01-16-2012, 08:50 PM
#4801 |
plainsman
Oddometer: 89,071
One of the bolts in the sump I believe is actually a locater for the shift drum, if I remember correctly. But I don't know why they aren't both listed. Maybe the bolt for the transmission parts is listed in the transmission schematic.
_______ |
01-16-2012, 09:15 PM
#4802 |
Backcountry Rider
Oddometer: 362
Bingo! I don't know if this is a repost but i've just found the DR200se parts catalogue online as a pdf.
http://www.suzuki.com.mx/motos/img/P...ones/DR200.pdf The oil drain plug is part 09247-14026 It is in the oil pump diagram, i'm definately ordering a few of these.
Buell Ulysses Xb12X Suzuki DR200SE 2007 Sold Custom Leather Work-Made In England www.lordofleather.com https://www.youtube.com/user/frontiercolorado |
01-16-2012, 09:20 PM
#4803 |
Backcountry Rider
Oddometer: 362
While i'm placing an order, the stock brake pads come up as 59300-42880 for around $25, it doesnt state whether this is for one side only or both I'm assuming its for both can you confirm this clay?
01-16-2012, 09:32 PM
#4804 |
plainsman
Oddometer: 89,071
They aren't going to sell them separately. That would be very unlikely.
_______ |
01-17-2012, 05:40 AM
#4805 |
Oddometer: 154
brake pads 2005 dr200
2 in a box. Wore outs on the left.
01-17-2012, 06:43 AM
#4806 |
ADVenture Capitalist
a little overkill. Plus, your X rear straps will pull the rears of the bike toward the center. Tie rear wheels straight back. Only takes three straps to hold down a motorcycle. I was running 60mph down dirt roads this weekend with bikes on the trailer. Loop around forks at lower triple clamp, straps pulling between front of tire arc and axle centerline approx 18-24" outside the bike's centerline, then a strap from rear wheel to rear of truck/trailer/etc pulled tight to keep rear from swinging L/R and bouncing up. I've seen the bike fly up over railroad tracks.
Proper way to tie down a motorcycle for transport: http://advrider.com/forums/showpost....2&postcount=52
Not an ACTUAL motorcyclist |
01-17-2012, 02:01 PM
#4807 |
Oddometer: 54
bought this 2009 from the orignal owner last month who bought it in march 2011 (2009 left over). I already put kintech jet kit, fmf pipe, pirelli mt-21 tires and have a ricochet skid plate on order. It might be up for sale shortly, Im already wanting a bigger bike.
01-17-2012, 02:22 PM
#4808 | |
Oddometer: 71
I tie my bikes down such that failure of any single strap will not cause any problems with the bike..... Been trailering for a lot of years and have never lost or damaged anything. And I have had single straps fail (both break or just come loose). I have two green straps on the rear. One for each bike. They pull directly backwards and not towards the center. BTDT. Chuck |
01-17-2012, 04:08 PM
#4809 | |
Kudos. Lots of "beginners" in this thread. My post was more intended for their benefit. However using caribiners and quality straps is the key. As you well know by the look of those ProTaper straps. Their my favorite. Route your loops around the forks above the lower triple tree. Forks ar far stronger than bars and less wires/cables/bodywork to work around
01-19-2012, 06:11 AM
#4810 | |
Oddometer: 221
Hey Klay, have u ever cleaned out the sump screen? I see it in the manual to do, but not a mileage limit like for oil and filter. Thanks
1981 CB900C, 1998 GL1500C Valkyrie 2007 DR200 "Our Constitution was made only for a Moral and Religious people. It is wholly inadequate to the goverment of any other." John Adams 10/11/1798 "If we ever forget that we're one nation under God, then we will be a nation gone under" Ronald Reagan |
01-19-2012, 09:11 AM
#4811 |
plainsman
Oddometer: 89,071
No. Wouldn't you have to open the engine cases to get at that?
_______ |
01-19-2012, 11:18 AM
#4812 |
Oddometer: 221
the service manual shows it is behind the little cover, I think 3 bolts, that is next to the oil drain bolt.
01-19-2012, 11:45 AM
#4813 | |
plainsman
Oddometer: 89,071
I think I remember now. (too many DR's here...) I wouldn't worry about something like that unless you really put the bike through extraordinarily severe service.
_______ |
01-22-2012, 05:55 PM
#4814 |
Oddometer: 7
Near Llallagua, Bolivia
Riding from Oruro to Llallagua, most of it above 13000 ft.
01-22-2012, 06:05 PM
#4815 |
Oddometer: 71
