08-23-2011, 08:13 PM
#4126 | |
Oddometer: 141
Nah, just complaining about another bike to work on. Next thing you know, I'll be getting carb kits, new pipe, and all kinds of crazy shit for this one too. It's a disease, you know... And it's not even "my" bike
'09 Kawasaki KLR 685 -Black '09 Suzuki DR 200se -Black- Mommas |
08-23-2011, 08:17 PM
#4127 |
Motorcyle Stuff
Oddometer: 1,792
That why i build racks
08-26-2011, 09:43 AM
#4128 |
plainsman
Oddometer: 89,162
Got a problem with the battery going dead. The battery is only a year old. With the bike running at idle, the voltage reads 13.9 volts. Rev the motor, and it drops to 13.4 volts. Regulator? Stator?
_______ |
08-26-2011, 09:57 AM
#4129 | |
Bypass? What bypass?
Oddometer: 436
Charging output check Start with a fully charged battery (important!) Start engine and run it at 5000 r/min Measure DC (25V) between + battery terminal and - terminal. If tester reads under 13V or over 16V, check the AC generator no-load performance and the RR. |
08-26-2011, 10:07 AM
#4130 |
plainsman
Oddometer: 89,162
It checks out okay according to that. Maybe I'll assume the battery is faulty, even though it's young, and start by replacing it.
_______ |
08-26-2011, 10:35 AM
#4132 |
plainsman
Oddometer: 89,162
I'll probably just get another sealed lead-acid Yuasa battery, but I've got one of those fancy ones in mind for my DR350. The batteries in both of the 200s right now are generic ones made in China. Same source as the one in my DR650, and that has been lasting very well.
_______ |
08-27-2011, 02:11 AM
#4133 |
Oddometer: 9
Can someone confirm that the DR200 has a "Wasted Spark" type of ignition system, firing the plug on the compression and exhaust stroke? According to Wiki, many four stroke singles use this type of ignition, but I can't find any related info specifically for the DR200.
I just installed a TTO tach/hourmeter, and had to set the PPR (pulse per rev) at "1" to get the tach to indicate properly. By the way it works great, and is small enough to stick on the triple clamp. About $30 from Amazon. |
08-27-2011, 03:11 PM
#4134 | |
Oddometer: 1,302
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper |
08-27-2011, 05:47 PM
#4135 |
Oddometer: 224
do u have a reference for that? I have not seen that in the tech manual, usually only a multi-cylinder engine will use a wasted spark system.
thanks
1981 CB900C, 1998 GL1500C Valkyrie 2007 DR200 "Our Constitution was made only for a Moral and Religious people. It is wholly inadequate to the goverment of any other." John Adams 10/11/1798 "If we ever forget that we're one nation under God, then we will be a nation gone under" Ronald Reagan |
08-28-2011, 08:49 AM
#4136 |
Dreaming of a DS
Oddometer: 18
Newb question
looking at a little 200 for myself and i have a question. is it possible/has anyone put in a larger motor?
08-28-2011, 09:45 AM
#4137 | |
Oddometer: 436
![]() That would be a lot of work for not a whole lot of gain. You'd be better off with a 350 or DRZ-400. |
08-28-2011, 11:57 AM
#4138 |
Oddometer: 1,302
No reference for it, but since the ignition is timed from the crank rather than the cam, like the old Honda singles and twins, it has to fire once each revolution of the crank. So one spark on the compression stroke, and one on the exhaust.
08-28-2011, 01:01 PM
#4139 |
plainsman
Oddometer: 89,162
Just realized the 200 uses the same battery as the DR350. I popped in a feeble spare I had for the DR350, and the wife's 200 is running again.
_______ |
08-28-2011, 06:11 PM
#4140 |
Oddometer: 1,302
Just as I was going to suggest that you swap batteries between the 200s.
