Old 06-20-2012, 08:13 AM   #5716
BigCanoe
Oddometer: 703
I drove a TU250x for a while, I assume this bike is slower seeing how its down 50ccs? I like the idea of a small dual sport that I can take with me camping, etc.
2007 Yamaha TW200
BigCanoe is offline   Reply With Quote
Old 06-20-2012, 09:33 AM   #5717
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,465
14 mighty horsepower. It's not for the meek.
The future is bright, fruitful, and positive.
Old 06-20-2012, 09:59 AM   #5718
BigCanoe
Oddometer: 703
Ah the TU has 15, or is it 17, eep!
2007 Yamaha TW200
Old 06-22-2012, 02:10 AM   #5719
tomas377
Oddometer: 7
making my dr more highway friendly?
looking at changing the tires for my dr200se because im going to be using it for commuting (school store and going into town) so mostly street use.
Will getting a smoother tire more suited for street use make the ride better or worse going 60mph on the highway(im riding stock tires right now). and what would the sizes for the front and rear tire be so i can start shopping around?
also i have a windscreen on my bike and im thinking about getting the bars higher mostly so it raises the wind protection.would there be any adverse effects with that
and any advice as for options to make the bike better at those speeds for street
btw this is actually my first motorcycle
tomas377 is offline   Reply With Quote
Old 06-22-2012, 10:11 AM   #5720
BigCanoe
Oddometer: 703
Whats the GVWR on this bike ie the weight limit? Can it go 55MPH? Will it be ok sized for a 5'10 individual?
2007 Yamaha TW200
Old 06-22-2012, 10:13 AM   #5721
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,465
I'm 5'10". It goes 55.
Old 06-22-2012, 12:16 PM   #5722
JayGoldstein
Oddometer: 65
I looked at my owner's manual and the GVWR is not stated.
Jay
2009 DR200SE: ManRacks rack, ScreensForBikes windshield, Wolfman tail bag, 16T sprocket, Kenda K761 tires, Moose Racing CR-HI handlebar, Renthal MX grips, Polisport fender.
JayGoldstein is offline   Reply With Quote
Old 06-22-2012, 01:14 PM   #5723
L1ability
Accident Prone
L1ability's Avatar
Oddometer: 34
my dr200, 1986 model, will only get to 55km/h!
im 5-10, 160lbs.... first gear is fine, after that its a dog... going all out in 5th = 55km/h.
mods to the bike are tm28 pumper carb, big gun exhaust and hole-ed airbox.... any ideas?
changing plugs from the old sooty DR8EA to a brand new D8EA didnt help.. might actually be worse.
L1ability is offline   Reply With Quote
Old 06-22-2012, 02:05 PM   #5724
Highaltidude
Oddometer: 71
I'm a similar body type, and my DR200 has plenty of power at 7,000ft elevation. It runs out of gear at 55 mph, but still has ooomph for the hills. Motor is stock (other than jetting for altitude).
Check your compression. Maybe in need of rings????
Chuck
Highaltidude is offline   Reply With Quote
Old 06-22-2012, 03:35 PM   #5725
Wallrat
Wallrat's Avatar
Oddometer: 679
I'm 6' 230lbs and I can sit all day at 60 mph on a flat road with no wind.
If I had to guess I'd say your carb is hurting you. Seems a tad big for an underpowered engine with that heavy of a rider - but I'm hardly an expert.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is online now   Reply With Quote
Old 06-23-2012, 12:23 PM   #5726
rivercreep
Oddometer: 3,243
The oil cooler project, pages ago....
...just wondering if anyone successfully installed an oil cooler? (as was being discussed)
rivercreep is offline   Reply With Quote
Old 06-23-2012, 01:14 PM   #5727
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
Sounds like you have some jetting issues to clear up. Sooty plug sounds like it is too rich.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 06-23-2012, 02:01 PM   #5728
L1ability
Accident Prone
L1ability's Avatar
Oddometer: 34
the sooty plug was caused because the faulty BST31mm CV carb, with that carb the bike idles but wouldent rev,
with the tm28 it idles and revvs great, then is pooched on a load.
the 31mm was supposed to be for street carbs, and the tm28 was supposed to be marketed for the dirt models... right?
IIRC 31mm would dove more top end, 28mm would give more low?
i run a 24mm on my 100cc 2stroke, so i dont think a 28 on a 200 is too much,its smaller than a 31
Old 06-23-2012, 07:01 PM   #5729
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
Where did you get the TM28? Although smaller than a BST31 the CV will not flow as well as a TM type carb.
Old 06-23-2012, 07:03 PM   #5730
MorganSS
Texan
MorganSS's Avatar
Oddometer: 81
I think it was agreed that it was just something else to worry about when it breaks
MorganSS is offline   Reply With Quote
Times are GMT -7.   It's 07:49 AM.
