Old 12-01-2011, 03:57 PM   #4576
motocikl
Oddometer: 63
ladybug, regarding cold starts, I've found that holding the throttle open does NOT help. For about a month or so last winter I was constantly wondering what was wrong with the bike, never wanting to start. I assumed that holding the throttle open, as the owners manual says, would help. Then one day, I tried just hitting the yellow button without touching the throttle. Started perfectly. From then on, I've never touched the throttle when starting and the bike always starts right up.
Of course, I do apply the choke. Once it's started I let it sit for a minute or so. If I'm in a hurry I'll get going and get off the choke in a mile or so.
I have the Kientech jet kit and exhaust mod, by the way.
motocikl is offline   Reply With Quote
Old 12-01-2011, 04:02 PM   #4577
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,402
Also, I have the same mods with FMF. Pull the choke all the way out, touch the start button but not the throttle works every time. My DR650 is the same way. Cold blooded bikes that run great once they get warmed up.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 12-01-2011, 04:03 PM   #4578
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,061
^^^ Mine pops off every time using this approach. The bike will not start when cold if it's not on the idle circuit.
windigo
Old 12-01-2011, 09:24 PM   #4579
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 550
White lithium grease
I need to lubricate the levers following the periodic maintenance, does it matter if I use the tube or aerosol white lithium grease?
thesurvivalist is offline   Reply With Quote
Old 12-01-2011, 09:27 PM   #4580
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,061
Doesn't matter what kind of grease...that's a non-critical application.
windigo
Old 12-01-2011, 09:37 PM   #4581
havocdog
havocdog's Avatar
Oddometer: 127
Turn signal issue
06 model. Right turn signals work fine. When I turn on the left turn signals, front left stays on (no blinking) and rear left is off. I swapped the rear bulbs - same problem on left, so it is not the bulb. Where do I look next?
Can you see me now?
dr200 f650gs r60/6 ttr125 crf230f crf150f amf(moped)
havocdog is offline   Reply With Quote
Old 12-01-2011, 09:45 PM   #4582
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,061
I had the same problem. If I recall, the positive wire to the turn signal was broken off...I think inside the turn signal stalk. I soldered it back together.
windigo
Old 12-01-2011, 10:47 PM   #4583
havocdog
havocdog's Avatar
Oddometer: 127
Thanks! I'll check that out. Left stalk was bent recently when the bike rolled backwards down a hill.
Can you see me now?
Old 12-01-2011, 10:58 PM   #4584
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 623
Same exact thing happened to mine this summer. Pulled the signal apart, resoldered it, and it's been fine for the past 5 months.
Regarding the cold starts, it was ~25 this morning...thick coat of frost on everything. The starter was a little hesitant, but she fired right up with full choke. I had to wait a good minute though of it sitting there idling before it would take any more throttle to actually get moving.
godwinmt is offline   Reply With Quote
Old 12-01-2011, 11:03 PM   #4585
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,061
I'm absolutely sure that's it, then. Or where the wire feeds into stalk.
windigo
Old 12-02-2011, 06:45 AM   #4586
DR BrianO
DR BrianO's Avatar
Oddometer: 41
Headlight Adjustment
Took the bike out last night after dark, since it gets dark around here by 6pm this time of year. My low beam is positioned perfectly, but my high beam is high and to the right. I saw that there is three screws in the front of the light for adjustment. Is there a way to adjust just the high beam?
Thanks.
DR BrianO is offline   Reply With Quote
Old 12-02-2011, 10:33 AM   #4587
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,061
Thanks.
That's odd. It could be an internal flaw in the headlight. No, there isn't any way to adjust the beams independently.
windigo
Old 12-02-2011, 11:26 AM   #4588
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Originally Posted by SHO_GuN View Post
Before you buy a Raptor petcock, read THIS and then decide what petcock to get.
Perfect ordered from local shop installed without any issue so simple its painful! Now the little DR has a manual fuel petcock. Thanks for the info!
rotten is offline   Reply With Quote
Old 12-02-2011, 12:30 PM   #4589
Highaltidude
Oddometer: 71
Thanks.
I have not taken apart the stock headlight. Is it a separate bulb and housing?
If so, if the bulb were rotated incorrectly, it could aim "to the right"......
Not sure how to get around it being too high though.....
Chuck
Highaltidude is offline   Reply With Quote
Old 12-02-2011, 01:04 PM   #4590
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,061
Chuck
It's an H4 halogen bulb inserted into a reflector mirror. I think the tabs would prevent inverted installation, but perhaps someone could have forced it seated improperly...
Or hey. Maybe somebody installed the whole headlight upside-down.
windigo
Times are GMT -7.   It's 05:13 PM.
