Old 08-29-2012, 07:32 AM   #6001
Lukon
Oddometer: 19
Originally Posted by Wallrat View Post
Slide the smallest washer onto the pointy end of the needle all the way up until its snug against the needle clip, should be a snug fit. Drop the needle down into the slide and bounce it around until it drops through the center hole in the slide. Push the needle back up with your finger so you can add the larger shoulder washer to the top of the needle. Place the spring against that. The diaphragm has a little tab on one side that matches with the tab on the carb body and cover.
I think I lost that smallest washer, and that is why the needle has some play. I just have the clip on the needle and a nylon spacer which goes on top of the clip. I'm guessing that washer guides the needle down to seat positively with the main jet. That is why I'm running so rich that I have to keep the air filter off to keep the engine from choking out. Thank you! I'll look for that part.
I'm sill concerned about what I may have done to the float level by bending the tabls all over the place, trying to compensate. Does anyone know how to set that correctly?
Can I just send my carb in to Keintech, along with my muffler and get it all done right? How much would that be?
2007 DR200 Bone Stock so far...
Airhawk seat pad -Love it!
Lukon is offline   Reply With Quote
Old 08-29-2012, 07:35 AM   #6002
Lukon
Oddometer: 19
Originally Posted by Zaboo65 View Post
Thanks Coop, that might be what I have to do!
How much would a whole wheel be, from one of those sites that sells the Chinese clones of these bikes? hay might sell spokes as well...
Old 08-29-2012, 08:11 AM   #6003
Wallrat
Wallrat's Avatar
Oddometer: 798
Can somebody post a link to the online manual so I can look up the float setpoint.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 08-29-2012, 04:57 PM   #6004
Lateralus180
Lateralus180's Avatar
Oddometer: 46
You have probably found the manual by now but here it is:
http://www.scribd.com/doc/40540261/DR-200-Owners-Manual
Lateralus180 is offline   Reply With Quote
Old 08-30-2012, 10:59 AM   #6005
Wallrat
Wallrat's Avatar
Oddometer: 798
Nope. That's the link I knew of and I refuse to allow all the scripts on that site to run on my computer so it won't load the images for me. Seriously don't visit that site. Ever. NoScript is showing a total of 7 really bad guys trying to run and a couple others that are malicious but are no big deal if you run a pop-up blocker, etc.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Old 09-01-2012, 11:11 AM   #6006
Charliedog43
Charliedog43's Avatar
Oddometer: 20
Loose ignition key
Got sometime new for you all. I've never had a cycle do this before. The key is so loose in the ignition while riding my 2003 DR200 (bought it the end of Feb. w/ 728 miles on it), that I can hear it buzzing with my faceshield open on my full face helmet. I thought it might be loose enough I could pull it out while riding and then re-insert it to turn the ignition off, but it's not quite that loose. The only thing I can think of is a strip of velcro secured on both sides of the key to keep it from buzzing. Any other suggestions would be appreciated.
Larry aka CharlieDog
Bristol, TN
Charliedog43 is offline   Reply With Quote
Old 09-02-2012, 10:36 AM   #6007
Wallrat
Wallrat's Avatar
Oddometer: 798
That happens when you hang a bunch of heavy crap on the keychain. Probably have a lot of wear around the ignition as well where all that crap was rattling. Might try smearing a tiny layer of beeswax on the key? IDK other than replacing the ignition.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Old 09-05-2012, 12:32 PM   #6008
Retired Rider
Oddometer: 3
New guy
Hi,
I've just become an ADVrider member today. This is my first reply (I haven't yet figured out how to post anything). Being an old man I'm somewhat of a techno-tard when it comes to learning my way around. I have a 2000 DR200 and was pleased to see an interest in a DR200 thread. I hope to learn a lot and look forward to seeing how other DR200 riders roll.
Retired Rider is offline   Reply With Quote
Old 09-05-2012, 01:41 PM   #6009
BigCanoe
Oddometer: 703
Originally Posted by Retired Rider View Post
Hi,
Welcome, good choice!
2007 Yamaha TW200
BigCanoe is offline   Reply With Quote
Old 09-05-2012, 02:04 PM   #6010
Retired Rider
Oddometer: 3
Thank you, this is a great site. The more I see the more I like. I'll feel better once I learn how to find my way around.
Old 09-05-2012, 02:06 PM   #6011
Retired Rider
Oddometer: 3
Thank you, I see I just started a new reply while trying to reply to your "welcome". I'll get this figured out sooner or later. Fun stuff.
Old 09-05-2012, 02:59 PM   #6012
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,728
Hi,
Welcome.Don't take much of anything too serious around here.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 09-08-2012, 11:32 AM   #6013
Pauls2ndblessing
Oddometer: 99
Hello and Great thread!!
Hey guys,
My name is Paul, purchased my first bike for me and my missus to learn on. Got a 07 DR200 and absolutely love it! My missus has a sprung ankle at the moment so she hasn't had a chance to do anything with it but I've been on it every day since I bought it :)
Definitely like the thread going here!
So I'm wondering what the limitations are on this bike, I've now had it in some soft sand/clay at a pit and it seemed to do really well. Climbed a small hill, road on some dirt, gravel, and hard packed clay and it really has seemed to push through everything I've put in front of it with no problem at all.
I'm tall but skinny, 6'0 at 145lbs and have no problem getting up to speed.
So I'm wondering if this thing will push through some trails? Nothing to intense as we don't have much/if any elevation here in Southern Alabama near the coast. Few rolling hills and thats about it, so where should I be concerned when it comes to off-roading?
I've only had the bike for a week but I can't imagine ever getting rid of it... well it'll go 100% to my missus if she decides she wants to really start getting into it, then I'll look at the drz400 for my dual sporting.
Thanks for a great thread and I look forward to any responses :)
Paul
Pauls2ndblessing is offline   Reply With Quote
Old 09-08-2012, 11:51 AM   #6014
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,758
Welcome to motorcycling, Paul. I imagine the DR200 is up to whatever kind of service you want to throw at it. You could even take it touring if you're patient enough. It's short on power and suspension, but I'll never get rid of mine. It's the one I ride every day.
Old 09-08-2012, 12:02 PM   #6015
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
I need more power on the interstate especially on slight gradients. I do not want a 650 just yet. Wll the kientech kit, air box bod and fmf exhaust significantly improve the power or not?
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Times are GMT -7.   It's 05:39 PM.
