Old 03-10-2012, 09:01 AM   #5071
Wallrat
Wallrat's Avatar
Oddometer: 821
The lube is really important, esp with 19" motocross tires, I keep a can of silicon spray handy for the last couple of inches.
I've always heard that you shouldn't use any type of lubricant that can potentially stick around on the tire bead - makes it easier for the tire to slide on the bead and you might shear a valve stem. Soapy water works, although some say the soap can harm the finish on the rim. I used soapy water for years without any issues. Plus I wash my bike a lot more often than I remove the tires. Windex seems to be a good, non-controversial choice. Only drawback to either of these is that they dry quick so you have to keep reapplying more as you go.
Oh and you want hell? Change a tire on a kid's motorcycle.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 03-10-2012, 09:09 AM   #5072
kafkamars
Oddometer: 40
rear axil
so, i found out about this a few days ago when i was putting my motor back in the bike after putting a new base gasket in the motor and checking everything which turnrd out prettyt ok (my base gasket was leaking oil for the last 3000 miles) it was fine. The motor was just collecting road stuff cuz it had oil all over it so i figured id finally fix it. but anyway i was putzin with the rear weel and realized that the wheel had play in it (about a 1/4 inch side to side) and when i tried to take the axil out it seems as tho the bearing welded itself to the axil! so yea.... i have 10000 miles on her and the last o i dont know, 1500 ish are 30 highway miles a day at 60-70mph and i have known for the last 5000 miles i should have kept an eye on the wheels, so i guess its my fault. so, any ideas on how to get the axil out, ha, yea my regular hammer wuznt enough, i might borrow my buddys 4 lb slege but just wondering if theres anytricks before i brake something else? .. btw rock on all shade tree mechanics
kafkamars is offline   Reply With Quote
Old 03-10-2012, 10:19 AM   #5073
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 731
My personal favorite is vinyl or rubber dressing for car interiors. It starts slick as snot, and then gets soaked up by the tire and tube.
And hell is mounting/demounting a semi truck tire by hand. Been there...done that.
godwinmt is offline   Reply With Quote
Old 03-10-2012, 04:13 PM   #5074
Motardo
Commuter
Oddometer: 5
No tricks, just a BIG hammer! Don't hammer directly on the axle, because if you smash the threads you wont get the axle nut back on. Use a drift on the center of the axle and hammer on that. Wear thick gloves, or have a good friend hold the drift. Sounds like you want to replace the wheel bearings anyway, so use some heat on them to help get the axle out.
Motardo is offline   Reply With Quote
Old 03-10-2012, 04:56 PM   #5075
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,853
The only time I use a tire lube that leaves a tacky bead is on tubeless wheels and when I feel that the tire could possibly spin on the rim.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is online now   Reply With Quote
Old 03-10-2012, 06:41 PM   #5076
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
Anyone know where I can get a new full rear rim with spokes for the DR200? I have the XP200 which is an exact copy of the DR200 except for the oil filter which is a DRZ400 filter everything else is exactly same. My rear wheel keeps breaking spokes and I'm not ordering stock spokes or spending loads of money to make it invisible instead I want a Suzuki rim with spokes. The spokes on the XP200 seems to have copper in the middle (to me seems like they are the cheapest of the cheap spokes) and the rim doesn't seem that durable either.
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 03-11-2012, 10:26 AM   #5077
knowlsey
Oddometer: 4
Originally Posted by HeReTiK View Post
Seeing that brand new frame is making me want to strip my bike down and paint the frame....
Was going to paint the frame myself, decided to check how much for a strip and powder coat, only 60 not worth messing around with paint for that price, and looks like new
just need to find out whats holding the damn thing back, after rejet and air box mod
knowlsey is offline   Reply With Quote
Old 03-11-2012, 10:34 AM   #5078
knowlsey
Oddometer: 4
Originally Posted by Klay View Post
I like the round headlights on the Djebel. Not sure what's holding your bike back, though. I did the Kientech mods on my 200 and it still tops out at 72 mph. I tried changing sprockets once to bring highway rpms down once, but decided that the bike felt too bogged down and returned to the stock 15/45 sprockets.
not sure what holding it back, i have literally stripped the bike to its bare bones and ground up rebuild, had to drill a few more extra holes in the air box as this was causing it to bog out, may take the lid off the air box alltogether and see what that does, if that works then a pod filter may be the answer
Old 03-11-2012, 10:52 AM   #5079
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
New wheel? SHS powersports?
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 03-11-2012, 09:45 PM   #5080
amtz.zero
amtz.zero's Avatar
Oddometer: 72
My wife's DR200:
amtz.zero is offline   Reply With Quote
Old 03-11-2012, 09:59 PM   #5081
Wallrat
Wallrat's Avatar
Oddometer: 821
I like it. Painted plastics? Whatcha got going on with that rear fender?
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Old 03-11-2012, 10:14 PM   #5082
amtz.zero
amtz.zero's Avatar
Oddometer: 72
Yep, plastics were painted with "krylon fusion for plastics" and the bike has a drz400 rear fender on it. It took some cutting but I was able to get it on there. It also has an "edge" tail light.
Old 03-12-2012, 05:19 AM   #5083
onyajonesy
onyajonesy's Avatar
Oddometer: 24
fuel wise
hi dr dudes... just a quick question..... what is the mileage you get out of the/your dr200? cheers jonesy.
onyajonesy is offline   Reply With Quote
Old 03-12-2012, 08:29 AM   #5084
Wallrat
Wallrat's Avatar
Oddometer: 821
Can I see a closeup of that rear fender? The wife hates the stock fender and has tasked me with "fixing it".
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Old 03-12-2012, 08:30 AM   #5085
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 731
Here's my log on mine.
Most of the riding is highway riding > 50mph. The 89mpg I got on the first stretch of the Hoosier National Forest ride last year.
Times are GMT -7.   It's 09:43 AM.
