03-09-2012, 05:05 AM
#5056 |
Carpe Diemer
Oddometer: 91
Ewwww. I WANNA GO! |
03-09-2012, 05:16 AM
#5057 | |
Oddometer: 118
While you're in there, check the float needle and seat, and especially, the o-ring on the seat. Remove the screw that holds the seat in place and check to see that the o-ring is still soft and and not hardened/shrunk. Replace it, if in doubt. It can cause rough/unpredictable idling. Also, check to see that the vacuum line to the petcock from the carb is dry and not leaking fuel, as the DR petcock is prone to failure (it's vacuum operated). If it's wet, you have to replace the petcock (it's not repairable), but there are ATV (Raptor) petcocks that fit well, and will solve your problem (be sure to cap the vacuum line if you replace the petcock with a non-vacuum one). Jet's are very tiny, so take care cleaning them. Don't worry, you'll get it running. |
03-09-2012, 07:20 AM
#5059 |
Oddometer: 50
change/mount tires
I always watch this video before I change tires, it's a great help.
http://motocross.transworld.net/1000...p-tire-change/
CRF230(plated) KTM105SX |
03-09-2012, 09:51 AM
#5060 |
plainsman
Oddometer: 89,019
Don't let one crank run you off.
_______ |
03-09-2012, 10:13 AM
#5061 |
Oddometer: 285
I'm slowly reading through this whole forum and have seen the question asked, but not answered: Is there a plastic tank that can be made to fit the 200? Perhaps from another bike? I'm not worried about capacity, I just want something less dent-able. Any weight savings couldn't hurt either, even if it is only ounces.
While we're at it, what about rear fenders? That rear rack makes things tricky.
07 450EXC |
03-09-2012, 11:50 AM
#5062 | |
Carpe Diemer
Oddometer: 91
That is a sweet video! That makes me want to try it! I bought the tires today. Paid $70 for the both of them. I will get this tire change done if it's the last thing I do! |
03-09-2012, 12:05 PM
#5063 | |
plainsman
Oddometer: 89,019
That's a pretty good video. You don't have a rim lock to contend with. Be careful not to put a lot of pressure on the brake rotor...you don't want to bend it. One hard part is getting the second bead on the rim without accidently pinching the inner tube with the tire iron.
_______ Klay screwed with this post 03-09-2012 at 12:22 PM |
03-09-2012, 12:08 PM
#5064 | |
Carpe Diemer
Oddometer: 91
http://youtu.be/BE1qG9iQZlg |
03-09-2012, 12:35 PM
#5065 |
I watched those videos too.
I changed dozens of tires on bicycles, and I do all the maintence and repairs on my motorcycles. But for the life of me, I could not get the bead over the edge of the rim with the tire iron. I felt like I was going to Crush the rim prying it over. In fact, it sounded that way too, so I stopped. Anybody can make it look Easy on a video, if you have the rights tools AND you have done it many times. AKohler883 screwed with this post 03-09-2012 at 12:42 PM |
03-09-2012, 12:48 PM
#5066 | |
plainsman
Oddometer: 89,019
Make sure you lube up the bead and make sure the beads on the opposite side of the wheel are pinched together toward the center of the rim so you have a little room to work with.
_______ |
03-09-2012, 01:08 PM
#5067 | |
Backcountry Rider
Oddometer: 358
I don't think there is an aftermarket tank for the dr200 as stock its a good size. If i didnt want the tank to get dented I'd get a tank saddlebag and pack it with some spare socks, t shirt etc to change into when your wet and it will give padding to the tank.
Buell Ulysses Xb12X Suzuki DR200SE 2007 Sold Custom Leather Work-Made In England www.lordofleather.com https://www.youtube.com/user/frontiercolorado |
03-09-2012, 04:35 PM
#5068 | |
Where we riding to?
Oddometer: 3,500
![]() ![]() You can do the same thing with your hand, but when trying to run 3 spoons, these really help. Growing an extra arm and hand never hurts either.
03-09-2012, 07:21 PM
#5069 | |
Backcountry Rider
Oddometer: 358
http://www.rockymountainatvmc.com/v/...I/DR200SE-2006
03-10-2012, 07:46 AM
#5070 |
Oddometer: 50
The lube is really important, esp with 19" motocross tires, I keep a can of silicon spray handy for the last couple of inches.
Rocky Mountain has the Tusk "bead buddy" for $10.
