Old 04-15-2012, 07:44 AM   #5311
poppawheelie
poppawheelie's Avatar
Oddometer: 559
Originally Posted by Klay View Post
A Yamaha Raptor petcock fits...it's one a lot of people commonly retrofit the 200 with. I've got a few other petcocks at home...can't remember where I got them...but I can take a look when I get home.
If I were you, I wouldn't fiddle with the carb any more until you've eliminated the petcock as a source of trouble. It sure sounds like that's the problem.
Ditto on replacing the petcock before anything else. Solve one issue at a time. I used the Raptor petcock on our DR650 when I put an IMS tank on.
Ditto on changing the oil too. That's where the gas goes when it overflows, first into the airbox, then down into the crankcase.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Old 04-15-2012, 08:56 AM   #5312
MorganSS
Texan
MorganSS's Avatar
Oddometer: 81
I do know the PO just changed it, I want to say he mentioned Mobil Synthetic oil.
Any recomendations on oil? May as well post any hints or tricks for me now
MorganSS is offline   Reply With Quote
Old 04-15-2012, 11:13 AM   #5313
tkent02
Oddometer: 2,255
Shinko 244, comes in 3.50-18 or 4.10-18.
Which is closest to the stock 100/90-18?
tkent02 is offline   Reply With Quote
Old 04-15-2012, 11:36 AM   #5314
bross
Where we riding to?
bross's Avatar
Oddometer: 4,519
Conversion chart here...
Tire Conversion Chart
Old 04-15-2012, 12:02 PM   #5315
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,323
I use 10W-40. Do not over-tighten the drain plug or the oil filter cover screws. Those screws in particular are very easy to strip. I use a small (short) wrench and tighten them just past finger-tight.
windigo
Old 04-15-2012, 12:03 PM   #5316
tkent02
Oddometer: 2,255
Which does not help at all, does anyone have experience with these tires on a DR 200?
Old 04-15-2012, 12:09 PM   #5317
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,323
I've got a 4.10X18 705 on the back. Not sure if that's the same size as stock.
windigo
Old 04-15-2012, 04:24 PM   #5318
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,228
Just to add to this.Most auto oils have friction modifiers which will cause the clutch to slip.I use Castrol 10-40 aka 4T oil.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 04-15-2012, 04:37 PM   #5319
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,323
Oil wars! I just use automobile grade oil in all my bikes. All my life. I've never had any oil-related wear or clutch problems. Just make sure the oil doesn't carry this stamp:
(make sure it doesn't say "energy conserving")
windigo
Old 04-15-2012, 04:58 PM   #5320
poppawheelie
Oddometer: 559
If the previous owner used synthetic, I'd stick with that. Just be sure it doesn't have friction modifiers or that it is motorcycle specific. Reason is, clutch plates may slip and wear if oil is "too slippery." I use AmsOil moto oil, but hey, there's many to choose from.
Old 04-15-2012, 09:23 PM   #5321
MorganSS
Texan
MorganSS's Avatar
Oddometer: 81
When is a good time to change the filter, my bike only has 500 miles on it
Old 04-15-2012, 09:48 PM   #5322
poppawheelie
Oddometer: 559
If you're going to change the oil, change the filter too. If there is gas in the oil, it will be saturated in the filter too. If there wasn't gas pooled in the bottom of the air box, there might not be gas in your oil at all. You'll have to make the call on that. Check the smell and the color of your oil. Maybe there's no gas in it at all. Biggest question: was there gas in the bottom of your air box?
Old 04-15-2012, 10:07 PM   #5323
MorganSS
Texan
MorganSS's Avatar
Oddometer: 81
Very minimal amount. Not pooling at all, just some moisture. I am doing a lot of easy things to get familiar with the bike and learn though. I am new to this hobby. I was previously a rc nitro racer and ours amazing how similar they are. Hell these are easier but I want to know this bike and feel comfortable by myself on a long trail ride.
Old 04-16-2012, 12:49 AM   #5324
Wallrat
Wallrat's Avatar
Oddometer: 623
I've always used auto oil in my bikes too, cept lately I can't find friction-modifier less auto oil in Ca for less than $5/qt. So I've switched to motorcycle oil simply b/c its the same price.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 04-16-2012, 05:01 AM   #5325
AKohler883
Oddometer: 107
If bike was new and had 500 miles, I would change the oil per break in procedures.
If bike sat for long periods of time, I would change the oil.
So you have 2 reasons to change.
Might as well do the oil filter as well.
It is super easy on this bike.
AKohler883 is offline   Reply With Quote
Times are GMT -7.   It's 03:44 PM.
