Old 06-02-2012, 09:17 AM   #5626
Wallrat
Wallrat's Avatar
Oddometer: 623
Originally Posted by JayGoldstein View Post
I've also experienced that hesitation when opening the throttle. I'm taking my bike in for the 1,000 km service next week and will mention this issue. Has anyone has gotten their dealer to adjust the carb, or do they refuse to do so because of emissions regulations?
I've never asked a dealer to do anything on my bike except mount a tire to a wheel - which I've now stopped doing as well. You'll probably find very quickly that despite how easy it is to work on motorcycles with even just basic hand tools, dealers still feel justified in charging ridiculous rates. Swapping jets in a carb takes maybe 20 min for your first time. A 1000km service is probably just going to be:
change oil/filter
adjust valves
check electrical for function
check tire pressure
finger check spokes for loose ones
adjust throttle and clutch play
clean air filter
To do that in your garage you'd only need a few wrenches/screwdrivers and a couple hours tops. Half that stuff you should be doing before every ride anyway.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is online now   Reply With Quote
Old 06-02-2012, 11:18 AM   #5627
MorganSS
Texan
MorganSS's Avatar
Oddometer: 81
Originally Posted by ThomasVolomitz View Post
The sad thing is, in Japan, Suzuki sells this awesome machine with the GZ250 power plant. Much more desirable than the cruiser model.
that thing is insanely badass
MorganSS is offline   Reply With Quote
Old 06-02-2012, 12:15 PM   #5628
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,990
I want it insanely badly.
windigo
Old 06-02-2012, 01:09 PM   #5629
JayGoldstein
Oddometer: 65
Originally Posted by Klay View Post
Does it go away when the bike is thoroughly warmed up?
No, some hesitation is there even when the engine is fully warmed up. I could easily live with the hesitation if it did go away once the engine was up to normal operating temperature.
Jay
2009 DR200SE: ManRacks rack, ScreensForBikes windshield, Wolfman tail bag, 16T sprocket, Kenda K761 tires, Moose Racing CR-HI handlebar, Renthal MX grips, Polisport fender.
JayGoldstein is offline   Reply With Quote
Old 06-02-2012, 01:25 PM   #5630
JayGoldstein
Oddometer: 65
change oil/filter
adjust valves
check tire pressure
clean air filter
Except for a valve adjustment I feel comfortable about doing everything on your list. I'm going to have the initial service done by the dealer because I figure that is the best way to avoid any hassle should I need to make claim under the new bike warranty.
Jay
Old 06-02-2012, 01:37 PM   #5631
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,990
I would adjust the idle screw to richen up the mixture on the low end.
windigo
Old 06-02-2012, 02:34 PM   #5632
BC1
Oddometer: 22
Quick question, is it normal to have oil circulate everywhere on the stator side? Am I missing a seal here....
BC1 is offline   Reply With Quote
Old 06-02-2012, 03:26 PM   #5633
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,990
I believe that's normal...the alternator runs in oil.
windigo
Old 06-02-2012, 04:21 PM   #5634
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,990
windigo
Old 06-02-2012, 04:53 PM   #5635
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
Looks like he's listening to the valves.
Old 06-02-2012, 06:45 PM   #5636
JayGoldstein
Oddometer: 65
Wildlife rescue :-)
Came upon this turtle sunning itself right in the middle of the dirt road. I moved it out of harms way. I couldn't tell if it appreciated my help.
From 2009 Suzuki DR200SE
Jay
Old 06-02-2012, 07:44 PM   #5637
Lateralus180
Lateralus180's Avatar
Oddometer: 46
Klay
What tires do you have on your DR200 in that photo? What size are the ones you have, front and rear?
If they are slightly larger than stock tires, is the speedometer reading off by much? My speedo seems to be off even with the factory tires..
Lateralus180 is offline   Reply With Quote
Old 06-02-2012, 07:53 PM   #5638
Lateralus180
Oddometer: 46
Old 06-02-2012, 08:24 PM   #5639
BC1
Oddometer: 22
Thanks. Can anyone else confirm?
Old 06-02-2012, 09:06 PM   #5640
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,990
Originally Posted by Lateralus180 View Post
Klay
They're Shinko 705s. 40 bucks apiece or so. Almost a street tire, or maybe 90% pavement 10% gravel. 90/90-21 in front and 4.10-18 on the rear. I haven't done a speedometer check with them yet, but they look small, so I bet the speedometer reads fast. Back when I had Kenda K270 tires on it, the speedo was spot on.
windigo
Times are GMT -7.   It's 07:50 PM.
