Old 01-27-2012, 06:13 PM   #4831
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,626
Originally Posted by Rasthomas View Post
Not sure, I never ride this bike at night. It is my trail bike.
Then no worries mate.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 01-28-2012, 04:08 PM   #4832
daffodil60
Adventure Kiwi
daffodil60's Avatar
Oddometer: 11
Clutch Lever Replacement
Hi everyone, I am fairly new to riding and definetly havent done any mechanics before. I have a 2010 DR200. I love my bike and as every newbie does, I placed my bike on the ground a little suddenly and unexpectedly when I stopped on uneven ground.... So consequently I broke the end off my clutch lever. I have the replacement now and want to know if someone could give me step by step instructions on how to do the replacement. Even better if someone has pictures or can scan the instructions for me.
daffodil60 is offline   Reply With Quote
Old 01-28-2012, 04:28 PM   #4833
Highaltidude
Oddometer: 71
Easy job..... Take the nut off the bottom of the bolt, pull the bolt out the top. Now pull the lever away from the mount (cable still attached). You'll have to rotate the handle about 90 degrees clockwise so the cable lines up w the slot in the bottom of the lever. Now you can pull the lever "up" and off the cable.
When you put it back together, over tightening the nut can cause the lever to bind in the mount.
Chuck
Highaltidude is offline   Reply With Quote
Old 01-28-2012, 08:39 PM   #4834
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,626
Attachment 312443
Please purchase a service manual.It is worth it.
This should be the same for 2010 models as well.
Suzuki Factory Service Manual / 1996-2009 DR200SE / Pt # 99500-41141-03E
Old 01-29-2012, 01:15 PM   #4835
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,695
Chuck
You need to remove the clutch switch on the bottom of the perch before removing the lever, so it does not get broken. Re-install it last.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 01-29-2012, 01:31 PM   #4836
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 663
I've replaced the clutch lever numerous times and have never removed the clutch switch in the process. As long as you rotate the lever back in you're just fine.
godwinmt is online now   Reply With Quote
Old 01-29-2012, 02:00 PM   #4837
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,587
If you remove the clutch switch, take care not to lose the little spring. It'll spring out and hide.
Well, I ain't always right but I've never been wrong.
Seldom turns out the way it does in a song.
Old 01-29-2012, 04:39 PM   #4838
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
Brake Shoes
My bike has complete nearly 5k and the rear brakes are getting very soft. Are they supposed to be adjusted from the outside or do they just need replacing? Also does, the rear wheel need to be removed to changed the brake shoes?
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 01-29-2012, 05:39 PM   #4839
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,587
You adjust the brake shoes via the nut on the end of the brake rod. Just tighten it down. It's that simple. Yes, you have to take the wheel off to get at the brake shoes. They're unlikely to have significant wear...they last a very long time on the DR200.
Old 01-29-2012, 06:29 PM   #4840
thesurvivalist
Backcountry Rider
Oddometer: 551
Cheers again mate.
2015 Honda PCX
Old 01-30-2012, 11:05 AM   #4841
daffodil60
Adventure Kiwi
daffodil60's Avatar
Oddometer: 11
Chuck
Thanks Chuck I will try this.
Old 01-30-2012, 01:47 PM   #4842
striperjunky
Go team "Venture" !!!!!
striperjunky's Avatar
Oddometer: 152
spare fuel pack
I just finished up fabricating a spare fuel pack bracket for little suzi, here's some pix. Let me know what you guys think? Were planning another trip to the UP this spring and wanted the added security of extra fuel. for those who want more pix, email me and i will send you the full load. Sorry the pix are kind of big!
Rocky
striperjunky is offline   Reply With Quote
Old 01-30-2012, 01:49 PM   #4843
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,587
What kind of bash plate is that?
Old 01-30-2012, 01:55 PM   #4844
striperjunky
Oddometer: 152
bash plate
That would be a Ricochet brand plate (brand sticker is in the last pic) and i think it ran around $80.
Old 01-30-2012, 01:56 PM   #4845
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,587
Times are GMT -7.   It's 08:10 PM.
