Old 03-18-2012, 01:51 PM   #5161
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
Are they safe to use?
Chuck you lucky sod I wish i was living in Colorado Springs right now.
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 03-18-2012, 02:06 PM   #5162
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,860
Sounds like it's time to look into a summer cabin.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 03-18-2012, 05:21 PM   #5163
rickcj7
rickcj7's Avatar
Oddometer: 518
Originally Posted by psu75 View Post
I'll let you know how I make out with the bead buddy. This being my first time changing a tire in my life, I fully expect it to not go all that smoothly and there to be a full row of curse words to come flying out of my mouth at some point. I will be sure to have ice packs and band-aids on hand as well as a six pack or two...
Hey asshat? Learn to read dickweed.
I really hope you didn't jinx yourself with your piss poor attitude.
rickcj7 is offline   Reply With Quote
Old 03-18-2012, 08:09 PM   #5164
Wallrat
Wallrat's Avatar
Oddometer: 821
No more dangerous than any wall wart charger/power supply that you'd find on your printer, cell phone, router, etc.
Complete discharges will kill a lead acid battery faster than anything else so you're better off using a tender than not.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 03-18-2012, 10:43 PM   #5165
tkent02
Oddometer: 2,910
DR 200 Knobbies....
Can't find any tires in these stock sizes, 70/100-21 and 100/90-18. What type and size tires are you running?
This for Colorado, so it's a lot of rocks... And nearly zero pavement.
tkent02 is offline   Reply With Quote
Old 03-19-2012, 07:03 AM   #5166
Highaltidude
Oddometer: 71
Tenders that drop to a trickle charge are made to be left for long periods of time. Very safe. Used a lot on motorcycles over the winter in places like Colorado......
Poorly guided tours of Colorado Springs are always available....
Chuck
Highaltidude is offline   Reply With Quote
Old 03-19-2012, 11:30 AM   #5167
Wallrat
Wallrat's Avatar
Oddometer: 821
If you're trying to stay close to stock height and on DOT tires as I was, then a 110/80-18 Pirelli MT-21 is great for the rear. It's about 0.05" shorter than the stock tire so basically identical. For the front I went with a 90/90-21 Dunlop D606. It was considerably taller (maybe 1.5"), but I've heard its a very popular dirt-oriented front tire for a wide variety of terrain. I got the rear from mx superstore. Front I picked up at a local shop but I think MX superstore has it as well.
Front:
Rear (mounted, stock trailwing shown for comparison)
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Old 03-19-2012, 06:50 PM   #5168
tony the tiger
yeah - what he said...
tony the tiger's Avatar
Oddometer: 10,665
Cool2
Is a battery tender the same as a battery charger? I'm going away for 6 months should I remove the battery and put it on a tender?
I think they've already hit the big info points - all I have to add is that if you will be gone for six months, I'ma guess that would include some warm ones. I wouldn't leave it on continuously during the summer, but that's just me.
I'm away now,for awhile - what I did was plug the charger into a 24 hour timer, set to be on 12 hours a day. This will preclude slowly "cooking" the electrolyte or acidy stuff ;-) from the battery, and allow the charger to cool off each "down" cycle of 12 hours. Mebbe I'm over-thinkin' it though.
Tony
Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines.
tony the tiger is offline   Reply With Quote
Old 03-19-2012, 06:57 PM   #5169
AKohler883
Oddometer: 108
Batteries do not lose that in a day. An hour a day would have been more than enough.
AKohler883 is offline   Reply With Quote
Old 03-19-2012, 07:00 PM   #5170
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,046
If a bike is stored in the summer, that is when the battery needs attention the most, as the higher temperatures facilitate chemical reactions within the battery.
Old 03-20-2012, 05:51 AM   #5171
AKohler883
Oddometer: 108
This is true. Good thing we don't own snowmobiles (especially this year)
Old 03-20-2012, 06:05 AM   #5172
Highaltidude
Oddometer: 71
Hey, now wait just a minute.......
You should see in my barn.....
But none of mine have batteries.... Too much weight.....
Chuck
Old 03-20-2012, 11:08 AM   #5173
acif
Oddometer: 48
does anyone knows what is the brass cylinder that sits (offset) beetwen the imaginary line that connects the main jet with the pilot screw (plug)?
it should has a hole?
NOTE: internet picture, do not take into account the annotations.
acif screwed with this post 03-20-2012 at 11:16 AM
acif is offline   Reply With Quote
Old 03-20-2012, 11:29 AM   #5174
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,046
I can't remember what it is. I'd have to take the carb apart. Is it just a vent tube of some type?
Old 03-20-2012, 06:34 PM   #5175
Motardo
Commuter
Oddometer: 5
It's the "choke" jet. It should have a very small hole (smaller than the pilot jet). If it's clogged, the engine won't fast idle when you pull the choke plunger out.
Motardo is offline   Reply With Quote
Times are GMT -7.   It's 04:17 PM.
