Old 02-10-2012, 05:49 PM   #4891
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
Thanks for the conversion chart.
I'll get a new tube on this occasion as the one on it is 5 years old and keep the stock tube.
My trail wings are low after 5k. To be honest I have not had any issues with the stock trail wings apart from some cracking, to be fair the tires are 5 years old though. I don't see where they get the reputation of death wings.
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 02-10-2012, 05:59 PM   #4892
AKohler883
Oddometer: 108
Being new, I was wondering too about the whole death wing thing. To me, tires are tires when you aren't talking full street use, and such a light weight application.
AKohler883 is offline   Reply With Quote
Old 02-10-2012, 06:31 PM   #4893
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,603
You ought to change the tire yourself. You need the skill in order to be self-reliant in the case of a puncture.
Well, I ain't always right but I've never been wrong.
It seldom turns out the way it does in the song.
Old 02-10-2012, 07:33 PM   #4894
thesurvivalist
Backcountry Rider
Oddometer: 551
I agree but I don't want to mess it up and have the wheel or tire come off because I bodged it up.
I already nearly killed myself a few weeks ago when i didn't torque the oil drain plug.
I'm going to ask the shop if I can watch them do it. Are special tools needed to removed the tire from the rim?
2015 Honda PCX
Old 02-10-2012, 07:41 PM   #4895
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,603
Tire changing skill is really something you need. You just need a set of tire irons. The tires on a DR200 are really easy to change...almost as easy as a bicycle...perfect to learn on.
They might use a tire changing machine at the shop...not helpful for you when you're stranded in a remote location.
here you go:
http://www.advrider.com/forums/showthread.php?t=50717
Old 02-10-2012, 09:10 PM   #4896
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,647
I did a search on here for reviews and most of the comments are read are negative. Such as they wear out quickly, chunks of rubber have ripped off after a short time, they don't grip. Looking at them they look very similar to the stock trail wing pattern.
You must have used different search terms that me.I have mostly read good things about Shinko's,their performance and longevity.I rave about mine every chance I get.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 02-10-2012, 10:26 PM   #4897
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,603
I've heard about trouble with the 705s. After I put them on my 650 last fall. We'll see how it goes.
Old 02-11-2012, 06:11 AM   #4898
drtaco
Oddometer: 41
hey lobsta my wife said those handguards are just my style. is a pat. pending or do you sell detailed construction plans? can i get them in black . she uses store brand bleach, so the bottle is not the same as clorox maybe she'll get off 25 cent and buy the good stuff really i like it i did a cheap experiment with the new BUD aluminium bottle, didn't work so well and i came up with the idea after emptying 8 bottles so that didn't help :)
drtaco is offline   Reply With Quote
Old 02-11-2012, 03:44 PM   #4899
thesurvivalist
Backcountry Rider
Oddometer: 551
I'll check that thread out. Hopefully the shop will let me watch them change it.
I was riding off road before with my wife on the back, the bike slid on the mud and i've bent a second clutch lever.
I'm definitely going to get a set of aftermarket handlebars so I can get some proper bark busters. What brand is better pro taper or renthal? it's 7/8 size I need?
On motorcycle superstore they have a drop down menu for the model of bike, the dr200 is not listed under suzuki, the drz400 is listed, aren't all handlebars pretty much the same?
Can i get handlebars that come up higher than stock bars or do I need to get risers?
Is there more vibration with aftermarket handlebars as they will not have the weights in the ends to counteract the vibrations?
2015 Honda PCX
Old 02-11-2012, 06:01 PM   #4900
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,603
I'm definitely going to get a set of aftermarket handlebars so I can get some proper bark busters. What brand is better pro taper or renthal? it's 7/8 size I need? 7/8ths, no opinion on model
On motorcycle superstore they have a drop down menu for the model of bike, the dr200 is not listed under suzuki, the drz400 is listed, aren't all handlebars pretty much the same? no, they aren't
Can i get handlebars that come up higher than stock bars or do I need to get risers? you can raise them either way
yes, there will be more vibration
Old 02-11-2012, 09:04 PM   #4901
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 664
You can run bark busters with the stock bars. Just drill a 1/4" hole in each end use a 5/16" tap to tap the steel weight welded in to accept a bolt. A friend ran mine into the side of a pickup and the levers/bars/bark busters are fine.
godwinmt is online now   Reply With Quote
Old 02-11-2012, 09:10 PM   #4902
thesurvivalist
Backcountry Rider
Oddometer: 551
Do you get any vibration?
What about other thumper bikes, I thought only the dr200 had the weights?
2015 Honda PCX
Old 02-11-2012, 09:50 PM   #4903
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,603
Most thumpers have bar end weights. They're usually not welded in. (at least on Suzukis)
Old 02-11-2012, 09:50 PM   #4904
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,603
I might just do that.
Old 02-11-2012, 10:05 PM   #4905
thesurvivalist
Backcountry Rider
Oddometer: 551
Sorry just reread my post, what I ment to say is the increased vibration of having aftermarket handlebars, is it significantly noticeable.
2015 Honda PCX
Times are GMT -7.   It's 08:29 PM.
