05-23-2012, 08:57 AM
#5566 |
Oddometer: 61
Hi, I was wondering if any of you guys could help me out. My wife's dr is not running right. I test rode it after she complained about it and it seems like it wants to cut off. It just acts like it wants to turn off as you're riding it and sometimes when she's stopped at red lights too. I'm pretty sure it's not the carburetor as it was recently cleaned. Could it be something simple like the spark plug or cable? Would that cause the symptoms that I described? Any help is VERY much appreciated as this is her daily ride right now and my bike is too tall for her. Thank you guys in advance!
05-23-2012, 09:13 AM
#5567 |
Bring me up!
Oddometer: 2,931
Nothing (ad)ventured, Nothing Gained Explore. Dream. Discover. Maryland OHV Alliance |
05-23-2012, 09:39 AM
#5568 |
Carpe Diemer
Oddometer: 91
Add to it...
I was out looking for some instructions on replacing the headlight and came across this site - pretty good info here as I know a lot of of older DR's here and some of this will apply to the newer one's as well. I don't know if it's ever been posted or not but here's the link:
http://addto.it/1998-Suzuki-DR200
Seize the frick'n day!! |
05-23-2012, 10:07 AM
#5569 |
Oddometer: 18
Well I figured it out. BLOWN FUSE. I guess I gave the previous owner to much credit thinking he would have checked that first before running wires to get power. I dont think it was a security thing because the switch was dangling off the side of the bike with a red wire looped to the front headlight assembly.
05-23-2012, 10:08 AM
#5570 | |
Oddometer: 18
05-23-2012, 10:59 AM
#5571 | |
Oddometer: 61
05-23-2012, 12:12 PM
#5572 |
Oddometer: 285
I'd replace the petcock with a raptor one anyway just b/c its going to fail at some point so might as well remove that as a possible culprit to this issue and save yourself potentially costly repairs when it does fail.
It sounds like a carb issue to me. What part of the throttle range is it doing it at (0-1/4, 1/4-3/4, 3/4-full)? Just b/c the carb was recently cleaned doesn't mean that it can't be the issue - especially if you had a shop do it. I've heard tales of shops installing parts in backwards or even forgetting to put the jets back in. Have you pulled the plug to see what it looks like? That is your best indication of how good the fuel/air mixture is. When's the last time you adjusted the valves? Valves that are way way out can cause the engine to run rough. I'd try pulling the plug and post a pic if you're not sure what you're looking at. Then I'd try running it with the choke on to see if that clears things up. If it does you probably have a plugged jet.
07 450EXC |
05-23-2012, 12:17 PM
#5573 | |
Oddometer: 61
Well, I went over the whole bike and the postive terminal on the battery was loose. I tightened it and went out for a test ride and the bike acted completely normal. Is it possible that was the only thing wrong? Could it be that easy? Thanks. |
05-23-2012, 02:01 PM
#5574 |
Discontinued?
![]() Just checking out Suzuki USA's site and saw no new DR200. I can live with that IF they bring us a DRZ250S (air/oil cooled) but I think it'd be a shame to not have a smaller D.S. than the DRZ400S. |
05-23-2012, 02:32 PM
#5575 | |
Where we riding to?
Oddometer: 3,501
05-23-2012, 03:55 PM
#5576 | |
Oddometer: 36
Jay 2009 DR200SE (ManRacks rear rack, ScreensForBikes windshield, Wolfman Peak tailbag, RAM GPS mount, 16T sprocket) |
05-23-2012, 07:56 PM
#5577 | ||
yeah - what he said...
Oddometer: 9,043
DAMHIK
Tony ![]() Quote:
05-23-2012, 09:43 PM
#5578 | |
Oddometer: 9,043
now I get it. I knew what they meant by snails or whutever... but didn't see your picture till just now. Just changed out the petcock for the Yamaha... had to trim the inside of the petcock handle so it'd clear the lip of the tank. I know I saw pictures of some bodges with fuel line (because the fuel line spigot is larger diameter than the DR200 petcock) but I think I'll just go get a reducer tomorrow to bring it back to the right size... or maybe an inline fuel filter.
Tony ![]() Quote:
05-23-2012, 09:54 PM
#5579 | ||
Oddometer: 9,043
![]() This is the petcock I bought - fuel line is smaller than the spigot on the petcock. Also, the fuel filter level was ~lower~ than the vacuum stocker... so I'ma thinkin' it'll be LESS fuel in the reserve. ![]() This one sits a little closer to the tank (it's smaller than the stocker) so I took a Dremel tool w/cutoff wheel to the inside edge so it'd clear the lip of the gas tank - otherwise you wouldn't be able to rotate it to reserve. 'bout $10 though. Such a fun word...
Tony ![]() Quote:
05-24-2012, 07:09 AM
#5580 |
Carpe Diemer
Oddometer: 91
I'm moving from PA to TX this summer - is there anything particular I should do to the bike to prepare it for the change in the weather conditions/sea level? I'll be in the Houston area so it'll be HOT. My poor little bike is used to me getting it out in the colder weather and riding it... Any advice is helpful!
