06-30-2012, 10:53 AM
#5761 | |
Accident Prone
Oddometer: 34
how do i get the motor to sit perfect at TDC? |
06-30-2012, 11:11 AM
#5762 | |
Oddometer: 71
I've always used a pencil in the spark plug hole (eraser side down) to feel the piston to determine when it's at the top.... Chuck |
06-30-2012, 11:16 AM
#5763 |
plainsman
Oddometer: 89,154
Look at the intake valve. When it starts to come back up after pushing down, you're approaching TDC on the compression stroke. There's an inspection port on the front of the motor, and when you see the hash mark on the flywheel through the port, the piston is at top dead center.
_______ |
06-30-2012, 11:50 AM
#5764 |
Oddometer: 1,302
To get it to stay at TDC, put it in gear.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper |
06-30-2012, 02:27 PM
#5765 |
Oddometer: 37
How many miles is everyone getting out of a set of tires? I have the stock trailwings on my bike. I just rolled over 3,000 miles and the rear looks to have 1/3 tread, and maybe 1/2 tread on the front. I ride 90% street and 10% off road here. The trailwings are good enough on the road but are very squirmy off-road. I feel like I'm going to lose it every time I turn off road.
I'm thinking about getting a set of Michelin T63's in 80/90-21 front and 110/80-18 rear. |
07-02-2012, 10:40 AM
#5766 |
Oddometer: 299
I got about 4 miles out of mine. Then I ordered some that were actually worth a crap.
07 450EXC |
07-02-2012, 01:45 PM
#5767 |
Oddometer: 71
The stock tires get blasted on here frequently.....
The wife and I have put about 1,300 miles each on our bikes since buying them last Fall. Her's was "new" and mine now has 2,200 miles. It's been about 50% pavement and 50% off road. They've still got plenty of life in the tires and we've been very happy with them. Chuck |
07-02-2012, 02:11 PM
#5768 |
Adventurerer
Oddometer: 44
I put over 9,000 miles on my Trail Wings.
They still had tread left, I just replaced them because they were over a decade old and starting to develop tiny dry rot cracks. |
07-02-2012, 07:58 PM
#5769 | |
Oddometer: 118
I would DEFINITELY remove the cylinder head cover and inspect the rockers and shafts, as well as having a look at the cam surfaces, before running the engine again. Hopefully you'll find the screw and nut somewhere in there. If the follower end of the rocker is worn down, or missing, then I can believe the rocker might hit the cap - and then you are in a world of hurt. |
07-02-2012, 08:27 PM
#5770 | |
Oddometer: 118
And while you would be correct to say that the best benefit from a jet kit would be obtained if you increase breathing, like adding a less restrictive pipe, and opening up the airbox, the fact remains that factory jetting is on the ragged edge of too lean, and engine temperatures suffer from it. On a hot day, in heavy traffic, I would rather have a bike that is slightly too rich, but running cooler, than one that is too lean running hot... Just my $0.02. |
07-03-2012, 04:04 AM
#5771 |
Oddometer: 189
new DR owner
We just got my wife a '96 DR200 for her first bike. I took it for a little ride and then turned the petcock to the "off" position (between on and res). Woke up with fuel and oil all over the garage floor.
![]() I'll change the oil and filter but will I need to do anything else? I don't have an owners manual, anything specific I need to know about changing the oil and filter or is it pretty basic (I am figuring pretty basic)? Thanks all
2009 KLR (Red & Black) '96 DR200 (really my wife's but she must share) Trans WI Adv Trail Oct 2011 Photos (I still have to write that RR) Zaboo65 screwed with this post 07-03-2012 at 05:52 AM |
07-03-2012, 04:33 AM
#5772 | |
Oddometer: 118
Check for a second rubber hose coming off the back of the petcock, and terminating on the opposite side of the carb from the fuel line. That would be the vacuum line, which controls the petcock. Also, in my experience, if it's leaking that much fuel, the o-ring which seals the needle/seat assembly into the carb body is shot. Easy enough to change, and the bike will probably run better for a long time. Once it is hardened, it begins to leak randomly with vibration, and can contribute to everything from poor idling and starting problems, to major driveability problems. Ethanol fuel components (gasohol) can cause this o-ring to get hard. I think it a 6 x 1.5 mm o-ring. To answer your original question, just drain the oil, change the filter, and away you go! Oil plug on the bottom of the crankcase, in the middle of the triangular flange, oil filter behind the round cover with three acorn nuts on the right-side engine cover. Be sure the center o-ring is there, and that the one in the oil filter cover is still good. Refill, starting with 800ml or so, start the engine for a minute or so, then stop it and let it sit while the oil drains back to the sump. Make sure the bile is upright, and check the sight glass on the engine side cover, and top up until it's half way up. Bam! You're done. Congrats on the new bike - they're a whole lot of fun. Your wife will love it. |
07-03-2012, 08:43 AM
#5773 | |
Oddometer: 37
07-03-2012, 09:31 AM
#5774 |
Oddometer: 299
Just save yourself a headache and replace the stock petcock with a raptor one. It's $15 and can potentially save your engine.
07 450EXC |
07-03-2012, 09:33 AM
#5775 | |
Stuck @ Home! >=^(
Oddometer: 1,095
Pull the spark plug and rotate the engine by putting the bike in gear and pushing it.If there is any fuel in the cylinder,it will be expelled with extreme prejudice.
Manic Cycles=My Facebook Page |
