Old 03-22-2012, 09:55 AM   #5191
Klay
plainsman
Oddometer: 89,815
I put a set of Shinko 705s on my 200. They're pretty street-oriented. I like them so far, but of course, they're new, soI can't offer a long-term review.
_______
Old 03-22-2012, 04:36 PM   #5192
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 8,722
Jack stand: http://www.advrider.com/forums/showthread.php?t=538235 It fits in my tool tube and works great.
Does the tubeliss system fit the tires on the DR200? Has anyone used it on their's? Anyone use http://www.revzilla.com/product/mich...b-mousse-tires it says not safe after 80 mph but I don't think that's an issue with these bikes.
2013 Hells Canyon/Wallowa Valley Gathering: http://www.advrider.com/forums/showthread.php?t=843668
"Always be a first-rate version of yourself, instead of a second-rate version of somebody else." - Judy Garland
Ladybug0048 is offline   Reply With Quote
Old 03-22-2012, 09:34 PM   #5193
havocdog
havocdog's Avatar
Oddometer: 126
Originally Posted by havocdog View Post
06 model. Right turn signals work fine. When I turn on the left turn signals, front left stays on (no blinking) and rear left is off. I swapped the rear bulbs - same problem on left, so it is not the bulb. Where do I look next?
Originally Posted by Klay View Post
I had the same problem. If I recall, the positive wire to the turn signal was broken off...I think inside the turn signal stalk. I soldered it back together.
Originally Posted by godwinmt View Post
Same exact thing happened to mine this summer. Pulled the signal apart, resoldered it, and it's been fine for the past 5 months.
Klay and godwinmt: Thanks for the guidance - you were dead on. I finally pulled the bike out of the back of the garage and took the signal stalk apart - one wire was separated from the base of the socket. Soldered it back on and good to go! Thanks again!
Can you see me now?
dr200 f650gs r60/6 ttr125 crf230f crf150f amf(moped)
havocdog is offline   Reply With Quote
Old 03-22-2012, 10:56 PM   #5194
Wallrat
Wallrat's Avatar
Oddometer: 314
The bib system is supposedly only for Michelin tires, which really limits what you can run.
Tubeliss makes an 18" and a 21" so I don't know why it wouldn't work, although I did read that some people had issues on really wide rims (not a problem on the stock DR rims). I just installed a pair of Tubeliss(19/21) on my XR400 and so far they seem nice. Gonna hit the trails tomorrow and see how they do offroad. I'll do the DR if I like em. Only difference will be that you have to drill a 7/16" hole in the DR rim.
07 450EXC
Wallrat is offline   Reply With Quote
Old 03-23-2012, 02:08 PM   #5195
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,324
Originally Posted by Charliedog43 View Post
AKohler,
The Avon street tires that caught my eye are the RoadRider AM26. Available in 90/90-21 and five different rear sizes from 4.00 to 120/80-18 that look like possibilities. The price is rather steep tho. It looks like the Distanzias are designed for bigger, heavier bikes.
From what I've researched so far, it looks like the IRC GP-110s might be the most street oriented tires for the DR200.
Larry aka CharlieDog
Bristol, TN
I had the GP-110s on mine and was quite happy with them. I would have tried the Shinko 705s next, but I had to sell the little DR.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 03-23-2012, 09:42 PM   #5196
Wallrat
Wallrat's Avatar
Oddometer: 314
Wifey got to ride the DR on the dirt for the first time:
07 450EXC
Old 03-23-2012, 10:08 PM   #5197
Klay
plainsman
Oddometer: 89,815
Nice. Where is that?
_______
Old 03-23-2012, 10:31 PM   #5198
Wallrat
Wallrat's Avatar
Oddometer: 314
Cleveland National Forest. Its small but the closest offroad we've got here in Orange County, Ca
07 450EXC
Old 03-24-2012, 06:17 PM   #5199
patski
patski's Avatar
Oddometer: 50
Inverted Forks on the XR???
CRF230(plated) KTM105SX
patski is offline   Reply With Quote
Old 03-25-2012, 09:05 AM   #5200
Wallrat
Wallrat's Avatar
Oddometer: 314
They're from a 2008 CRF450. http://www.emigracing.com/ makes a conversion stem that allows you to bolt CRF triples onto the XR400 (they also make other conversion kits like the CRF230, DR650, etc). If you go with an older CRF (think <2004) then you can even use the XR brake caliper. I think I spent about $500 on the whole conversion. Great mod IMO, they work awesome and really update the look of the bike. Helps that they came from the PO already sprung/valved for my weight.
07 450EXC
Wallrat screwed with this post 03-25-2012 at 09:10 AM
Old 03-25-2012, 11:38 AM   #5201
dean-o
2 for the price of 1
Oddometer: 736
off the wall wheel question
do dr125 wheels fit on dr200? i use several for training & wonder about using a spare set of wheels for tire changes...
dean
tennessee
615 545 1111 text
dr350se owner
tubliss
acerbis
dean-o is offline   Reply With Quote
Old 03-25-2012, 02:30 PM   #5202
Charliedog43
Charliedog43's Avatar
Oddometer: 20
Rear shock question
I saw a reference somewhere that someone might have installed a DRZ400 rear shock on a DR200. Can anyone confirm a successful installation? If so, what was involved? I've done the ZZR1200 shock on my Concours and the R6 shock on my FZ1 with great results, but both took some modifications. It is much less expesive than going after market tho.
Bristol, TN
Charliedog43 is offline   Reply With Quote
Old 03-26-2012, 06:28 AM   #5203
daffodil60
Adventure Kiwi
daffodil60's Avatar
Oddometer: 11
Tires
Ok this might sound really stupid, but I put Kenda 761 tires on my bike and I want to check what pressure should be in them. I looked the tires up and it said 32 front and rear??? I had the standard tires on before but these are bigger tires. The previous tires were Bridgestone and they had psi 22/25. Would anyone be able to give me some help with this. Thanks
daffodil60 is offline   Reply With Quote
Old 03-26-2012, 08:04 AM   #5204
Charliedog43
Oddometer: 20
Tire Pressures
I would go with what the bike says to start with-22/25 solo or 22/29 two-up or heavily loaded. Setting the tires at 32/32 just sounds too high for that weight bike. I'd bet you would have a very harsh ride, reduced traction, and increased wear down the middle of the tires. Be sure to take it easy around corners for a few miles with the new tires, they might have a coating on them that could make them slippery until it wears off. HTH
Bristol, TN
Old 03-26-2012, 08:15 PM   #5205
poppawheelie
poppawheelie's Avatar
Oddometer: 278
There are mousse systems available (state side) for other than Michelin, but are not recommended for any pavement riding. The issue is heat build up. In any usage, the mousse must be liberally lubricated to reduce friction between the tire and mousse.
Tublis may be the way to go, or if you search the Internet, you'll find different ways of converting spoked rims to tubeless use.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Times are GMT -7.   It's 09:31 AM.
