06-28-2012, 12:32 PM
#5746 |
Carpe Diemer
Oddometer: 91
Dammit. I just had these new tires put on. I wonder if the shop would help me out and check... Guess I'd better give a call...
Seize the frick'n day!! |
06-28-2012, 12:34 PM
#5747 |
Carpe Diemer
Oddometer: 91
Houston Area
Oh another question - Anyone in the Houston area? If so, can you recommend a decent shop? The bike's gonna need inspected soon.
06-28-2012, 12:38 PM
#5748 |
plainsman
Oddometer: 89,147
They're easy to balance on your own...all you need is a wheel balancing tool and some lead weights and sticky tape. You just put weight on the rim opposite the heavy side.
http://www.harborfreight.com/motorcy...FcHRKgod72zmvw
_______ |
06-28-2012, 12:45 PM
#5749 | |
Carpe Diemer
Oddometer: 91
If I weren't busy packing my life up right now to move across the country, I might think about doing it for myself but I just don't have the time. So...off to the shop it goes.
06-28-2012, 01:24 PM
#5750 |
Oddometer: 1,302
Might be that the bead did not get seated correctly, especially if you can feel it at low speeds. I have also seen a few tires that were defective and out of round.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper |
06-28-2012, 04:08 PM
#5751 | |||
yeah - what he said...
Oddometer: 9,051
Might want to bring 'er back and have the shop that mounted it do the work, before you go leavin' town. ![]() I'd agree with Klay & Andy - especially since you just had new tires put on(?)
Tony ![]() Quote:
06-29-2012, 04:36 PM
#5752 |
Accident Prone
Oddometer: 34
as an update to my no power problem, i just got back from the dealer with my new valve ajuster, installed it and WOW, for a 200, with this pumper carb and big gun exhaust it goes.
idles smoother, revvs cleaner and has all its power there. my only problem now, is past 1/2 throttle, it sounds like the top ends gonna explode. up to 1/2 its nice clean power but past that it starts to rattle and clunk like crazy, any ideas? both valves were set to .10mm |
06-29-2012, 07:18 PM
#5753 | |
Oddometer: 1,302
If it sounds like the top end is gonna explode, if you run it long enough making noise like that, it probably will.
06-30-2012, 05:21 AM
#5754 |
Oddometer: 716
Here's my tip: Put the bike on a stand, remove the front caliper, and balance the front wheel on the bike. Easy and works great. You can do the same on the rear but the chain has to be off to remove any drag on the wheel.
2010 Gas Gas EC250 - 1997 Honda XR650L - 1992 Gas Gas GT25 "Twenty years from now, you will be more disappointed by the things that you didn't do than by the ones you did do" - Mark Twain |
06-30-2012, 08:27 AM
#5755 |
Oddometer: 692
"NEW" 2007 DR250SE! I bought it today, 999 miles on the odometer. The last owner barely rode it (obviously). The dealer took it in and cleaned the tank, carb, changed the oil, adjusted the valves, etc etc. I got it for $2600 OTD, its the most I could naggle them down, but they had just done over $300 in service to it, so I figured that was good.
I rode it home about 20 miles, mostly on 55 mph roads. It felt comfortable at about 50-55 indicated, I got it up to 70 indicated. My feet and hands felt a little buzzy when I got home. The dealer admitted its cold natured, I guess a jet kit is in order? Can I drill out and adjust the fuel screw in the meantime? I have started my farkle shopping list already! I was impressed with the comfort for a big (fat) guy like me, and the torque. Also the pretty blue paint job
2007 Suzuki DR200SE |
06-30-2012, 09:26 AM
#5756 |
plainsman
Oddometer: 89,147
_______ |
06-30-2012, 09:36 AM
#5757 |
Oddometer: 37
BigCanoe
The jetting kit makes the bike much much much much better!! It feels hollow and unresponsive with the factory carb parts. On factory settings I would have to warm the bike up for 5-10 minutes with the choke on before I could ride. My 2006 DR200 feels a little more powerful but way more responsive and more grunty with the jetting kit. The engine revs up faster as well. I can ride it with 20-30 second warm ups now, and the choke can come off almost immediately after starting. $40 for the jetting kit and 1-2 hours to install it and fine tune. 2 hours is more realistic.
06-30-2012, 09:38 AM
#5758 | |
Oddometer: 71
When we bought my wife's bike, we were told that same "cold natured" story by the PO. But it never really ran perfect when warmed up (although it did run a bit better). We eventually determined that it was a plugged pilot jet that just played a bigger role when cold....... Note that cold air is denser and should help the lean condition that many of these bikes seem to have w factory jetting at sea level elevation. I'm of the opinion that the "jet kit" is only needed if you have made other changes (exhaust and air box) that require more air flow..... Otherwise it's an easy thing to just jet for tuning....... I don't think it's a problem to drill out the plug to access the idle mixture screw for tuning.... Chuck |
06-30-2012, 09:59 AM
#5759 |
Oddometer: 692
It needs to warm up, then it runs great! Maybe just turning the fuel mixture screw out would help. Anyone got a pic of where it's hidden?
06-30-2012, 10:07 AM
#5760 | |
plainsman
Oddometer: 89,147
Hmm, you see that knob on the lower right of the carb? That's the aftermarket adjustable Kientech fuel mixture screw. ![]() There's a brass plug in the well that you have to get out first if the carb is stock.
_______ |
