03-01-2012, 11:38 AM
#4981 |
plainsman
Oddometer: 89,809
I think the manual calls for 10W-40.
_______ |
03-01-2012, 12:23 PM
#4982 |
Carpe Diemer
Oddometer: 91
03-01-2012, 12:56 PM
#4983 |
if you look at the chart it says 10W-30 for climates up to 86*F, and 10W-40 for up to 104*F and higher.
It rarely gets over 86*F for extended periods of time in PA, but if you want to be safe, go for the 10W-40, couldn't hurt |
03-01-2012, 03:55 PM
#4984 | |
Oddometer: 226
amsoil has a great 10w30/30 HD oil that is top of the line, shell rotella has a 10w30 diesel also. I perfer 15w40 or 5w40 oil.
1981 CB900C, 1998 GL1500C Valkyrie 2007 DR200 "Our Constitution was made only for a Moral and Religious people. It is wholly inadequate to the goverment of any other." John Adams 10/11/1798 "If we ever forget that we're one nation under God, then we will be a nation gone under" Ronald Reagan |
03-02-2012, 08:43 AM
#4985 | |
Carpe Diemer
Oddometer: 91
OMG, Now I'm really confused. Okay - I'm just going to get 10w-40. |
03-02-2012, 08:46 AM
#4986 | |
Carpe Diemer
Oddometer: 91
Man, I warned you guys I wasn't much of a wrench!! And this has an oil plug on it right, I don't have to turn the bike upside down, right? (BTW, I'm TOTALLY kidding about that last part!!!)
03-02-2012, 08:59 AM
#4987 |
book says only 1 quart ... surprised me ...
03-02-2012, 09:02 AM
#4988 |
plainsman
Oddometer: 89,809
Fill it up until the level is about halfway up the sight glass.
_______ |
03-02-2012, 11:46 AM
#4989 |
Carpe Diemer
Oddometer: 91
03-02-2012, 11:48 AM
#4990 |
Carpe Diemer
Oddometer: 91
Notawrench
In my defense -
I admit, I'm not much of a wrench, but I am trying to learn. I don't want to get stuck out on the trail somewhere with my butt in a sling and that's all. I appreciate all you guys on here and the advice you hand out!! Thanks so much!! |
03-02-2012, 03:27 PM
#4991 |
Bug Sister
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 8,719
I'm worthless with a wrench but I can tell you there are two oil plugs and it takes just under a quart of oil.
After I killed the clutch on my bike in Moab the mechanic that replaced it suggested I not use synthetic oil - I don't know the specifics since it was over my head but basically he said synthetic might not be providing the correct lube for the clutch . . . . It made sense to me when he said it but I'm not able to repeat what he said. In case anyone is interested my '07 DR200SE is in the process of having it's suspension re-done for a better ride and handling. With lack of aftermarket support for this bike it was a challenge for the suspension guy to work the suspension. He figure it out though, the new spring is on the way and I should have my bike back soon. I'm looking forward to seeing what kind of difference it makes. I over load the poor bike something awful so this will help.
2013 Hells Canyon/Wallowa Valley Gathering: http://www.advrider.com/forums/showthread.php?t=843668 "Always be a first-rate version of yourself, instead of a second-rate version of somebody else." - Judy Garland |
03-02-2012, 03:51 PM
#4992 |
plainsman
Oddometer: 89,809
Ladybug, I've never had the transmission apart, so I don't know for sure, but I believe that second bolt down under locates the shift drum. I wouldn't fool with that one.
I tried a couple kinds of synthetic oils in the DR200, but both of them made shifting notchy, so I switched back to straight dino juice. I just change it often.
_______ |
03-02-2012, 05:39 PM
#4993 | |
Carpe Diemer
Oddometer: 91
03-02-2012, 06:06 PM
#4994 | |
plainsman
Oddometer: 89,809
![]() Be very careful when you are re-tightening the drain plug and the screws holding the oil filter cover. They are easy to strip out, especially the oil filter screws. There's supposed to be a rubber O-ring on the tower that you set the oil filter on, behind the oil filter. Make sure it's there.
_______ |
03-03-2012, 10:29 AM
#4995 |
Oddometer: 831
Hi, I'm a lurker from another thread, (except I see my buddy ThomasVolomitz is here.) I have a DR 200, I ride it mostly gravel, some trails. I have to ride pavement to get to gravel.
I'm wanting new tires, it has Bridgestone Trailwings, here are the numbers and letters off the tires; on the front Trailwing 19 70/100-21 44P TW19 on the rear Trailwing 18 100/90-18 56-P I think it's probably the original tires. Do these tires have tubes?
"I went to the Town of Cats and came back on the train." |
