Old 02-05-2012, 09:14 PM   #4861
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 690
I've been running a set of Fly Racing Aurora gloves I picked up a while back, and they're just plain awesome. I won't wear them if it gets above about 45 degrees (Fahrenheit) because my hands start to overheat, but below that to about 20 outside they're awesome. They've got a neoprene inner cuff that goes underneath your coat sleeve, and then an outer cover you pull over your jacket and pull a drawcord to cinch down making them super windproof. Below about 25 I'll throw in a set of Tourmaster liners, and that's been fine riding down to about 10 deg (-12C). or so which is as cold as it's gotten here this year.
If you've got to ride any sort of long distance in the cold I'd look into a set of heated grips as I've found that's the biggest culprit of cold hands is the bars wicking the heat away out of your palms. Also make sure you get a balaclava if you haven't yet. The difference one makes riding in the cold for your head/neck is amazing. My cold cruising setup is:
Thick wool socks
Alpinestars Vector boots
Tourmaster Venture pants with liner (I ordered a size bigger and use them as overpants)
Firstgear Kilimanjaro Jacket with liner
Tourmaster Polar Fleece glove liners
Schampa Warmskin balaclava
AGV GP1 helmet
Depending on how long i'll be out, I may throw on another pair of socks or run a set of underarmour coldgear underneath my street clothes.
Also, if you have any problems with roads not being clear soon enough for you to go out and have fun, really look into studding your tires. I took a set of old knobbies and ran 1/2" long hex head sheet metal screws into some of them to make 2 rows of studs. I've run mine about 500 miles (unfortunately a lot of just pavement because of the heat wave), and they've been fantastic. The biggest thing is to not put too many studs in or you'll make dry pavement scary to ride on.
Stay safe!
-M
godwinmt is offline   Reply With Quote
Old 02-07-2012, 01:16 PM   #4862
AKohler883
Oddometer: 108
can anybody tell me where the turn signal flasher is located on the bike ?
I did not see one under the seat, or behind the headlight cover.
Also, a wiring diagram would be nice if anyone can tell me how to access one online maybe.
I have some Extra wires that I do not know where they are supposed to go.
2 up front, and 2 under the seat. The 2 under the seat are attached to the starter relay, but go nowhere.
those I plan on removing. The 2 up front go into the harness.
AKohler883 is offline   Reply With Quote
Old 02-07-2012, 01:19 PM   #4863
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
if its not completely burned out it will click when activated so listen for it you should be able to hear
www.manracks.com
jungleplant is offline   Reply With Quote
Old 02-07-2012, 01:36 PM   #4864
AKohler883
Oddometer: 108
I am not even sure it is there. Someone had removed the turn signals. I am putting new ones on, I have at least located the turn signal wires so far. I got one light that I put on to light, but not flash.
Maybe I need to wire up all 4 (or at least one side) before it will attempt to flash.
I was doing this last night after midnight. So I gave up for the day.
I looked at the wiring harness on the part diagrams, but I do not see anythign that looks like a relay on there either. I know what it is supposed to look like.
Old 02-07-2012, 08:35 PM   #4865
AKohler883
Oddometer: 108
I found the flasher. It was behind the air box, and it was not working. Since the OEM flasher is very expensive, I decided to try an old school car flasher that I had laying around, and it seems to work fine.
Old 02-07-2012, 09:01 PM   #4866
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,740
When one bulb is blown out on one side, the blinkers will not flash. The intact turn signal just comes on steady. The flasher may be still working. You don't know until you have both turn signals hooked up, if you haven't done that yet. I bet the flasher is fine.
Old 02-08-2012, 03:56 AM   #4867
AKohler883
Oddometer: 108
All 4 brand new turn signals were hooked up last night. All 4 lit up, but did not flash. I swapped flasher relay and they worked immediately. I even swapped back just to make sure it wasn't a fluke, but indeed the relay is shot.
Next is to figure out why the horn does not work. And the front brake light switch.
I guess that's why I consider this a Project bike. :-)
My new Used seat is coming today, to replace the currently heavily damaged one. Can't wait !
Old 02-08-2012, 12:32 PM   #4868
harryhammer
harryhammer's Avatar
Oddometer: 171
i have a 2001 200 and the starter sounds like its coming apart when you start it, any ideas, bike runs good just a little cold blooded
harryhammer is offline   Reply With Quote
Old 02-08-2012, 01:54 PM   #4869
Highaltidude
Oddometer: 71
Been some discussion regarding the turn signals on the DR200 being too wide and subject to breakage on the inevitable dirt nap when ridden hard......
Here's what I've tried. Ordered a set of stock rear turn signals for a DR350, late 90s version. They look exactly like the DR200 signals except they're 1.5" shorter. Here's a pic for comparison:
The stock turn signals are very stiff and don't have much flexibility. These have quite a bit of flexibility and may not be official Suzuki issue. I paid just under $40 shipped to my house. They tuck under the Cycleracks rack my wife has on her bike and I do not expect any damage if (when???) this bike takes a rest...... We're very pleased w the look and now have the stockers for spares. I will probably order a set for my bike just because of the esthetic improvement.
Chuck
Highaltidude is offline   Reply With Quote
Old 02-08-2012, 05:45 PM   #4870
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,714
I would disassemble the starter and check the bearings and brushes.If all is well with that,check the starter clutch behind the charge rotor.I had a starter clutch failure on one of my Suzuki's and it spun the starter apart when I left the gas station.It locked my engine up and almost caused me to go down.Once I pulled the starter the engine would turn over manually.Scared the holy hell out of me.I had no warning of an impeding starter clutch failure, except a little unusual noise that developed when I would hit the start button.
You'll need a good manual.I recommend this one. Suzuki Factory Service Manual DR200SE
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 02-08-2012, 05:45 PM   #4871
poppawheelie
poppawheelie's Avatar
Oddometer: 582
Originally Posted by striperjunky View Post
That would be a Ricochet brand plate (brand sticker is in the last pic) and i think it ran around $80.
Any more info on the Ricochet bash plate? I didn't know anyone made a plate to fit. I had one fabricated.
When I Google Ricochet, all I get is ATV bash plates. Can you recommend a supplier?
EDIT: Found it under cyclebuy/MSR. $98.95.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie screwed with this post 02-08-2012 at 05:52 PM
poppawheelie is offline   Reply With Quote
Old 02-08-2012, 08:18 PM   #4872
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
Its on ebay type in dr200 skid plate.
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 02-08-2012, 08:19 PM   #4873
thesurvivalist
Backcountry Rider
Oddometer: 551
Has anyone here owned a tw200 as well as a dr200? I'm really liking the tw200 right now, just wondering how they compare?
2015 Honda PCX
Old 02-08-2012, 08:25 PM   #4874
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,740
Haven't owned one, but have extensively studied and wanted one. Even more compromised for the street but great for off-road plunking around, especially in wet areas.
Old 02-08-2012, 08:29 PM   #4875
thesurvivalist
Backcountry Rider
Oddometer: 551
Small tank and hard to find rear tires?
2015 Honda PCX
Times are GMT -7.   It's 11:53 PM.
