Old 01-04-2012, 05:44 AM   #4711
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,648
18*F here this morn.Dry and the air was dead still,almost creepy still.Didn't make any sense for my area.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 01-04-2012, 08:59 PM   #4712
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
Can someone sell me a rear right turn signal, left too if its available. My wife dropped my bike by accident and busted the casing.
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 01-05-2012, 07:41 AM   #4713
DR BrianO
DR BrianO's Avatar
Oddometer: 41
Thumb Joe Rocket Manta Tank Bag
My wife got me this tank bag for Christmas and I am very pleased with it. It fit the odd gas tank perfectly and is low profile enough to stay our of the way. I just wanted something to put keys, wallet, sunglasses, garmin, and a small jacket or extra gloves.
I just thought I would pass on the information.
1999 Suzuki DR 200se (fixed and sold)
1985 Honda Spree (fixed and sold)
1960 Honda S90 (restored and sold)
DR BrianO is offline   Reply With Quote
Old 01-05-2012, 08:48 AM   #4714
motocikl
Oddometer: 63
I finally bought some riding boots but now have run into the dreaded shift lever problem. It's really hard to get the boot under the shift lever to shift up. Some people have mentioned adjusting the shift lever but I don't really understand what you mean. Can someone explain in more detail? Perhaps post some pictures?
Thanks.
motocikl is offline   Reply With Quote
Old 01-05-2012, 10:58 AM   #4715
straight cut
Oddometer: 136
Motocikl
On one end of the lever is a 10mm bolt you will need to remove this completely to adjust the lever
slide the lever off ,clean up the shaft and grease push the lever back on in the new position and tighten the bolt
straight cut is offline   Reply With Quote
Old 01-05-2012, 12:00 PM   #4716
thesurvivalist
Backcountry Rider
Oddometer: 551
Thanks.
You can undo the shift lever and slide it off. you can then put it on a higher spline which gives a bit more clearence. One fella on here grinded s ection of the lever to clear the engine casing. I maxed out the height of my gear lever and it still would not clear my alpinestars tech 3 boots. I sold them about bought some tourmaster solution 2.0 boots which are so far awesome.
Again does anyone have a right rear turn signal for sale?
2015 Honda PCX
Old 01-05-2012, 12:11 PM   #4717
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,605
The turn signals can be swapped between right and left without any problem.
Well, I ain't always right but I've never been wrong.
It seldom turns out the way it does in the song.
Old 01-05-2012, 12:26 PM   #4718
thesurvivalist
Backcountry Rider
Oddometer: 551
Cool beans do you have a spare one Klay, there are reproduction ones on ebay for $19.99 but don't know the quality of them and how compatible they are.
2015 Honda PCX
Old 01-05-2012, 12:30 PM   #4719
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,605
I have spares, but I'm not willing to part with them.
Old 01-05-2012, 12:53 PM   #4720
thesurvivalist
Backcountry Rider
Oddometer: 551
A brand new factory suzuki pair just came up on ebay, got them for $45.00.
2015 Honda PCX
Old 01-06-2012, 07:36 AM   #4721
thesurvivalist
Backcountry Rider
Oddometer: 551
Is there anyone that has fitted heared grips to their dr200?
2015 Honda PCX
Old 01-06-2012, 08:54 AM   #4722
motocikl
Oddometer: 63
Originally Posted by straight cut View Post
Motocikl
So, in the attached picture, I would remove #32 and then just angle the lever upwards on #25?
I will try that but it seems like it may only be a slight improvement. Does anyone know if there are any aftermarket shift levers available? Perhaps I could use one from another bike?
Old 01-06-2012, 09:41 AM   #4723
straight cut
Oddometer: 136
YES thats the one
I had to relocate mine for my size10 Sidis
Old 01-06-2012, 10:24 AM   #4724
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 667
Yeah, you undo the 10mm headed bolt on the lever, slide it off the spline, rotate it up 1 spline, and reattach it. I had to grind mine a bit to get it to clear:
godwinmt is online now   Reply With Quote
Old 01-06-2012, 10:52 AM   #4725
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 11,164
I have heated grips on my bike. I like farkles and warmth.
Ladybug0048 is offline   Reply With Quote
Times are GMT -7.   It's 03:27 PM.
