Old 01-08-2012, 01:58 PM   #4741
KORACK
KORACK's Avatar
Oddometer: 13
Originally Posted by Klay View Post
have
of
KORACK is offline   Reply With Quote
Old 01-08-2012, 02:41 PM   #4742
KORACK
KORACK's Avatar
Oddometer: 13
Originally Posted by Trailrider200 View Post
www.sudco.com has everything in their catalog, pilot's, mains, and needles.
Thank you......never heard of sudco but will check it out.
Old 01-08-2012, 04:09 PM   #4743
SHO_GuN
Adventurerer
Oddometer: 44
Originally Posted by motocikl View Post
What about moving the footpeg back? Any information on that?
Someone else did just that.
It is in this thread within a month or two - I think the word "weld" is in the post.
SHO_GuN is offline   Reply With Quote
Old 01-08-2012, 04:43 PM   #4744
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 623
What do you think about cutting a notch out of the never itself where it hits the engine casing? Has anyone done that? Will it weaken the lever too much?
From 2 pages ago, here's what I did with mine to rectify the problem. Precisely as you said. This picture was done with a dremel which is all I had available at the time. When I got back home from school, I reground it with an angle grinder and it looks a lot better.:
Originally Posted by godwinmt View Post
Yeah, you undo the 10mm headed bolt on the lever, slide it off the spline, rotate it up 1 spline, and reattach it. I had to grind mine a bit to get it to clear:
godwinmt is offline   Reply With Quote
Old 01-08-2012, 07:34 PM   #4745
motocikl
Oddometer: 63
Wow, not sure how I missed that. I guess because it was on the bottom of the page. Thanks for the info.
I still want to leave this kind of thing as a last resort. I don't have easy access to power or welding tools.
I am waiting on a reply from the Procycle folks. They have a DR350 lever which looks like it may fit.
motocikl is offline   Reply With Quote
Old 01-08-2012, 11:00 PM   #4746
titont
Oddometer: 13
Yeah, that was me. Had same problem with my 12" size MX boots and clearence. Removed footpegs, took them to a welder guy, who cut console shorter and welded footpeg back to very close to the bolt.
titont is offline   Reply With Quote
Old 01-11-2012, 10:40 PM   #4747
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 550
I'm thinking about fitting some saddlebags but they are like to touch the exhaust heat shield. If I was to fit some kind of heat insulating material between the exhaust and the heatshield would it prevent exhaust heat from disapating?
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 01-11-2012, 10:47 PM   #4748
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,992
On my DR350, I smashed a large beer can and wired it in place. Works great. On the 200, I run plastic Ortlieb bags and they lay directly on the muffler guard (the little guard on the stock muffler) and they don't melt. I'd be a little nervous about this in very hot weather, though.
windigo
Old 01-11-2012, 10:52 PM   #4749
thesurvivalist
Backcountry Rider
Oddometer: 550
Beer can, awesome. Also will these tank bags work well on the dr200?
http://www.ebay.com/itm/Moose-BIG-HO...item43ac343ab0
2015 Honda PCX
Old 01-11-2012, 10:58 PM   #4750
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,992
Don't know. They seem kind of small.
windigo
Old 01-12-2012, 05:49 AM   #4751
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 10,943
I'm looking for a new set of tank panniers too. The ones I had were made for ATVs but they are no longer made.
Ladybug0048 is offline   Reply With Quote
Old 01-12-2012, 08:25 AM   #4752
Highaltidude
Oddometer: 71
Saddle Bags
Originally Posted by Highaltidude View Post
Got em, got em mounted up.
I was a bit uncomfortable w the part of the right bag that hung below the side panel.... Just sitting in the garage it looked fine, but it didn't seem like it would take much to push it into the pipe..... So I fabbed up a bracket to keep it away.....
Here's a shot of the mounted bag (with just a beach towel shoved in it):
I'm impressed with the quality and fit of this product.....
Chuck
Chuck
Highaltidude is offline   Reply With Quote
Old 01-12-2012, 10:08 AM   #4753
thesurvivalist
Backcountry Rider
Oddometer: 550
What is the model name of the wolfman bags? I think the moose expedition bags hold more.
2015 Honda PCX
Old 01-12-2012, 12:11 PM   #4754
MatBurn
dropout
MatBurn's Avatar
Oddometer: 29
Question replacement 2003 DR200 starter motor seals
my starter's main seal is leaking and the brushes are about spent. i cleaned all the oil out yesterday to get it to start and know it is just a matter of time before i have to do it again.
down here (southern chile), apparently you need the physical dimensions of the seals to ask for them, not the part number, like on a bearing. can anybody tell me this? i don't want to pry the old seal out until i am SURE i can get a replacement on the spot.
same question for the clutch seal on the top of the case...
my breather must be plugged to be losing oil up high like this, huh?
thanks for any tips. i just posted about my trip in south america on ride reports.
MatBurn is offline   Reply With Quote
Old 01-12-2012, 12:16 PM   #4755
Highaltidude
Oddometer: 71
http://www.wolfmanluggage.com/Enduro...ddle_bags.html
Chuck
Times are GMT -7.   It's 11:06 PM.
