heet and or seafoam in the tank though- Thanks
Old 08-22-2011, 09:48 PM   #4115
tbolt
Bypass? What bypass?
tbolt's Avatar
Oddometer: 436
Messing with the idle simply covers up the symptoms of the problem.
The idle mixture screw is under a brass plug near the front of the carb. You'll have to pull the carb, drill out the plug, and carefully remove it.
bolty.net - a blog about riding motorcycles [SV650] [DR200]
The ADV Ride Report De-crufter -- [Firefox] [IE]
The ADV Picture Once-inator -- [Firefox]
tbolt is offline   Reply With Quote
Old 08-22-2011, 09:52 PM   #4116
KF7GTH
KF7GTH's Avatar
Oddometer: 152
Thanks tbolt- Is there a baseline for how many turns out/in to go with it?
Old 08-22-2011, 10:29 PM   #4117
SHO_GuN
Adventurerer
Oddometer: 44
Stalling:
My bike had this exact symptom - in my case it was the o-ring on the needle valve assembly causing the problem.
SHO_GuN is offline   Reply With Quote
Old 08-22-2011, 10:58 PM   #4118
tuffstuff
Livin' Life
tuffstuff's Avatar
Oddometer: 516
Stalling:
I am currently having the same problem and turning the idle screw up on it really is only getting me by until I get home and can have someone look at it. It isn't stalling now but I have to play with the clutch so it doesn't over rev when idling. It's really annoying. Plus, it is now sputtering when I am riding steady around 40 mph. I hope I don't need a new carb and am hoping someone can rebuild mine but I am sure the carb is the problem in my case. Interesting so many have this issue.
2014 Colorado Ride Report
tuffstuff is offline   Reply With Quote
Old 08-23-2011, 01:48 AM   #4119
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,686
All of the past several posts are indicative of plugged jets or leaking needle seat o-rings. When the slow speed circuit is overlean, the idle will want to run away or not idle at all, and when the mid range and main circuit is lean that will cause missing, hesitation and backfiring.
Time to clean those carbys. Remember that the little DR has small jets and passages and even though it may look clean it likely isn't.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 08-23-2011, 10:26 AM   #4120
tbolt
tbolt's Avatar
Oddometer: 436
After you remove the plug, turn the mixture screw in until it stops and remember how many turns it was.
Old 08-23-2011, 03:45 PM   #4121
tuffstuff
Livin' Life
tuffstuff's Avatar
Oddometer: 516
Thanks for this! I will learn to clean a carb when I get home from this trip. I have my bike running but it sure wants to rev up if I don't control it with the clutch when I am idling. I really hope a good cleaning does the trick because I don't want to spend $300 on a new carb like I was told I need to do here.
Old 08-23-2011, 07:10 PM   #4122
trackman11
Oddometer: 1
Originally Posted by FlyingFinn View Post
Headlight cover is from a DRZ400 and the fender is a generic Acerbis supermoto.
The DRZ has a smaller headlight than the 200 so you have to enlarge the headlight opening the DRZ cover. I think the blinkers had to be relocated too, can't remember for sure.
Mikko
what did you use to enlarge the headlight cover? a sander?
trackman11 is offline   Reply With Quote
Old 08-23-2011, 08:13 PM   #4123
KF7GTH
KF7GTH's Avatar
Oddometer: 152
Thanks guys- I will have to pull the carb and clean it and check the mixture screw. Geez, and here I thought this thing would be less trouble than a KLR.
Old 08-23-2011, 09:05 PM   #4124
tbolt
tbolt's Avatar
Oddometer: 436
You have a KLR bored out to 685 and you're complaining about drilling out a mixture screw plug?
Old 08-23-2011, 09:09 PM   #4125
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,397
My wife crunched the numbers recently, and after about 14,000 miles on each bike and ten years time, our two DR200s have paid for themselves in saved fuel and other costs. All further mileage will be pure profit and fun. Great way to look at it.
windigo
Times are GMT -7.   It's 02:35 AM.
