01-13-2012, 10:12 AM
#4771 | |
Backcountry Rider
Oddometer: 362
Buell Ulysses Xb12X Suzuki DR200SE 2007 Sold Custom Leather Work-Made In England www.lordofleather.com https://www.youtube.com/user/frontiercolorado |
01-13-2012, 10:24 AM
#4772 | |
Carpe Diemer
Oddometer: 91
Yup, I'll be taking that across the river to the nearest bike shop to have the work done. I can perform basic maintenance on my bike but this is where I start to break things and start costing myself more money... ![]() Thanks for the help!!!! |
01-13-2012, 11:14 AM
#4773 |
Oddometer: 63
01-13-2012, 12:41 PM
#4774 | |
They call me Crash
Oddometer: 340
Also, we got snow yesterday so I figured I'd ride the DR in this morning :) 14 degrees :) Damn coldblooded bike takes forever to get moving in the morning.
01-13-2012, 01:51 PM
#4775 |
plainsman
Oddometer: 89,127
I put on a lot of winter miles on my 200 a few years ago. The muffler rusted out. Got a new cast-off one from an inmate here.
Also, the Kientech jet kit plus messing with the idle screw really takes away much of the cold-bloodedness of the bike.
_______ |
01-13-2012, 04:00 PM
#4776 | ||
Stuck @ Home! >=^(
Oddometer: 1,091
http://www.jcwhitney.com/glossy-moto...?filterid=u0j3 http://www.jcwhitney.com/travel-trun...wx?filterid=u0 http://www.jcwhitney.com/motorcycle-...?filterid=u0j3 http://www.jcwhitney.com/travel-trun...wx?filterid=u0
Manic Cycles=My Facebook Page |
01-13-2012, 04:18 PM
#4777 |
Backcountry Rider
Oddometer: 362
How much did the windshield set you back? I have a moose racing number plate bag on mine so I'd have to remove it if I was to go for the windshield. Looking good, nice jacket.
01-13-2012, 07:05 PM
#4778 | |
They call me Crash
Oddometer: 340
The windscreen I think was ~$100 shipped, but I'm not sure. Peter is really nice to deal with over there. I put 2 rows of studs in the knobbies today. Made a night and day difference on the slick stuff. |
01-13-2012, 07:14 PM
#4779 | |
plainsman
Oddometer: 89,127
When I was riding in really cold weather (like well below freezing) all the time a few years ago, the warm-up time was just too long, and it's cured now. It was always okay 35 degrees and up, just a little cold-blooded. It'll probably help if you just richen up the idle circuit, but I found that the lean spot was somewhere off idle. It would pop off every time, even down to ten degrees, and sit there and idle, but you couldn't give it any throttle for a few minutes. Now with the jetting changes, it's much better. Ladybug, I bet you have a weak battery in yours. Mine always pops right off, even below freezing.
_______ |
01-13-2012, 08:13 PM
#4780 |
They call me Crash
Oddometer: 340
It acts the same way you describe...idle seems fine,even a bit rich, but somewhere north of it when the throttle cracks, it says hell no i won't go.
01-13-2012, 09:00 PM
#4781 |
Oddometer: 223
[QUOTE=godwinmt;17745790]Any issues running the jet kit with the stock airbox configuration and exhaust? I think i'm going to play around with the screw on the bottom of the carb and see if I can get it to behave a bit better. It's not bad as long as you let it idle for a couple minutes and warm up.
QUOTE] just open up the idle mixture screw 2 to 3 turns open. the stock air box openings provide more than enough air for the size of the stock carb size. also try removing the metal screen inside of the air filter for extra airflow. hard starting esp when cold is always the idle mixture screw. with stock exhaust a jet kit is not required. I opened up the stock exhaust, by drilling the epa baffle. nice upgrade with the 3 turns open. I believe the needle also needs to be shimmed after the exhaust mod, but the weather changed to winter, so this testing will not be done until 60-70 degree weather is back.
1981 CB900C, 1998 GL1500C Valkyrie 2007 DR200 "Our Constitution was made only for a Moral and Religious people. It is wholly inadequate to the goverment of any other." John Adams 10/11/1798 "If we ever forget that we're one nation under God, then we will be a nation gone under" Ronald Reagan |
01-13-2012, 09:17 PM
#4782 |
plainsman
Oddometer: 89,127
Definitely not the idle mixture screw, then, because they start very well.
_______ |
01-14-2012, 07:20 AM
#4783 |
Oddometer: 71
Cold air is denser than warm air. Thus a lean condition, even if not obvious normally, will be made worse in colder weather.....
So if your bike runs worse in cold weather showing lean symptoms, time to richen it up..... Chuck |
01-15-2012, 02:46 PM
#4784 |
Oddometer: 71
Top Speed
Who says these bikes can't do 85mph on the interstate?????
:-) Chuck
01-15-2012, 04:08 PM
#4785 |
Backcountry Rider
Oddometer: 362
The dr looks nice in black. I've had mine up to 75mph. I noticed since I've been taking my dr on the interstate it goes through oil faster. Have you taken your dr up pikes peak does the carb need to be altered at all to handle the altitude.
