Old 12-14-2011, 01:08 PM   #4636
bross
Where we riding to?
bross's Avatar
Oddometer: 4,585
Originally Posted by ben2go View Post
Thanks.I'll have to check that product out.Is it good for cables that spin,such as a tach cable?
Not sure but I would think it would be fine, see the text below for uses...
Note the last line caution, it is nasty stuff and stained my fingers black for a few days.
Iron Braid is pleased to introduce Bike Aid ® (also known as Dri-Slide), a multi-purpose lubricant made by Lilly Industries, that coats and protects better than any other commercial substance. Unlike other oil based lubricants, which attract harmful particulates that can cause damage, Bike Aid goes on wet but stays on dry. Made from a naturally occurring ore similar to graphite, Bike Aid (Molybdenum Disulfides or MoS2) is ideal for cables and other key mechanical pivot points. Avoid downtime and replacement costs, by using the first choice of professionals—Bike Aid.
Features & Choices:
Bike Aid is a petroleum based liquid medium that can be applied to virtually any surface needing lubrication.
Goes on wet but dries to leave a long lasting film that resists wear, water, dirt and other harmful UV elements.
Because it goes on in liquid form, Bike Aid can penetrate deep down into the smallest spaces.
Because Bike Aid is a dry film lubricant, it may be used in extreme environmental conditions.
Withstands pressure up to 100,000 pounds per square inch.
Bike Aid can even help restore worn or corroded parts.
The perfect lubricant for all general and household uses.
Caution: Bike Aid can stain fabrics.
Old 12-14-2011, 05:58 PM   #4637
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,618
Note the last line caution, it is nasty stuff and stained my fingers black for a few days. THANKS FOR THE HEADS UP.I WEAR GLOVES WHEN I WORK, BUT CHEMICALS CAN SOAK THROUGH THEM.
Features & Choices:
Thank you for posting this info.Have you used this product on other areas of a bike besides the cables?
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 12-14-2011, 06:22 PM   #4638
wavygravy87
wavygravy87's Avatar
Oddometer: 163
Used engine on Craigslist
Hey guys I don't have a DR200 and I don't know this guy, but I found this on Craigslist under Birmingham, Alabama. $40 for an engine. Thought it might help someone.
http://bham.craigslist.org/mcy/2730672551.html
You'll never make it out of this life alive...try and enjoy yourself while you can
2009 Suzuki DR650
2013 Yamaha Super Tenere
wavygravy87 is offline   Reply With Quote
Old 12-15-2011, 07:04 AM   #4639
jeepkevin
Oddometer: 76
I recently picked up a 96' Dr200 with 2100 miles. I then started reading this thread from the begining. Inormation overload!! I did the Keintech carb and exhaust mods, Paint the frame silver, recovered the seat in black, new bars, tires, battery, greased the swing arm pivots, what a sweet little bike. Now I have new black fork boots on order to replace to yellow ones. I want to change the fork oil for good measure at the same time. Is it 7.07 oz per leg? Local Cycle Gear stocks all weights, picked up some 10wt to start with. I'll just stay with the same brand untill I figure out what weight works for me.
So 7.07oz per fork leg? or at least as a starting point? Thanks for your help.
jeepkevin is offline   Reply With Quote
Old 12-15-2011, 10:39 AM   #4640
bross
Where we riding to?
bross's Avatar
Oddometer: 4,585
Nope, just the cables. It's not a very big bottle and I tend to waste quite a bit just overflowing the top and then quite a bit will still run out the bottom once you see it appear at the other end of the cable. With too many bikes and quads in the garage I use other lubes for everything else.
Old 12-15-2011, 11:32 AM   #4641
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,583
Most of the time, they go by volume when they tell you how much fork oil per leg. I believe it's 309 ml.
http://www.scribd.com/doc/40540261/DR-200-Owners-Manual
Well, I ain't always right but I've never been wrong.
Seldom turns out the way it does in a song.
Old 12-15-2011, 12:04 PM   #4642
jeepkevin
Oddometer: 76
Awsome, thank you for your help!!
Old 12-16-2011, 05:47 PM   #4643
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
That is local to me, though i'm sure if I bought it it would be sat in the corner doing nothing.
thesurvivalist is offline   Reply With Quote
Old 12-17-2011, 07:17 AM   #4644
straight cut
Oddometer: 136
308ml or 10.41 USoz of 10wt or if you set the fork leg verticaly in a vice remove the springs,compress the inner tube fully and the oil level is 179mm or 7.0 inches from the top
straight cut is offline   Reply With Quote
Old 12-19-2011, 12:12 PM   #4645
DR BrianO
DR BrianO's Avatar
Oddometer: 41
Finally a picture of the bike
I have had this for a few months now. 1400 miles on it, never been offroad.
1999 Suzuki DR 200se (fixed and sold)
1985 Honda Spree (fixed and sold)
1960 Honda S90 (restored and sold)
DR BrianO is offline   Reply With Quote
Old 12-19-2011, 12:17 PM   #4646
DR BrianO
DR BrianO's Avatar
Oddometer: 41
Added additional lighting
I am not sure how to add more than one picture in a message.
I also added a second head lamp and a second rear marker light. The head lamp is a 1 watt LED that has a low, high, and super flash beam. I just clamped to the handlebars on the side of the plastic cowling. It is very bright LED that came off a triathalon bike I owned. I keep it on super flash during the day for riding and just on at night. The rear marker light is about 4 times brighter than the stock tail lamp. The difference from the rear is awesome at night.
Old 12-19-2011, 12:55 PM   #4647
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,408
Use smugmug or photobucket to add as many pics as you like.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 12-20-2011, 01:56 AM   #4648
jimmesa
jimmesa's Avatar
Oddometer: 102
pics...
How to post an image
Hope this helps! Jim
'08 Kawasaki Versys
'95 Suzuki DR350S
'06 Kawasaki KLX250
'02 Suzuki DR200SE
jimmesa is offline   Reply With Quote
Old 12-20-2011, 06:29 AM   #4649
dalehazelton
Oddometer: 47
Re: Note the last line caution, it is nasty stuff and stained my fingers black for a few days.
Something I learned long ago, when trying to wash ink or grease or ash (from charcoal or the woodstove) off your hands use the COLDest water you can stand. Your pores close up and your hands will be much cleaner than if you used warm water. It really works.
dalehazelton is offline   Reply With Quote
Old 12-20-2011, 08:26 AM   #4650
thesurvivalist
Backcountry Rider
Oddometer: 551
Does anyone know if TKC 80 tires will fit the dr200? I did a search for the stock trail wing tires and can't seem to find them available on the tkc 80.
Times are GMT -7.   It's 01:55 AM.
