Old 07-23-2012, 07:00 PM   #5851
FAW3
Old wanderer
FAW3's Avatar
Oddometer: 685
On rv trip...DR200 died...
Nuts...bike suddenly died on ride. Spark on grounded plug seems ok. Cranks fine, fuze ok, fuel to carb ok...just no catch/start. Started clean carb...does white plastic bushing/washer go on top of main
jet OR under the collar?
FAW3 is offline   Reply With Quote
Old 07-24-2012, 09:22 AM   #5852
Lateralus180
Lateralus180's Avatar
Oddometer: 46
I took a photo of the instructions that came with my jetting kit. It should be the same for stock parts.
Lateralus180 is offline   Reply With Quote
Old 07-24-2012, 10:26 AM   #5853
FAW3
Old wanderer
FAW3's Avatar
Oddometer: 685
Thanks for that photo....carb cleaned...seems fine but still no start. Tried removing air cleaner and using starting fluid as a test....still nothing. Thinking elect issue....checking harness connections. Bike cranks fine...just no catch/start.
? Would defective coil or ci module allow a spark on at grounded plug? I get spark at grounded plug.
There is only one fuze right?
Old 07-24-2012, 01:31 PM   #5854
tony the tiger
yeah - what he said...
tony the tiger's Avatar
Oddometer: 10,662
Cool2
Thanks for that photo....carb cleaned...seems fine but still no start. Tried removing air cleaner and using starting fluid as a test....still nothing. Thinking elect issue....checking harness connections. Bike cranks fine...just no catch/start. ...so, it's not a kickstand switch or sumpthin'...
? Would defective coil or ci module allow a spark on at grounded plug? I get spark at grounded plug. what color spark ya' got?
There is only one fuze right? yep
You got fuel, air and spark... what was happening when the "bike suddenly died on ride?"
How old was the gas in the tank, and have you changed it out for fresh fuel?
When the bike is cranking over - battery sound like it's dying or is there a fresh charge on it? How long since you last rode it?
When did you last clean the air filter?
You sure the fuze is good? Well, I suppose it must be if it's cranking over, never mind that one.
That's all I got - charge the battery, change the fuel and maybe the sparkplug if it's fouled.
Tony
Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines.
tony the tiger is offline   Reply With Quote
Old 07-25-2012, 04:27 AM   #5855
Wallrat
Wallrat's Avatar
Oddometer: 821
If you've got spark then its not electrical - unless your timing jumped (highly unlikely). My money is on fuel - maybe a clogged jet that you missed, issue with the fuel line to the carb, something like that. If you're using the stock petcock put it on prime and make sure you have good flow out of the bottom of the carb if you open the bowl drain. Could also be low compression I guess. Adjust the valves, and while you're at it take note of the resistance you feel when you rotate the engine by hand.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 07-26-2012, 01:28 PM   #5856
dalehazelton
Oddometer: 47
Originally Posted by Lateralus180 View Post
I think most of the DR200 owners in the thread have experienced gasoline in the crank case at some point as well.
There is a Yamaha fuel petcock linked on the first or second post in the thread. It was like $13 online and is pretty much a necessity.
EDIT:
Part number
Yamaha 23F-24500-11-00 - FUEL COCK ASSY 1
I used a Briggs and Stratton lawn mower fuel shutoff that that cost about three dollars.
dalehazelton is offline   Reply With Quote
Old 07-26-2012, 07:19 PM   #5857
Cheska
Old but still kickin
Cheska's Avatar
Oddometer: 8
Need your expert help
Hi just received my Yamaha fuel petcock 23-2450-11. My current Suzuki one has 2 hoses off it. Looking at bike from
side where petcock is one hose goes to bottom of left side of carburator. The other comes off the back of the petcock
and goes to the other side of the carburator. I am assuming that one gets sealed off as the new petcock only has one
outlet for the fuel. I'm old and slow so any help is appreciated. Plus I did try a search for pictures or explanation but
was unable to find anything. Thanks in advance for any help for this old guy. Bob
Cheska is offline   Reply With Quote
Old 07-26-2012, 07:23 PM   #5858
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,027
Your thinking is correct.
Old 07-26-2012, 10:12 PM   #5859
Cheska
Cheska's Avatar
Oddometer: 8
Thanks Klay
Thankyou Klay tommorrow I will install new petcock. Thanks again Bob
Old 07-27-2012, 05:26 AM   #5860
BigCanoe
Oddometer: 704
I think most folks cap off the vacuum port at the carb, thats the extra hose. Caps can be purchased at AutoZone, etc.
2007 Yamaha TW200
BigCanoe is offline   Reply With Quote
Old 07-27-2012, 04:54 PM   #5861
Lateralus180
Oddometer: 46
I shoved a golf ball tee in one of the hoses to cap it off. The tee has a taper near the top and it has worked reliably since I installed it.
Old 07-28-2012, 07:59 AM   #5862
JayGoldstein
Oddometer: 68
Sunstar Powerdrive 16T front sprocket vs stock
In his write-up about replacing the stock (15T) front sprocket with the Sunstar 16T part (# 32316) BigCanoe mentioned that "...the stock one has a rubber surface on one side" while the Sunstar sprocket doesn't. Does this a difference in construction make a difference? What is the function (if any) of the "rubber surface" on the stock sprocket?
Jay
2009 DR200SE: ManRacks rack, ScreensForBikes windshield, Wolfman tail bag, 16T sprocket, Kenda K761 tires, Moose Racing CR-HI handlebar, Renthal MX grips, Polisport fender.
JayGoldstein is offline   Reply With Quote
Old 07-28-2012, 08:35 PM   #5863
Wallrat
Wallrat's Avatar
Oddometer: 821
If I'd have to guess I'd say noise reduction.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Old 07-29-2012, 05:37 AM   #5864
ADVCoop
ADVCoop's Avatar
Oddometer: 792
It doesn't work. Yamaha put them on the WR250R/X's too and all they do is squeak and get annoying. I sliced them off both the front and rear sprockets and have been happier since .
2006 Husqvarna TE610 - 1982 Suzuki PE175 - 2009 Yamaha XT250 (wife's)
ADVCoop is offline   Reply With Quote
Old 07-29-2012, 02:20 PM   #5865
FAW3
Old wanderer
FAW3's Avatar
Oddometer: 685
I cleaned carb again.....success! The DR is running again. We are RV bumper hauling this little gem...now in Ottawa and it makes getting around a blast-a sturdy capable MC.
Thanks to all for advice given...
Times are GMT -7.   It's 11:23 AM.
