Old 05-03-2012, 10:21 AM   #5431
Wallrat
Wallrat's Avatar
Oddometer: 815
I run that fender on my XR. Just take off the OEM fender and flip it over onto the included template (so that you're looking at it from where the tire would be).
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 05-03-2012, 11:09 AM   #5432
kwayne
Oddometer: 18
Anyone had any experience removing the air box and using a cone style air filter that attaches directly to the carb?
kwayne is offline   Reply With Quote
Old 05-03-2012, 01:52 PM   #5433
JayGoldstein
Oddometer: 68
Originally Posted by Klay View Post
Check your clutch lever adjustment. There should be around 2-3 mm of play.
My owner's manual specifies 10-15 mm of play measured from the front of the lever ball-end. Mine is spot on.
Any other ideas about why it is hard to downshift and find neutral until the engine has warmed up?
Jay
2009 DR200SE: ManRacks rack, ScreensForBikes windshield, Wolfman tail bag, 16T sprocket, Kenda K761 tires, Moose Racing CR-HI handlebar, Renthal MX grips, Polisport fender.
JayGoldstein is offline   Reply With Quote
Old 05-03-2012, 02:04 PM   #5434
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,985
I suspect that the clutch is not disengaging fully. This is how the bike behaves when there's too much slack in the clutch cable. I adjust it so there is about 2-3 mm play measured at the gap in front of the pivot point for the lever.
Old 05-03-2012, 04:04 PM   #5435
JayGoldstein
Oddometer: 68
Measuring where you suggested I found about 4 mm of play. I've reduced that to about 3 mm, and will see if that improves things.
Jay
Old 05-03-2012, 05:26 PM   #5436
psu75
Carpe Diemer
psu75's Avatar
Oddometer: 105
New Fender
I put the new fender on tonight. The color match is good and installation was a breeze! Here are a few pics:
Seize the frick'n day!!
psu75 is offline   Reply With Quote
Old 05-03-2012, 05:52 PM   #5437
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,710
There was someone posting here a while back that had acquired a 200 already butchered that way. IIRC, it did not run too well. Generally, if you make that radical a change in the breathing, you are in for a good time jetting it to work. Unless you have some sort of uncorked exhaust, you won't gain much power, but you will gain a bunch of extra intake noise.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 05-03-2012, 07:47 PM   #5438
kwayne
Oddometer: 18
Thanks. Got the bike down to the frame, motor, and tires right now. I think im gonna try it when I put it all back together.
Old 05-03-2012, 07:49 PM   #5439
kwayne
Oddometer: 18
This is what I started with. Not a real big fan of the purple.
Old 05-03-2012, 07:50 PM   #5440
kwayne
Oddometer: 18
Old 05-03-2012, 07:52 PM   #5441
kwayne
Oddometer: 18
Old 05-03-2012, 07:55 PM   #5442
kwayne
Oddometer: 18
I hope I remember where all this stuff goes.
Old 05-03-2012, 08:40 PM   #5443
tuffstuff
Livin' Life
tuffstuff's Avatar
Oddometer: 533
Loved your videos ... Makes me want to go back!! My man and I were there riding last summer and I did not want to leave.
Originally Posted by Highaltidude View Post
The wife and I got the DRs out to Moab. Three days of phenomenal riding.
A pic from the Dead Horse State Park Visitors Center:
A pic from the White Rim Trail:
The DR on the Slickrock Bike Trail:
All told we did:
- Shafer switchbacks
- White Rim Trail (one day)
- Gemini Bridges
- Long Canyon
- Slickrock Bike Trail
- A run on HWY 279
- A jaunt out Kane Creek Road
These are very competent motorcycles!!!
And if you have absolutely nothing better to do:
Day one: http://youtu.be/9w1lkQiZ-BI
Day two: http://youtu.be/AqnqBB9lUnQ
Day three: http://youtu.be/6_O5hEYqSjI
Chuck
2014 Colorado Ride Report
tuffstuff is offline   Reply With Quote
Old 05-03-2012, 10:35 PM   #5444
Wallrat
Wallrat's Avatar
Oddometer: 815
Not just increased noise but that's going to be a nightmare in rain or water crossings, plus the filters get dirty incredibly fast. I run filters right off the carbs on my quad and have to run 3 layers of protection just to make it through a weekend. Outerwear on the outside keeps the big chunks off and helps a tiny bit with water (still have to putt through creeks). Under that I have a woman's leg nylon wrapped around the K&N filter. I swap the nylons out usually at the end of every day and they're pretty nasty looking at that point even. IMO an airbox is required on any bike that sees normal daily use including occassional flooded gutters, creeks, or even rain. People on this thread have even had problems with rain on DR's with the airbox lid removed.
Oh and looks good PSU!
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Old 05-04-2012, 09:51 AM   #5445
psu75
Carpe Diemer
psu75's Avatar
Oddometer: 105
Thanks! I'm happy with it!
Times are GMT -7.   It's 10:37 PM.
