Old 01-22-2012, 09:40 PM   #4816
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,601
Originally Posted by Jerico591 View Post
Riding from Oruro to Llallagua, most of it above 13000 ft.
Adventure!
Highaltitude, back in 2001 I rode my DR200 around parts of the Rockies at 12-14,000 feet without any ill effect with the stock jets in the carb. No problems.
Well, I ain't always right but I've never been wrong.
It seldom turns out the way it does in the song.
Old 01-23-2012, 12:48 PM   #4817
Highaltidude
Oddometer: 71
Originally Posted by Klay View Post
Adventure!
Klay, I assumed normal "Colorado" geography..... The roads climb pretty high here, but you don't spend much time up that high (the road up to the top of Pikes Peak being a perfect example). I was thinking this guy might be up at 13,000ft for a while...... I've had mine "sustained" at 10,000ft w no probs. Just looking for input on higher......
Chuck
Highaltidude is offline   Reply With Quote
Old 01-24-2012, 09:44 AM   #4818
DR BrianO
DR BrianO's Avatar
Oddometer: 41
Question Mounting Tool Tube
Has anyone mounted one on a stock DR? I have a few ideas in my head just need to go get some parts. I spent about an hour last night just thinking of different options. If you are unfamiliar with these, you can purchase them here. At $5 it is hard to make anything this nice. http://www.agrisupply.com/operator-m...ister/p/67670/
1999 Suzuki DR 200se (fixed and sold)
1985 Honda Spree (fixed and sold)
1960 Honda S90 (restored and sold)
DR BrianO is offline   Reply With Quote
Old 01-24-2012, 05:05 PM   #4819
poppawheelie
poppawheelie's Avatar
Oddometer: 565
tie down
Originally Posted by Highaltidude View Post
Yep, overkill. That's me......
I tie my bikes down such that failure of any single strap will not cause any problems with the bike.....
Been trailering for a lot of years and have never lost or damaged anything. And I have had single straps fail (both break or just come loose).
I have two green straps on the rear. One for each bike. They pull directly backwards and not towards the center. BTDT.
Chuck
My rule for tieing down bikes on a trailer is the same as tieing luggage to the bike on a trip, two separate systems, so if either fails, the load will not be lost. For trailering, two straps up front off the triple trees or handle bars if necessary, compressing the front suspension; two straps on the rear, compressing the rear suspension. Either pair will hold the bike upright. For luggage on the bike for road or off road, two rock straps in X pattern and two rock straps or bungies in parallel on the far ends. In 48 years of riding I've watched valuable cameras and other items fall off bikes and bounce down the road. The camera bounced over my head. I've never lost an item and don't intend to.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Old 01-24-2012, 05:51 PM   #4820
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,647
two of those or two of these would store nearly all my break down tools.
These have a neoprene seal.http://www.agrisupply.com/MANUAL+CAN...+SEAL/p/70111/
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 01-24-2012, 10:49 PM   #4821
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
When i get the skid plate I will mount one of those tubes.
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 01-25-2012, 09:58 AM   #4822
Jerico591
Oddometer: 7
High Altitude DR riding
Chuck
Hi there Chuck and Klay. It was my first above 12000 continious long ride so I did think about it, but, nope, I decided to try everything as it was, in part so I could later compare the “before” and “after”. I started out of La Paz, to Oruro and then unto the smaller mining towns. There was a noticeable decrease in throttle response making it a little harder to pass larger vehicles up in the mountain passes (aprox. 14000 feet) but it wasn’t a big issue since there wasn’t much traffic anyway. (Also, I weigh around 185 pounds and was carrying an additional 25-30 pounds). So, yeah, I'd fully agree with your findings and am keeping the stock jets as they are.
J.
Jerico591 is offline   Reply With Quote
Old 01-25-2012, 11:16 AM   #4823
Highaltidude
Oddometer: 71
J.
Good deal. My plugs are a bit dark with sea level jets and constant operation at 7,000ft. I'll leave the jets alone based on your feedback. Note that I have had to swap to a "hotter" plug this winter. As these bikes are recent purchases, we haven't had them out over too big of range of elevations. That'll change come spring.....
Have a fantastic trip!!!!!!
Chuck
Old 01-25-2012, 03:28 PM   #4824
FlownOver
Old and slow man
Oddometer: 5
Stealth Bike
I'm solicting suggestions for making my DR200 as quiet as possible. I know it already is quiet in stock form, but I use the bike to get close to critters for purposes of photography, so I don't want to spook the wary ones. For example, I was able to get to within 20 feet of a pronghorn just before the snow closed things down here. From what I can tell, the major sources of noise is exhaust, intake and squeaks from moving parts. While a water cooled engine might be quieter, I think I'll let Suzuki do that. Anyone else working on the sound of silence?
When making a decision based on gut feeling consider the end product.
FlownOver is offline   Reply With Quote
Old 01-25-2012, 04:02 PM   #4825
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,601
You could set your valves on the tight side.
Old 01-25-2012, 05:31 PM   #4826
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,647
You could try running a stock muffler from a larger bike or try adding a smaller muffler before the stock muffler.Don't know what would fit.That's all the off the wall idears I got.
Old 01-26-2012, 03:17 PM   #4827
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 11,157
Tool tube:
My tool tube is the standard black pipe seen on most KLRs. I didn't want it down in front of the skid plate so I have it on the left side. It's a bit gawdly looking but it works well and is out of the line of fire when running rough roads.
In it I keep my rolled up benchmark atlas and inside the roll is my tire irons. I wanted my benchmark somewhere it would be easy to get to and yet stay dry.
If it was a little shorter and mounted at the right height is can look balance from the back view with the muffler on the other side.
The guy on my bike is Sasquatch from http://www.sasquatchrider.com/products.html . He did a seminar at last summer's Hells Canyon gathering and used my bike for the demo because he could easily throw it around.
We decided my bike would spend some quality time with him this winter so he could dial in the suspension for me. Since there isn't much in the way of aftermarket things for DR200s he will be fabricating some of what is needed to do what he wants to do. I'm excited to see what the outcome is. I enjoy this bike so much and if he can make it ever better I'm all for it. I did have to throw another challenge in there for him. I want better suspension but the bike can't get any taller not even a fraction of an inch. He took on the challenge.
Ladybug0048 is offline   Reply With Quote
Old 01-27-2012, 02:05 PM   #4828
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,408
light guard
Had this light guard on my DR650 and thought I'd see if it would line up with the DR200.
Perfect. (no affiliation)
https://tciproductsusa.com/index.php...roducts_id=565
$43.95
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 01-27-2012, 05:29 PM   #4829
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,647
How does it affect light output?
Old 01-27-2012, 05:46 PM   #4830
ThomasVolomitz
New Old Stock
Oddometer: 4,408
Not sure, I never ride this bike at night. It is my trail bike.
Still Riff Raff
Times are GMT -7.   It's 09:17 AM.
